Propeller Platform 2
Rayman
in Propeller 2
I'm thinking about making a Propeller Platform compatible board for P2.
Just toying with the idea for now. I do have a Shield that I'd like to test with P2 though...
Looks like I make a 5" wide board that includes stuff from my existing layout (and, more importantly, stainless stencil) on the right hand side.
Years ago, I thought the header would be for all 64 I/O pins.
But now, I think I'll just connect the lower 32 pins to it.
Turns out the upper 32 pins are just enough for:
12 - HyperRam
4 - uSD
4 - Flash
2 - Serial
2 - USB
8 - HDMI
12 - HyperRam
4 - uSD
4 - Flash
2 - Serial
2 - USB
8 - HDMI
I do like the RPi zero and zero W...
I thought about that this week. I recently built an app for the Pi (Using .NET Core) that accepts E1.31 data and send it to my USB based Prop1 DMX dongle. It was then that I noticed the enclosure I purchased for my DMX dongle has the same dimensions of the enclosure for my Pi3. (I think the board is the same size too. I designed it for the enclosure.)
That lead me to think that a P2 in a Pi form factor would be great! Power it with the USB in. Mini HDMI out the side, Ethernet and USB on the front. Pinouts inside that match the Pi for GPIOs. It would be very cool! Lots of Pi hats and enclosures available at rock bottom prices.
We make a board with RPi layout so can use RPi hats.
I'll look into this...
