Shop Learn
Simple IDE print to paper — Parallax Forums
This is silly, but although I can get the Propeller Tool to print to paper, I am unable to do the same with Simple IDE. "Print" and CTRL + P do nothing. I am using a PC with Windows 7 Pro together with an Epson printer. Can't find the answer in the Help document. Any clues?
  • Well the print screen and ALT print screen and then CTRL ALT print screen generate graphic images of what you are looking at.
    Once you press these buttons you can past the image into Paint.
  • I was able to replicate this problem also. Open a project, and File>Print does nothing.
    SimpleIDE 1.1.2
  • Good idea, iseries. I inserted the screen image into a Word document and it printed OK. Many thanks for the tip.
    Publison: Yes, I am also using version 1.1.2.
    Thank you again for your prompt replies. The Parallax forum rocks!!
  • Addington wrote: »
    It would be a problem to print multiple pages. It needs to be fixed IMHO.
  • Can't print. Why is this not fixed?
    I copy and paste into Notepad. Keeps formatting, but not color.
