NTSC Spiral Demo - Now with HDMI and VGA output
cgracey
Here is a short program that displays a rotating spiral on an NTSC monitor via P16 (pin can be changed).
It uses the CORDIC for doing cartesian-to-polar conversion and the RGBI8 streamer mode for RGB-select with-5-bit intensity.
An MP4 is below.
Here is the code, NTSC driver first, then spiral program at the end:
An MP4 is below.
'* NTSC Spiral Demo *
DAT org
hubset ##%1_000001_0000011000_1111_10_00 'config PLL, 20MHz/2*25*1 = 250MHz
waitx ##20_000_000 / 200 'allow crystal+PLL 5ms to stabilize
hubset ##%1_000001_0000011000_1111_10_11 'switch to PLL
coginit #1,##@pgm_ntsc 'launch video cog
coginit #0,##@pgm_bmap 'launch bitmap cog
'* NTSC 256 x 192 x 8bpp rgbi8 *
CON
f_color = 3_579_545.0 'colorburst frequency
f_scanline = f_color / 227.5 'scanline frequency
f_pixel = f_scanline * 400.0 'pixel frequency for 400 pixels per scanline
f_clock = 250_000_000.0 'clock frequency
f_xfr = f_pixel / f_clock * float($7FFF_FFFF)
f_csc = f_color / f_clock * float($7FFF_FFFF) * 2.0
s = 84 'scale DAC output (s = 0..128)
r = s * 1000 / 1646 'precompensate for modulator expansion of 1.646
mody = ((+38*s/128) & $FF) << 24 + ((+75*s/128) & $FF) << 16 + ((+15*s/128) & $FF) << 8 + (110*s/128 & $FF)
modi = ((+76*r/128) & $FF) << 24 + ((-35*r/128) & $FF) << 16 + ((-41*r/128) & $FF) << 8 + (100*s/128 & $FF)
modq = ((+27*r/128) & $FF) << 24 + ((-67*r/128) & $FF) << 16 + ((+40*r/128) & $FF) << 8 + 128
video_pin = 16
ntsc_map = $1000
DAT org
' Setup
pgm_ntsc rdfast ##256*192/64,##ntsc_map 'set rdfast to wrap on bitmap
setxfrq ##round(f_xfr) 'set transfer frequency
setcfrq ##round(f_csc) 'set colorspace converter frequency
setcy ##mody 'set colorspace converter coefficients
setci ##modi
setcq ##modq
setcmod #%11_1_0000 'set colorspace converter to YIQ mode (composite)
cogid .x 'enable dac mode in pin
setnib .dacmode,.x,#2
wrpin .dacmode,#video_pin
drvl #video_pin
' Field loop
.field mov .x,#35 'top blanks
call #.blank
mov .x,#192 'set visible lines
.line call #.hsync 'do horizontal sync
xcont .m_rf,#0 'visible line
xcont .m_av,#1 'after visible spacer
djnz .x,#.line 'another line?
mov .x,#27 'bottom blanks
call #.blank
mov .x,#6 'high vertical syncs
.vlow xcont .m_hl,#2
xcont .m_hh,#1
djnz .x,#.vlow
mov .x,#6 'low vertical syncs
.vhigh xcont .m_ll,#2
xcont .m_lh,#1
djnz .x,#.vhigh
.vlow2 xcont .m_hl,#2
xcont .m_hh,#1
djnz .x,#.vlow2
jmp #.field 'loop
' Subroutines
.blank call #.hsync 'blank lines
xcont .m_vi,#0
xcont .m_av,#1
_ret_ djnz .x,#.blank
.hsync xcont .m_sn,#2 'horizontal sync
xcont .m_bc,#1
xcont .m_cb,.c_cb
_ret_ xcont .m_ac,#1
' Data
.dacmode long %0000_0000_000_1011100000000_01_00000_0
.m_sn long $7F010000+29 'sync
.m_bc long $7F010000+7 'before colorburst
.m_cb long $7F010000+18 'colorburst
.m_ac long $7F010000+40 'after colorburst
.m_vi long $7F010000+256 'visible
.m_av long $7F010000+50 'after visible (400 total)
.m_rf long $BF030000+256 'visible rfbyte 8bpp rgbi8
.m_hl long $7F010000+15 'vertical sync high low
.m_hh long $7F010000+185 'vertical sync high high (200 total)
.m_ll long $7F010000+171 'vertical sync low low
.m_lh long $7F010000+29 'vertical sync low high (200 total)
.c_cb long $507000_01 'colorburst reference color
.x res 1
.y res 1
'* Make spirals in 256 x 192 bitmap *
org
pgm_bmap wrfast ##256*192/64,##ntsc_map 'set wrfast to wrap on bitmap
.pixel mov .px,.x 'translate (x,y) to (x-256/2,y-192/2)
sub .px,#256/2
mov .py,.y
sub .py,#192/2
qvector .px,.py 'convert (x,y) to polar (rho,theta)
getqx .px
getqy .py
shr .py,#32-9 'get 9 MSBs of theta
add .py,.px 'add rho to twist it
add .py,.z 'add z to slowly spin it
mov .px,.py 'convert 6 LSBs to 5-bit up/down ramp
test .px,#$20 wc
if_c xor .px,#$3F
and .px,#$1F
shr .py,#1 'apply 3 MSBs to RGB bits
and .py,#$E0
or .px,.py
wfbyte .px 'write rgbi8 pixel to bitmap
incmod .x,#256-1 wc 'step x
if_c incmod .y,#192-1 wc 'step y
if_c add .z,#1 'step z
jmp #.pixel
.x long 0
.y long 0
.z res 1
.px res 1
.py res 1
I made three optimizations:
1) Overlapped the CORDIC instructions to get 16 pixels through at once
2) Used the LUT for fast lookup of RGBI8 pixel values
3) Unrolled the loop for 16 pixels at a time
Now, it's running 4.7 times as fast, so it's watchable.
