Recommendations for Force sensing devices?
 frank freedman
frank freedman
                    Need recommendations or suggestions for force/pressure sensing part in the range of 0-200 pounds range. The plan is to be able to monitor a standing load for shifts in position and then acting on the amount of shift greater than a certain difference from the initial set (is ballanced or reasonably distributed) across 4 or more points.
Sorry if this seems like a repeat of the last question, but thought I would ask in a more open ended way to see what others have done for this sort of measurement.
ff
ff
https://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=FX19&DocType=DS&DocLang=English
I thought I saw an I2C version somewhere but it may have been a different company. Similar price.
I used that load cell with their HX711 module and a Prop(examples probably in obex) and it worked great. pretty simple stuff to use.
