fastspin compiler for P2: Assembly, Spin, BASIC, and C in one compiler
13031333536
  • Might be useful to identify different callers. I have not used it either.
  • Rayman wrote: »
    What is ptrb useful for, in this context?
    It could be useful for finding hub data or buffer addresses if you don't know where in hub the code was (for position independent code). For example, you could do something like:
        org 0
    entry
        add ptrb, ##(@data - @entry)
        rdlong a, ptrb[0]
        rdlong b, ptrb[1]
        orgh
    data
        long initial_a, initial_b
    That snippet of code could be loaded off disk into any part of RAM and still work if launched with coginit, whereas traditionally code gets compiled to run from a specific HUB address (usually 0).
    That may end up being important for micropython, where the COG code gets loaded at run time and we may not be able to select where in memory it's going.
    FlexGUI, a GUI for programming the P1 and P2 in Spin, PASM, BASIC, and C.
    Help support its development at Patreon or PayPal.
  • Dave HeinDave Hein Posts: 5,981
    edited 2019-12-09 - 18:19:34
    Rayman wrote: »
    ptrb could be used as a base register for the beginning of code. This might be useful for position-independent-code (PIC) that could be executed from anywhere in memory.
    EDIT: I see that Eric had already posted the same thing. I should have read the next page of comments before posting. PIC is useful for operating systems where there might be multiple applications running at the same time.
  • Interesting...
    It just occurred to me that a cog could use ptrb to modify it's own code in the hub and then restart itself...
    Still, wouldn't it be more useful to have 3 arguments in cognew with the third being what goes in PTRB?
    Prop Info and Apps: http://www.rayslogic.com/
  • Rayman wrote: »
    Loading the LUT.
    Formerly known as TonyB
  • Rayman wrote: »
    Interesting...
    What goes into ptrb is controlled by the hardware coginit instruction, which automatically puts the hub address of the code being executed into ptrb. We can't change that without changing the silicon.
  • oh, right...
  • :D
    "Those who think we are powerless to do anything about the greenhouse effect forget about the 'White House effect,'" - George H.W. Bush, 1988.
  • RaymanRayman Posts: 10,054
    edited 2019-12-13 - 14:23:23
    Is there an easy way to find the end of program in HUB memory with Fastspin?
    Say I want to create a heap that starts at the end of the code...
    How can I find that point?
    If I make a DAT label at the bottom of the main .spin2 file, will that wind up on the bottom of the code?
  • Rayman wrote: »
    At first I was going to say that there's no way to do that. But actually there is, because the stack comes after the end of the program. So you can get the value in the stack pointer (ptra in P2) and add the size of stack you think you'll need to that.
  • Noob FastSPIN question.
    I'm in the process of porting some bit-banged I2C code from the P1 to the P2. Except the P2 just blasts this stuff out so fast that the I2C bus never even has a chance to swing rail-to-rail. So as a quick-and-dirty fix I wanted to kill some time between bits. Simple, right? So I stuffed some NOPs into the Spin code figuring I'm good to go... except that while NOP is indeed a reserved word in FastSPIN, there apparently isn't actually a NOP in Spin? It throws a "error: Unknown symbol NOP".
    Assuming the above assumption is correct, what then is the preferred instruction/method to just to kill a few clock cycles? (I'm really hoping I don't have to call a separate timing routine between bits. Ugh).
    BTW: Slowing the clock down isn't an option. I've got a VGA driver running on two COGs that needs to be banging along at 160 mhz, minimum.
    edited 2019-12-15 - 18:00:41
    in assembly, use waitx
    waitx   #1000
    for 1000+2 clocks
    In Spin, use waitcnt
    waitcnt(cnt+clkfreq)
    for 1 second delay
  • JRoark wrote: »
    There's nothing wrong with showing your intent in code by calling a wait function. If you pass a variable (or constant) into the wait, it's much easier to change each instance in the future by changing one value. Alternative is let's say you have 10 nops. Still too fast? Have to seek out all of those and add more.
    The optimizer may even flatten the function call if it's just a waitx being passed a constant.
  • There is a NOP in assembly. Fastspin encapsulates both Spin and ASM programming.
  • WAITX ##1000
  • I was really looking for “quick and dirty” delays, but you guys are right: do it right the first time. So I did. But I was surprised that Spin2 doesnt have a NOP equivalent. Seems like for slash-and-burn coding it would be handy.
    Thanks to all for the suggestions and guidance!
  • You can embed pasm in spin...
    I think it’s like this:
    Asm
         Nop
    Endasm
  • Rayman wrote: »
    Asm
         Nop
    Endasm
    (-Bangs head on desk-)
    THAT was it! LOL!!! Now I know. :smiley: And like darned near everything else in the Flex suite, it was just that simple. And I missed it.
    Methinks I over-think these things...
  • Great!
