Code for multiple COGs in a single .spin file ?
I can write multiple pasm section and launch them into several cogs like this and it compiles, don't know if it runs yet:
PUB Main
    cognew(@CODE1, 0)
    cognew(@CODE2, 1)
' 1st COG code
DAT
                    org     0
CODE1
                    ' code here
var1 long 0
' 2nd COG code
                    org     0
CODE2
                   ' code here
var2 long 0
Will this work?
How does the cognew() know how much code to load to the cogs?
Or does this result in each cog having all the code?
  • Yes, this should work.
    COGNEW always loads 496 longs of code. If your code is shorter, it'll just load whatever comes after into the remaining registers.
  • Ah, now I see. So it doesn't matter if the all cog code is longer than 496 bytes, loading starts from the address specified and anything that does not fit is effectively ignored. Thanks.
