Any Heathkit Fans Out There? - Page 2 — Parallax Forums
2»
    edited 2020-04-13 17:44
    DigitalBob wrote: »
    I see a few of those EC-1 tube computers on Ebay
    I looked at those in the Heathkit catalog when they were still being sold but never really wanted one. I'm a programmer so I need a computer that has enough memory to write a significant program. That's why the ET-3400 didn't work out for me, I think there was a memory expansion available for it but even that only brought it up to 1K as I recall.
  • David Betz wrote: »
    DigitalBob wrote: »
    I did 32K of static RAM expansion on my ET-3400 with battery backup.
  • Publison wrote: »
    David Betz wrote: »
    DigitalBob wrote: »
    Nice! Did you make a kit that I can buy from you to expand mine? :smile:
  • Would anyone be interested in a free* oscilloscope calibrator, model 4505? calibrator & power cord only, no manuals or cables.
    I didn't build it, but it seems to work fine. I don't have a use for it.
    These seem to be going for $40 or more on ebay. I'd rather it go to someone on these forums instead.
    *Just pay shipping...
    Publison wrote: »
    David Betz wrote: »
    DigitalBob wrote: »
    I used a 30- ns cache chip that was for a 486 mother board. I can't put my finger on it. just closed on my house and every thing is in boxes in storage.
    DigitalBob wrote: »
    The EC-1 was an analog computer. It didn't have "memory" and you didn't write "programs" for it at all, you selected appropriate feedback components for the op-amp circuitry so that the output voltage would settle to the solution which was required to solve the equation encoded by the circuit wiring and feedback values for the given inputs.
  • localroger wrote: »
    David Betz wrote: »
    DigitalBob wrote: »
    That's my point exactly. No ability to program it at all. The ET-3400 was only slightly better with 256 bytes of memory.
  • The circa '75 AR-1214 sniped off Ebay.
    Was in need of some repair: the two pots for balance and volume are duals, and each were terribly out-of-tolerance. So I hardware a couple fixed resistors in place for the balance pot, and then dangled a dual volume pot through the front panel.
    After in use for a couple months, the output level dropped significantly. Found a "popped" electrolytic in the voltage doubling circuit that powers the preamp section. Then, after another few months, two electrolytics in the power amp supply filters popped.
    Interestingly, the circa '72 AA-1214 that I built has had no components replaced. Not saying there's no need; I'm sure some of the electrolytics could stand to be retired!
    1024 x 404 - 69K
    Noisy potentiometers and bad electrolytic capacitors were two of the most common problems on a lot of the older analytical and imaging equipment I looked after. A small battery powered amplifier with a capacitor on the input and speaker was good for testing both.
