Passing data between cogs in Tachyon — Parallax Forums
Compadres, I am struggling with understanding how to pass numeric values from one cog to another.
I find the descriptions of the revelant words in the Glossary and Introduction to be confusing.
For instance I want to make a cog clock a port at regular intervals that can be changed from my
main program. Any help?
  • artkennedy wrote: »
    Just use a variable that any cog can read and write to.
    Wow, I tried doing it with constants and that didn't seem to work. Missed the obvious. I was trying to use the ATN/ENQ words. Thanks.
  • Though rarely if ever used, the ATN ENQ are more like a mailbox for each specific cog. But I've found it simpler to just use variables and I can also manipulate these from the console.
  • When you STOP a task, can it be restarted? It's not working for me.
    Also a task that has been stopped still appears in the .TASKS list. Is that expected?
    When I stop a task with n STOP does appear to stop but is still listed.
    edited 2020-02-17 06:19
    artkennedy wrote: »
    Generally once a task is started, it is rarely stopped although you can simply exit and return control to the IDLE task which ran it for you in the first place.
    If you do a COGSTOP it destroys this whole IDLE mechanism so you should build something into your code to ask it to exit back to IDLE.
    There's only so much we can do with cogs and unfortunately there isn't any kind of ability in the P1 other than to init it, or stop it.
    Here's the code for the IDLE loop which all the unused cogs are running after having been coginit'd with the Tachyon kernel at boot. Remember, you have to have a binary image present in hub memory to coginit it into the cog.
    --- idle loop for other Tachyon cogs
    : IDLE
    	BEGIN
    	  !RP 0 COGID TASK W!				--- clear task vector on entry or exit
    	  !SP 1 COGID TASK 2+ C!			--- set this cog's task flag to 1
    	  BEGIN 8 ms COGID TASK W@ ?DUP UNTIL		--- save power while waiting
    	  DUP >>8 IF ACALL THEN				--- execute user code if > $FF
    	AGAIN
    btw, the 8 ms in the idle loop was inserted at a time when I needed my P1 to draw 20ma or less since it was built into and powered from a Maxon motor control module.
    Funny, seems when I give up and ask for help I work on it a little longer and find a solution.
    I'm using BEGIN ..... ATN@ UNTIL in the cog
    and stop it with ' NOP cogn ATN!
    Works just fine but I still don't know why cogn STOP does not.
    edited 2020-02-17 07:37
    Are you sure you are using STOP? I have COGSTOP which stops the cog directly (and completely), but no STOP.
    If you simply pasted the code in you should notice that it wasn't happy with STOP and prints out the ??? response.
    If you used the block mode TACHYON & END then after END it will issue a compile report and let you know that it found errors.
  • Are you sure you are using STOP? I have COGSTOP which stops the cog directly (and completely), but no STOP.
    I should have mentioned that I am using version 2.7. Maybe I should catch up.
    This is from the EXTEND for 2.7:
    { This is actually handled by STOP
    \ 03 0C 7C 0C | cogstop 6
    pub COGSTOP ( cog -- \ stop the COG with number cog 0..7 )
    9 SHL %000011_0001_1111_000000000_000000011 OR PASM DROP
    I don't even maintain a dedicated folder for anything before V3!!! Looks like 2.7 came out 4 years ago, that's forever ago in the lifetime of a Tachyon :)
    The early versions stilled used bytecode and from V4 it streamlined to wordcode which actually uses less memory in real applications and runs faster etc. V5 has been out for quite a while now and the kernel itself allows ROMS to be added to the upper EEPROM over the serial port. V5 also has a much faster dictionary search so that you can reduce the terminal line delay to almost zero.
    Here's the kernel source or you can load the complete binary instead.
  • Thanks. I will go ahead and load v5.
  • artkennedyartkennedy Posts: 174
    edited 2020-02-23 08:31
    I'm having some trouble loading version 5. It's been a long time since I've installed a new version.
    I edited TACHYON5v7.spin to change the baud rate to 230400. Loaded with the Prop Tool. Instead of the 'Ok' prompt there was "...". Is that as should be? Then I pasted from EXTENDv5.FTH and got a big jumble of words and ??? etc. I'm using TerraTerm. More help?
  • @artkennedy - The default "prompt" is just three dots but can be modified by the user and locked in. I have mine as "TF5>" for instance but the other two responses are the --> immediately after receiving an enter which is used to separate and make clear user input from machine output, especially when it is copied and pasted back into examples and the forum. The third response is the "ok" acknowledgement after the line has been executed.
    Here is a line from my terminal:
    TF5> 12 100 * . --- 1200  ok
    Note that I also changed my --> to a --- as this is also the same as a comment.
