Spin2 - Page 14 — Parallax Forums
Spin2
11214161718
  • RaymanRayman Posts: 13,852
    edited 2020-02-11 15:04
    Sorry, one more thing... Is there a list of the Spin2 operators somewhere?
    I thought that "=>" was going to change to ">=", like C++, but I think Fastspin didn't make this change, so I wonder about Spin2...
    Also, I'm getting an error on this:
    value := ||(value+x)
    So, I think absolute value operator has changed...
    I found the 2018 proposed operators here: https://forums.parallax.com/discussion/166416/spin2-operator-syntax/p17
    Seems || is now ABS...
    BTW: Maybe it is a good idea to keep variables separate...
    After changing "x" to "x99" in my assembly code, I got an error here:
    PUB  CreateP1TvColors()|i,x,p,y,r,g,b 'create colors used by graphics demo, starting at index #128
        repeat i from 0 to 14
            x:=((i+4)&$F)*$10 + $C 'mid brightness colors that start and green and run through yellow, red, purple, blue and then back to green
            repeat j from 0 to 256
    The variable "j" was being used without being declared as a local variable.
    So, I guess it was using the long declared in the assembly block.
    Actually, once that assembly driver is started, maybe this is perfectly fine.
    Perhaps I should have gone the other route and just not defined i,j,k,x,y etc as local and just left them in the assembly code :)
  • Rayman wrote: »
    This syntax is not recognized by Fastspin:
        pinclear(av_base_pin_ addpins 4)
    Wouldn't that be better with commas?
    "addpins" is one of the new operators, and it's recognized by fastspin 4.1.3. "av_basepin_ addpins 4" is the same as "av_basepin_ | (4<<6)". This may be a case where having a lot of operators obscures what's going on.
    edited 2020-02-11 14:51
    I'm glad to see chip using 297 MHz clock in these demos.
    That's what I'm using, but I spent an hour or so deliberating whether or not this is a good idea...
    I might have to take a heat gun to it and see if this is going to work if the AC goes out during summer time...
    Is "result" no longer a Spin keyword?
    I copied over a "DEC" routine from Spin1 that has this in it:
          result~~                                          'flag non-zero found
        elseif result or i == 1
    Gives me an error in Spin2....
    edited 2020-02-11 15:25
    Yeah! I got my 1551 ling long driver file to compile.
    Now, I have to work on the top file...
    Spin2 does not like how I include "smartserial" in my OBJ section:
    OBJ
        VGA : "1080p_TileDriver_3n.spin2"  'Note:  You must set the fclk constant in this file to match _clkfreq
        gr  : "Graphics2b.spin2"
        usb1: "OneCogKbM_rja2b"   'Note:  You must change basepin and _FCLKFREQ settings in this file to match your setup
        ser: "spin/SmartSerial"
    It also doesn't like me putting the ".spin2" in the filenames...
    Is there no CogNew in Spin2?
    I get an error on this:
    okay := cog := cognew(@loop, @command) + 1
    I see the example does this:
    okay := cog := coginit(16, @driver, @background0_) + 1
    I guess the "16" means use the next free cog?
  • JRetSapDoogJRetSapDoog Posts: 954
    edited 2020-02-11 16:02
    Rayman wrote: »
    You've probably found them by now, but I saw a .txt file attachment with the operators in Chip's 2020-2-9 15:28:40 post a couple pages back. And I think that file is in the latest zip file, too.
    Thanks, I think Chip just added this and some other things to the latest .zip file.
    Does spin2 support preprocessor commands?
    I'm getting an error in garryj's USB code on this line:
    #ifndef USB_PORTB ' PortA is the default.
    edited 2020-02-11 18:14
    Minor note: FastSpin will let you redefine a constant later on but Spin will not...
    I had two instances of this:
    USB_V2MODE     = %1_11011_0 + 1 << 16 ' In P2 silicon v2 all USB smart pin modes are consolidated to %11011.
    This might be trouble:
    ' USB CRC constants:
            USB5_POLY      = %0_0101 >< 5           ' USB5 polynomial is reflected when calculating CRC
            USB5_RESIDUAL  = %0_1100 >< 5           ' Expected CRC5 residual value when checking received data
            USB16_POLY     = $8005 >< 16            ' USB16 polynomial is reflected when calculating CRC
            USB16_RESIDUAL = $800d >< 16            ' Expected CRC16 residual value when checking received data
    Hope REV is same as ><
    edited 2020-02-11 18:29
    I'm not sure why I'm getting this error in the USB code (attached).
    I guess you can't use . labels in hubexec?
    Strange... I replace the DJNZ with sub wz and if_nz jmp and its ok with that. These are the same, right?
                    'djnz    htmp2, #.loop  'PNUT doesn't like this?
                    sub     htmp2,#1 wz
            if_nz   jmp     #.loop
    568 x 539 - 29K
  • REV is not the same as ><. "x REV y" is the same as "x >< (y+1)", if I remember correctly.
    It's not liking "dirl_" either:
        dirl_(USB_EVENT_REPO)                               ' DIR bit low puts smart pin in reset mode
        wrpin_(SP_REPO1_MODE, USB_EVENT_REPO)               ' Set "long repository" mode to act as an event mailbox
        dirh_(USB_EVENT_REPO)                               ' Enable the event mailbox smart pin (will raise IN)
    What to do here?
