New P2 Silicon
1192021222325»
  • David Betz wrote: »
    Are there any differences between B and C other than the pin coupling fix?
    No, that one alone was a much cheaper fix than any of the others.
  • cgracey wrote: »
    The new P2 silicon seems fine.
    To celebrate, Ken has put the P2-ES Eval Rev B boards and the P2-ES Rev B 4-packs on sale:......
    Does that mean that the “One Eval Board per customer” restriction has been rescinded?
  • jmgjmg Posts: 14,278
    ke4pjw wrote: »
    Were the pads reworked to resolve the latchup "problem"? I can't recall. Problem in quotes because latchup only occurs well above spec.
    Will Rev. C Eval boards be available? Hoping to have a full collection :)
    We did not put the guard rings around certain n-wells because it would have been a very expensive all-layer change. We're just going to rate the part for 4.0V, absolute max.
    I did not see injection current levels specified for latchup ? - Just a lowering of the Abs Max Vcc value ?
    Other vendors spec their MCUs like this
    VHBM[*1]      Electrostatic discharge,human body mode      -8000 - +8000 V
    VCDM[*2]      Electrostatic discharge,charge device model  -1000 - +1000
    LU[*3]        Pin current for latch-up[*3]                 -400  - +400 mA
    VEFT[*4] [*5] Fast transient voltage burst                 -4.4  - +4.4 kV
    How much process variation are you seeing in a new batch ?
    are leakage, mA/MHz and maximum SysCLK significantly different, or ~exactly the same ?
  • doggiedoc wrote: »
    Yes, both those restrictions have been lifted for around a month
    Yes, please buy what you'd like! Multiple boards per customer are now allowed since we've been able to put at least one in the hands of each interested developer [who expressed interest in the P2].
  • evanh wrote: »
    David Betz wrote: »
    ke4pjw wrote: »
    If you're really going to have a full collection you'll have to get someone to sell you one of the ultra rare glob top boards.
    There was both revA and revB editions of those. I have a revB. I don't think Chip gave out any of the revA glob-tops.
    IIRC there were only 10 glob top Rev A chips. One got drilled/destroyed by Chip during assembly of the first board(s) :(
    I think they were only built on Peter's P2D2 Rev1 boards, not the P2-EVAL boards which were not done at the time.
    Peter J and I have RevA glob tops because we needed to verify our ROM code. I think one may have gone to the Melbourne guys.
    Peter may have put a couple on the first P2D2's he built??
    So, out of 10, 1 destroyed, 1 each to Chip, Peter, myself, and melbourne. So 5 whereabouts unknown.
    BTW I won't be selling mine.
    FWIW there were ~120 Rev A with production packaging.
  • Cluso99 wrote: »
    Two ended up down here, and sadly the good smoke escaped out of both of them. :(
    The cause was a nasty firmware bug in a bench top supply that changed ranges from 5V to 36V.
  • jmg wrote: »
    Well, we've got TWO P2 Eval boards with Rev C silicon on them. That's it, at this point. I haven't done any measuring.
  • jmg wrote: »
    ke4pjw wrote: »
    ON ran their standard latch-up test and the P2 passed. Let me see if I can find the results...
    704 x 117 - 30K
  • And here are the ESD test results:
    659 x 205 - 45K
  • Any new info for Rev. C?
    Bill M.
    Bill M.
    It's all the same. Just a resistor within the ADC mux was disconnected to stop noise coupling.
  • evanhevanh Posts: 8,960
    edited 2020-03-12 - 05:52:58
    There'll be one or two B-pin selections within the WRPIN "P" field bits that no longer work.
    EDIT: Maybe just the ADC ... P=%100_010_xxxxxxx
  • evanh wrote: »
    Right. Now, if you select that mode, you can measure the zero-bias point of the ADC, which is potentially useful for measuring very small currents.
  • Roy ElthamRoy Eltham Posts: 2,788
    edited 2020-03-12 - 08:51:27
    @cgracey,
    in the docs for the wrpin mode TT bits it says this:
    for all smart pin modes (%MMMMM > %00000):
                 x0 = output disabled, regardless of DIR
                 x1 = output enabled, regardless of DIR
    In my testing with pwm_triangle and pwm_sawtooth modes, I found that the output would be driven once I raised DIR even if TT = 00.
    Either I don't understand something, or the docs are not complete/correct.
    I was thrown off by the extra 0 in the bottom bit. /sigh sorry.
  • Working as per the docs for me. I'd say you've got something interfering.
    edited 2020-03-12 - 08:53:01
    Nevermind, I was wrong. I need to stop doing this kind of stuff late at night when I am tired.