    As for EXTEND.FTH you should make sure that TeraTerm has its line delay set to a few milliseconds when pasting.
    In fact I just tried using Prop Tool on Windows to load the kernel and start it up, and then used TeraTerm with a line delay of 1ms (no handshake), and it complied perfectly. Before these recent improvements to Tachyon's compile speed, the line delay had to be set to a minimum of 8ms and usually 12ms.
    Note that if you have any ROMs loaded into upper EEPROM then they will still be there even after loading the kernel, since this only affects the lower 32k.
    BTW, The kernel is designed so that you don't need to change the baud rate there, except in special circumstances, but rather just change it at runtime using CONBAUD.
  • Many thanks. I am now up and running ( tentatively ) in 5v7.
    Antelopes are skeptical of changes in their cages. - Paul Simon
  • I know I am doing something wrong here - just can't seem to pin it down.
    Why all those 00's between the address for 'code' and the data?
    ... TABLE codes 160 ALLOT --> ok
    ... $00FB || $A66C || $00FB || $A664 ||
    ... $00FB || $A66A || $00FB || $A662 ||
    ... $00FB || $A669 || $00FB || $A661 ||
    ... $00FB || $A66D || $00FB || $A665 ||
    ... $00FB || $A66B || $00FB || $A663 ||
    ... $0045 || $1533 || $0045 || $153C ||
    ... $0045 || $15C3 || $0045 || $15CC ||
    ... $0045 || $1703 || $0045 || $170C ||
    ... $0045 || $1D03 || $0045 || $1D0C ||
    ... $0045 || $1503 || $0045 || $150C ||
    ... $0001 || $153C || $0001 || $153C ||
    ... $0001 || $150C || $0001 || $150C ||
    ... $0001 || $150F || $0001 || $150F ||
    ... $0001 || $1530 || $0001 || $1530 ||
    ... $0001 || $1533 || $0001 || $1533 ||
    ... $00C5 || $1761 || $00C5 || $1761 ||
    ... $00C5 || $1762 || $00C5 || $1762 ||
    ... $00C5 || $1764 || $00C5 || $1764 ||
    ... $00C5 || $1768 || $00C5 || $1768 ||
    ... ' codes 384 DUMP -->
    0000.3C88: A0 80 7C 06 5A 00 5A 00 01 7D D4 00 5A 00 5A 00
    0000.3C98: 5A 00 5A 00 00 00 00 00 00 00 00 00 00 00 00 00
    0000.3CA8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    0000.3CB8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    0000.3CC8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    0000.3CD8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    0000.3CE8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    0000.3CF8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    0000.3D08: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    0000.3D18: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    0000.3D28: FB 00 6C A6 FB 00 64 A6 FB 00 6A A6 FB 00 62 A6
    0000.3D38: FB 00 69 A6 FB 00 61 A6 FB 00 6D A6 FB 00 65 A6
    0000.3D48: FB 00 6B A6 FB 00 63 A6 45 00 33 15 45 00 3C 15
    0000.3D58: 45 00 C3 15 45 00 CC 15 45 00 03 17 45 00 0C 17
    0000.3D68: 45 00 03 1D 45 00 0C 1D 45 00 03 15 45 00 0C 15
    0000.3D78: 01 00 3C 15 01 00 3C 15 01 00 0C 15 01 00 0C 15
    0000.3D88: 01 00 0F 15 01 00 0F 15 01 00 30 15 01 00 30 15
    0000.3D98: 01 00 33 15 01 00 33 15 01 00 3C 15 01 00 3C 15
    0000.3DA8: C5 00 61 17 C5 00 61 17 C5 00 62 17 C5 00 62 17
    0000.3DB8: C5 00 64 17 C5 00 64 17 C5 00 68 17 C5 00 68 17
    0000.3DC8: 00 80 86 3C 80 81 44 0B 5A 00 5A 00 00 00 00 00
    0000.3DD8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    0000.3DE8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    0000.3DF8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  • MJBMJB Posts: 1,235
    edited 2020-02-28 22:27
    artkennedy wrote: »
    you told it so
    you do not have to do the ALLOT here.
    What it does is just allot 160 bytes which are mostly $00 and then compile the data.
    Actually the first few bytes is 'garbage' from the compilation process, which will be overwritten by ||
    if you omit the ALLOT.
    so just remove the 160 ALLOT and you are fine.
    You do not have to specify the size.
    || compiles words one after the other.
  • MJB wrote: »
    artkennedy wrote: »
    you told it so
    That is what I was using in 2v7 and it worked fine. I tried it in 5v7 and it was funky. I tried using 160 ALLOT to fix the probs. Now it's good. Maybe something was corrupt at the time. Thanks again.
