RLE encoded images - Realtime display?
Rayman
in Propeller 2
Ken once wanted to show PowerPoint slides using a Propeller:
http://forums.parallax.com/discussion/140056/running-a-presentation-from-a-propeller-putting-a-bmp-in-vga/p1
Phil came up with some kind of real time compressed image decode to do something interesting.
Was just thinking about this in terms of P2 and 1080p display.
Seems there's this ancient image format called PCX that implements some kind of RLE encoding.
See the attached example. Irfanview can show it. It's a fairly complex, 256 color, 1080p image that comes in at 215 kB.
Forum software won't let me attach a .pcx image, so I zipped.
If it could be decoded faster than the frame rate, might be in business...
There's room for two of this size image in HUB RAM...
I found some c++ code here that looks like it can decode pcx:
https://github.com/mackron/dr_libs/blob/master/old/dr_pcx.h