  • Cool, I couldn't compile your example anyway. My Fastspin was out of date for C support and when updated it couldn't find a certain libc/unix/bufio.c file. I'm guessing the spin2cpp master tree is in limbo, atm. I'll probably have to build it from the FlexGUI master sources instead.
  • Roy Eltham wrote: »
    Here's a collection of some constants I include with every program now
    ' Pin modes
    '   ***** PIN MODES INCOMPLETE ***** ONLY HAS WHAT I USED *****
    	P_REGD		= (%1 << 16)		' turn on clocked digital I/O (registered pins)
    	P_IINV		= (%1 << 15)		' invert digital input
    	P_OINV		= (%1 << 14)		' invert digital output
    	P_NFB		= (%0001 << 17)		' negative feedback, in -> not out
    	P_FLOAT		= (%111111 << 8)	' float digital output
    	P_1K5R		= (%001001 << 8)	' 1.5 kiloOhm digital output
    	P_15KR		= (%010010 << 8)	' 15 kiloOhm digital output
    	P_1mA		= (%100100 << 8)	' 1 milliAmp digital output
    	P_COGDAC	= (%01 << 6)		' select a cog/streamer for DAC level, smartpin must be off
    	P_BITDAC	= (%10 << 6)		' preset for DAC level (split in revB), smartpin off (default for smartpins when DACMODE)
    	PM_DAC		= (%101 << 18)		' DAC output (with optional ADC input), preset level
    	PM_DAC_990	= PM_DAC |(%00 << 16)	' 990 Ohm, 3.3 Volt range
    	PM_DAC_124	= PM_DAC |(%10 << 16)	' 124 Ohm, 3.3 Volt range
    	PM_DAC_600	= PM_DAC |(%01 << 16)	' 600 Ohm, 2.0 Volt range
    	PM_DAC_75	= PM_DAC |(%11 << 16)	' 75 Ohm, 2.0 Volt range
    	PM_COMPDAC	= (%1100 << 17)		' Analogue comparator with DAC as preset reference
    	PM_ADC		= (%100 << 18)		' turn on custom pin ADC input
    	PM_ADC_GIO	= PM_ADC | (%000 << 15)
    	PM_ADC_VIO	= PM_ADC | (%001 << 15)
    	PM_ADC_B1	= PM_ADC | (%010 << 15)
    	PM_ADC_A1	= PM_ADC | (%011 << 15)
    	PM_ADC_A3	= PM_ADC | (%100 << 15)
    	PM_ADC_A10	= PM_ADC | (%101 << 15)
    	PM_ADC_A30	= PM_ADC | (%110 << 15)
    	PM_ADC_A100	= PM_ADC | (%111 << 15)
    	AF_PLUS1	= (%0001 << 28)
    	AF_PLUS2	= (%0010 << 28)
    	AF_PLUS3	= (%0011 << 28)
    	AF_MINUS1	= (%0111 << 28)
    	AF_MINUS2	= (%0110 << 28)
    	AF_MINUS3	= (%0101 << 28)
    	AF_OUT		= (%0100 << 28)
    	AF_NOT		= (%1000 << 28)
    	AF_PLUS1NOT	= (%1001 << 28)
    	AF_PLUS2NOT	= (%1010 << 28)
    	AF_PLUS3NOT	= (%1011 << 28)
    	AF_MINUS1NOT	= (%1111 << 28)
    	AF_MINUS2NOT	= (%1110 << 28)
    	AF_MINUS3NOT	= (%1101 << 28)
    	AF_OUTNOT	= (%1100 << 28)
    	BF_PLUS1	= (%0001 << 24)
    	BF_PLUS2	= (%0010 << 24)
    	BF_PLUS3	= (%0011 << 24)
    	BF_MINUS1	= (%0111 << 24)
    	BF_MINUS2	= (%0110 << 24)
    	BF_MINUS3	= (%0101 << 24)
    	BF_OUT		= (%0100 << 24)
    	BF_NOT		= (%1000 << 24)
    	BF_PLUS1NOT	= (%1001 << 24)
    	BF_PLUS2NOT	= (%1010 << 24)
    	BF_PLUS3NOT	= (%1011 << 24)
    	BF_MINUS1NOT	= (%1111 << 24)
    	BF_MINUS2NOT	= (%1110 << 24)
    	BF_MINUS3NOT	= (%1101 << 24)
    	BF_OUTNOT	= (%1100 << 24)
    ' Smartpin modes
    	SP_OUT		= (%1 << 6)		' enable digital output when DIR operates smartpin
    	SPM_OFF		= 0				' smart pin off (default)
    	SPM_REPOSITORY	= %00001_0			' long repository (P[12:10] != %101)
    	SPM_DAC_RANDOM	= %00001_0 |SP_OUT|PM_DAC	' DAC noise (P[12:10] = %101)
    	SPM_DAC_RND	= %00010_0 |SP_OUT|PM_DAC	' DAC 16-bit dither, noise (P[12:10] = %101)
    	SPM_DAC_PWM	= %00011_0 |SP_OUT|PM_DAC	' DAC 16-bit dither, PWM (P[12:10] = %101)