  • garryjgarryj Posts: 337
    edited 2020-02-11 18:36
    Edit: "x REV (y - 1)" is the same as "x >< y".
  • "pinfloat" will set the direction to low (like dirl_) and "pinlow" will set the direction to high (like dirh_). Use just plain "wrpin" instead of "wrpin_". fastspin 4.1.3 should accept all of those.
    edited 2020-02-11 19:02
    Thanks, it took that.
    Spin2 doesn't seem to like this:
    PUB str(s = string("")) | c
    Doesn't like waitx() either:
    waitx(1000) ' wait to settle
    Think this might be waitct
    Anybody know how to do inline assembly in Spin2?
    ASM..ENDASM doesn't seem to work...
    Skipping Smartserial integration for now...
    I thought it would compile now, but I get this (attached image).
    No idea what to do about that...
    600 x 309 - 18K
    Rayman wrote: »
    PUB go() | i
      repeat
    	org
    _ret_	add	i,#1
    	end
        pinwrite(56 addpins 7, !i)
        waitms(100)
    Rayman wrote: »
    In Spin2, there are three waits:
    WAITCT(ct_target)
    WAITUS(microseconds)
    WAITMS(milliseconds)
    There is also:
    POLLCT(ct_target) 'returns true if past ct_target
    Rayman wrote: »
    What to do here?
    There are register variables, same as in PASM: DIRA/DIRB/OUTA/OUTB/INA/INB.
    WRPIN/WXPIN/WYPIN/etc can be used in Spin2, as well as in PASM.
    Here are some files to reproduce the "Invalid Object File" error.
    Graphics2c_Spin2.spin2 compiles OK
    The barebones file that calls it "GraphicsTest1a.spin2" gives this error message...
    Rayman, I'm looking it over now. I'm getting the same error, of course. I'll figure out the problem.
    Okay. It's finding constant symbols that start with underscores, and for some reason I disallowed this in the object interface. I can't remember why. Let me change this...
    Rayman, here is PNut_v34b. This compiles your program:
    https://drive.google.com/file/d/1HWnhswX2fd3W9H1gYSFqNeWToBMO7N7T/view?usp=sharing
    Is "test" reserved or something? Got a "expected unique variable name" error on this:
     long  test
    edited 2020-02-12 01:38
    I guess you can't do this:
    b := data.byte[0]
    or this
    x := ~byte[@data][1]           '~data.byte[1]
    Also, looks like to call a function that returns multiple results, you shouldn't put them in parenthesis like this does:
    (ptr, val) := usb1.getDebugInfo()
    Interesting... I commented out a "case" and now it gives me a "block is empty" error
        other:
          'ser.printf("Event%u: %u\n", portnum, event)
    All right, I finally got it to compile my 1080p code...
    Didn't work though.
    First problem seems to be with the clock setting...
    Got VGA output after changing this part:
    CON  'RJA:  new for real P2 - you can use different xdiv and xmul to set clock frequency:  /10*125 -> 250 MHz
      _XTALFREQ     = 20_000_000                                    ' crystal frequency
      _XDIV         = 20                                            ' crystal divider to give 1MHz
      _XMUL         = 297                                          ' crystal / div * mul
      _XDIVP        = 1                                             ' crystal / div * mul /divp to give _CLKFREQ (1,2,4..30)
      _XOSC         = %10                                  'OSC    ' %00=OFF, %01=OSC, %10=15pF, %11=30pF
      _XSEL         = %11                                   'XI+PLL ' %00=rcfast(20+MHz), %01=rcslow(~20KHz), %10=XI(5ms), %11=XI+PLL(10ms)
      _XPPPP        = ((_XDIVP>>1) + 15) & $F                       ' 1->15, 2->0, 4->1, 6->2...30->14
      _CLOCKFREQ    = _XTALFREQ / _XDIV * _XMUL / _XDIVP            ' internal clock frequency
      _SETFREQ      = 1<<24 + (_XDIV-1)<<18 + (_XMUL-1)<<8 + _XPPPP<<4 + _XOSC<<2  ' %0000_000e_dddddd_mmmmmmmmmm_pppp_cc_00  ' setup  oscillator
      _ENAFREQ      = _SETFREQ + _XSEL                                             ' %0000_000e_dddddd_mmmmmmmmmm_pppp_cc_ss  ' enable oscillator
      _clkmode = _SETFREQ
      _clkfreq = _CLOCKFREQ
      ''NOTE:  You must manually change clock freq in both mouse and VGA drivers to match the above.
    CON _clkfreq = 297_000_000
    and also removing this:
        'First, set the clock
        'clkset(_clkmode, _clkfreq)
        'waitct(clkfreq*3)'waitcnt(clkfreq + cnt*3)
    edited 2020-02-12 02:33
    Rayman, there are ways of achieving all these things in the PNut version of Spin2.
    byte[base][index] 'look up a byte
    To set up the clock, you only need to specify:
    CON _clkfreq = 250_000_000 'assumes 20MHz crystal if no _xtlfreq specified
    CON _xtlfreq = 16_000_000 'if your crystal frequency is not 20MHz, specify _xtlfreq
    The compiler will pick the optimal PLL setting for you. You can see what it is in your code by using the constant clkmode_ and clkfreq_. Also Ctrl-L shows it.
    And TEST is a PASM instruction, so it is a reserved word.
    Until I get the documentation together for Spin2, there will be some ambiguities.
