Streamer and hub RAM FIFO question
ManAtWork
in Propeller 2
As read in the docs the hub RAM interface has a FIFO that can be used only for one purpose at a time. So if I'd like to make an object which doesn't launch it's own cog but can be called from any spin function then the FIFO is already used up by instruction fetching. So I can't use the streamer (in RDFAST/WRFAST mode) to transfer data from a smartpin to hub ram or vice versa. However, I could use the streamer in immediate mode to output a bit pattern up to 32 bits at a time and use RDLONG in a loop.
Is this assumption correct? (I'm using FlexGui with fastspin and inline assembly at the moment. Interpreted Spin2 would probably be different as the interpreter runs in a cog and the FIFO is free)
