nRF24L01(+) driver / demo available for propeller 1?
2»
  • RS_Jim wrote: »
    Jessie,
    I am attaching a file that captures what I see in minicom when the shockburst demo is running from the transmit side.. The .odt is a Libre Office text file. The received file, without interrupt, is in the .odt file attached to the interupts thread.
    Jim
    Hi Jim,
    It looks like you may be running the PST-compatible version (NRF24L01-TXDemoWithAA-PST.spin) in minicom. The one that should work with correct output in minicom or another ANSI-compatible terminal is the NRF24L01-TXDemoWithAA.spin
    I develop demos like these that target ANSI-compatible terminals first, as they're most easily accessible no matter which platform a person's using. The -PST version in this case was an exception that I made for someone that wanted the output to work with the PropTool.
    Let me know how it goes if you try the ANSI-compatible version.
    Cheers,
    Jesse
  • Jesse,
    I am running NRF24L01-TXDemoWithAA.spin. I haven't run any of the PST versions. I moved the included files into the main program as my compiler does not handle #include. I need to reorder the transmit program as it wants to send 20 repeats before sending the origonal data. if the main transmission is akd the repeats should never be sent.
    jim
  • Hi Jim,
    I'd strongly recommend using openspin to build everything...then you won't have to go through the extra effort of combining sources (it should just work as-is) - time better spent just developing an application. In any case let me know if there's something I can do to help.
    Cheers,
    Jesse