    	SPM_PULSES	= %00100_0 |SP_OUT		' pulse/cycle output
    	SPM_STEPS	= %00101_0 |SP_OUT		' transition output
    	SPM_NCO_FREQ	= %00110_0 |SP_OUT		' NCO frequency
    	SPM_NCO_DUTY	= %00111_0 |SP_OUT		' NCO duty
    	SPM_PWM_TRI	= %01000_0 |SP_OUT		' PWM triangle
    	SPM_PWM_SAW	= %01001_0 |SP_OUT		' PWM sawtooth
    	SPM_PWM_SAW_FB	= %01010_0 |SP_OUT		' PWM switch-mode power supply, V and I feedback
    	SPM_CNT_QUAD	= %01011_0		' count: A-B quadrature encoder
    	SPM_CNT_UP_ENA	= %01100_0		' count: A clock up, B enable
    	SPM_CNT_DIR	= %01101_0		' count: A clock, B direction
    	SPM_CNT_UP	= %01110_0		' count: (Y=%0) A clock up
    	SPM_CNT_UP_DN	= %01110_0		' count: (Y=%1) A clock up, B clock down
    	SPM_ACC_UP	= %01111_0		' accumulate: (Y=%0) A up
    	SPM_ACC_UP_DN	= %01111_0		' accumulate: (Y=%1) A up, B down
    	SPM_TIM_STEP	= %10000_0		' interval: of most recent step duration
    	SPM_TIM_PULSE	= %10001_0		' interval: of most recent pulse duration
    	SPM_TIM_MANY	= %10010_0		' interval: (Y=%0xx) of X number of accum/pulses/steps
    	SPM_TIMEOUT	= %10010_0		' interval: (Y=%1xx) since most recent high/rise/edge, with X compare
    	SPM_TIM_PULS	= %10011_0		' interval: of X number of A-B pulses/steps
    	SPM_ACC_PULS	= %10100_0		' accumulate: pulses/steps, of X number of A-B pulses/steps
    	SPM_TIM_OVER	= %10101_0		' interval: of A-B pulses/steps, for at least X duration
    	SPM_ACC_OVER	= %10110_0		' accumulate: A-B pulses/steps, for at least X duration
    	SPM_CNT_OVER	= %10111_0		' count: A-B pulses/steps, for at least X duration
    #ifdef PROP2_REVA
    	SPM_USB_HOSTL	= %11000_0 |SP_OUT		' USB host, low-speed (even/odd pin pair = DM/DP)
    	SPM_USB_HOSTH	= %11001_0 |SP_OUT		' USB host, high-speed (even/odd pin pair = DM/DP)
    	SPM_USB_DEVL	= %11010_0 |SP_OUT		' USB device, low-speed (even/odd pin pair = DM/DP)
    	SPM_USB_DEVH	= %11011_0 |SP_OUT		' USB device, high-speed (even/odd pin pair = DM/DP)
    #endif
    #ifdef PROP2_REVB
    	SPM_ADC_ISINC	= %11000_0			' ADC sample/filter/capture, internally clocked
    	SPM_ADC_ESINC	= %11001_0			' ADC sample/filter/capture, externally clocked
    	SPM_ADC_SCOPE	= %11010_0			' ADC scope-mode, with trigger, internally clocked
    	SPM_USB		= %11011_0 |SP_OUT		' USB v1.0 host or device, (even/odd pin pair = DM/DP)
    #endif
    	SPM_SSER_TX	= %11100_0 |SP_OUT		' sync serial transmit (A-data, B-clock)
    	SPM_SSER_RX	= %11101_0			' sync serial receive (A-data, B-clock)
    	SPM_ASER_TX	= %11110_0 |SP_OUT		' async serial transmit (baud)
    	SPM_ASER_RX	= %11111_0			' async serial receive (baud)
    	SSTX_STOP	= (%1 << 5)			' sync serial transmit first bit direct when empty (start-stop mode)
    	SSRX_LATE	= (%1 << 5)			' sync serial receiver post-clock sampling
  • evenh,
    Yeah the current spin2cpp code in github is missing the bufio.c file, I just made one with stub functions to get it to compile. I also have local changes/fixes that are waiting in pull requests for Eric's return.
    If you still have the code you can see that I was setting mode to 0x00000050 which indeed sets the TT bits to 01. I was mentally shifting it because of the unused bottom bit.
  • potatohead wrote: »
    Did we ever make a programmer's model of a COG, similar to the ones published for many other CPUs?
    Is there one even for the prop1?