    You can and a REP instruction in there to do as many NOPs as you like (I think).
  • The waitx # is probably better because it's only one instruction, doesn't require a label, and is measured in single clock ticks.
  • I think I've decided that inline assembly is the way to go for things like I2C, where you don't want to dedicate a cog, or maybe even if you do.
    Now I wonder... Why didn't Spin1 have inline assembly?
    I think Chip said that his Spin2 will also have inline assembly, hopefully compatible with FastSpin...
  • Rayman wrote: »
    Inline assembly may not even be necessary. Some famous computer scientist (I think it was Donald Knuth) once said that "Premature optimization is the root of all evil". For many purposes pure Spin code will work fine, particularly if it's compiled by fastspin to PASM. And Chip's Spin2 interpreter will be significantly faster than Spin1. So I would suggest first coding the driver in pure Spin (or C, or BASIC, or some other convenient high level language) and then only if there is in fact a performance issue worrying about optimizing inner loops with inline assembly. PASM is nice as assembly goes, but it's still not as nice as a high level language :).
  • Maybe that's true for fastspin…
    But, needs wrpin, which I don't think is part of Spin2.
    Also, want to be compatible with Chip's Spin2 (?).
  • whicker...
    The other BIG difference between the P2 and the P1is that everyone is going to be able to select their favorite system clock... So, you will want your i2c waitx ##_constant to be defined in terms of the clock frequency.
    something like: i2c_wait = ##_sysclock/100000.
    waitx i2c_wait
  • I just saw Chip's inline assembly...
    Looks the same as Fastspin, but starts with "org" and ends with "end".
    BTW: Looks like Chip's now has multiple return values. Thinking of doing that too?
  • Rayman wrote: »
    fastspin has had multiple return values for a long time now...
  • Inline assembly is a wonderful thing.
    Will really help people learn assembly.
    So easy in Spin2
  • jmgjmg Posts: 14,175
    Rayman wrote: »
    So easy in Spin2
    Yes. The other thing that helps a lot too, is good listing files from the compilers.
    Users can scan the created ASM code, and in many cases avoid needing in-line assembly.
    If they do need to in-line, they can cut/paste/tune the assembler bit that matters most.
    P2 is going to run mixed/multiple languages much more often than other MCUs, due to the isolated nature of each COG.
  • When using FlexGUI 4.0.5, under Win10 and coding in BASIC for the P2-EVAL rev B board:
    @ersmith It looks like there is a GUI issue when attempting to do a search (Edit->Find). Entering any search criteria gives this error:
    bad command "tag": must be configure, cget, invoke, instate, state, or identify
        while executing
    "$w tag ranges hilite"
        (procedure "searchrep'next" line 3)
        invoked from within
    "searchrep'next .toolbar.compile"
        invoked from within
    ".sr.bn invoke "
        invoked from within
    ".sr.bn instate !disabled { .sr.bn invoke } "
        invoked from within
    ".sr.bn instate pressed { .sr.bn state !pressed; .sr.bn instate !disabled { .sr.bn invoke } } "
        (command bound to event)
  • JRetSapDoogJRetSapDoog Posts: 834
    edited 2019-12-23 - 08:45:44
    Rayman wrote: »
    I've been searching the forum and my question seems to overlap with Ray's above, hence the quote.
    In my situation, I've got a bunch of font data in the hub. And *after* that, I've got some more (unrelated) data that is labeled at the beginning, like this:
    Tiles	byte	11, 3,10,10, 0,10, 3, 3, 2   '0
    	byte	 1,10, 0, 0,10, 0, 3, 3, 2   '1
    	byte	 3, 3,10,11, 3, 2, 3, 3, 2   '2
    	byte	 3, 3,10, 0, 3,10, 3, 3, 2   '3
    My question is: How do I get the starting address for the data labeled by Tiles? I can and am manually calculating the address of that data, such that I'm able to access it (and I just store the fixed, calculated address in a cog register for the cog that needs it). But to a PASM noobie like me, it's tempting to think that the assembler at compile time (or less likely, the language at run time) should be able to help with that, you know, to automatically provide the address. I did admittedly blindly try using single, double and triple @ prefixes with the Tiles label with various compile errors, but I didn't learn much from that.
    Perhaps I can handle it programmatically by making use of ptrb as mentioned above, but I haven't thought that through yet (sorry). If there's no (convenient) way to get the address, does anyone have an explanation to help me understand the "why" of it. I suppose that there's only so much that the compiler can do at compile time, and run time depends on actual code (that I supply) to do things, so maybe there's no mechanism to "bridge the gap," so to speak. Anyway, it just seems odd that, for example, if I add a third kind of data between my font data and the tiles data, that I'd need to recalculate the Tiles address. But perhaps I'm missing something or not designing things properly, hence I thought it was best to ask (to hopefully gain some insight).
