Quickstart + LCD + 9V
in Propeller 1
Hello,
i would like to connect a 9V battery to the quickstartboard and the LCD be powered from the board.
Which pin should i use ?
LCD : RX = pin 12
gnd = pin 39
5V = pin ???
9V: + on pin 40 and - on pin 39
I have fried my previous quickstart board by misconnected the 9V on the little holes. now i'm a bit reluctant to try something.
LCD : RX = pin 12
gnd = pin 39
5V = pin ???
Another solution :
Could i use a USB standalone smartphone charger instead of 9V battery? (i have a revB quickstartboard)
I'm currently using a USB wallplug.
Maybe something like this:
-- https://www.amazon.com/SoulBay-Replacement-Versatile-Regulated-Electronics/dp/B07BXW19R7
Run the LCD directly from the logic battery.
At 4 volts is was necessary to adjust the contrast to read the display.
But it wasn't visible at all on 3.3VDC.
I think the LCD controller was running. But the display was not readable.