'***************** '* HDMI Spiral * '***************** CON hdmi_base = 8 'must be a multiple of 8 freq = 250_000_000.0 'system clock frequency must be 250 MHz for HDMI fast = 1 '0 for small code (7.8 fps), 1 for fast code (36.6 fps) bitmap = $400 'HDMI bitmap (300 KB) DAT org hubset ##%1_000001_0000011000_1111_10_00 'config PLL, 20MHz/2*25*1 = 250MHz waitx ##20_000_000 / 200 'allow crystal+PLL 5ms to stabilize hubset ##%1_000001_0000011000_1111_10_11 'switch to PLL setq ##($7FFFF - @end_of_pgm)/4 'clear hub RAM wrlong #0,##@end_of_pgm coginit #2,##@pgm_hdmi 'launch HDMI coginit #0,##@pgm_bmap 'launch bitmap cog '********************************* '* HDMI 640 x 480 x 8bpp luma8 * '********************************* DAT org pgm_hdmi setcmod #$100 'enable HDMI mode drvl #7<<6 + hdmi_base 'enable HDMI pins wrpin ##%001001<<8,#7<<6 + hdmi_base 'set 1k-ohm drive on HDMI pins setxfrq ##$0CCCCCCC+1 'set streamer freq to 1/10th clk (25 MHz) rdfast ##640*480/64,##bitmap 'set rdfast to wrap on bitmap ' Field loop field mov hsync0,sync_000 'vsync off mov hsync1,sync_001 callpa #10,#blank 'top blanks mov i,#480 'set visible lines line call #hsync 'do horizontal sync xcont m_rf,#0 'do visible line djnz i,#line 'another line? callpa #33,#blank 'bottom blanks mov hsync0,sync_222 'vsync on mov hsync1,sync_223 callpa #2,#blank 'vertical sync blanks jmp #field 'loop ' Subroutines blank call #hsync 'blank lines xcont m_vi,hsync0 _ret_ djnz pa,#blank hsync xcont m_bs,hsync0 'horizontal sync xzero m_sn,hsync1 _ret_ xcont m_bv,hsync0 ' Data sync_000 long %1101010100_1101010100_1101010100_10 ' sync_001 long %1101010100_1101010100_0010101011_10 ' hsync sync_222 long %0101010100_0101010100_0101010100_10 'vsync sync_223 long %0101010100_0101010100_1010101011_10 'vsync + hsync m_bs long $70810000 + hdmi_base<<17 + 16 'before sync m_sn long $70810000 + hdmi_base<<17 + 96 'sync m_bv long $70810000 + hdmi_base<<17 + 48 'before visible m_vi long $70810000 + hdmi_base<<17 + 640 'visible m_rf long $B0830000 + hdmi_base<<17 + 640 'visible rfbyte luma8 i res 1 hsync0 res 1 hsync1 res 1 '************************************** '* Make spirals in 640 x 480 bitmap * '************************************** org pgm_bmap wrfast ##640*480/64,##bitmap 'set wrfast to wrap on bitmap modc fast * %1111 wc 'fast or slow code? if_nc jmp #.pixel ' Fast code (36.6 fps) 4.7x the speed of slow code .lut mov .px,.z 'make lookup table for fast translation test .px,#$20 wc 'convert 6 LSBs to 5-bit up/down ramp if_c xor .px,#$3F and .px,#$1F mov .py,.z shr .py,#1 'apply 3 MSBs to RGB bits and .py,#$E0 or .px,.py wrlut .px,.z incmod .z,#$1FF wc if_nc jmp #.lut .pixels qvector .x,.y '0 in do overlapped QVECTOR ops for 16 pixels add .x,#1 '1 in qvector .x,.y add .x,#1 '2 in qvector .x,.y add .x,#1 '3 in qvector .x,.y add .x,#1 '4 in qvector .x,.y add .x,#1 '5 in qvector .x,.y add .x,#1 '6 in qvector .x,.y add .x,#1 '7 in qvector .x,.y getqx .px+0 '0 out getqy .py+0 add .x,#1 '8 in qvector .x,.y getqx .px+1 '1 out getqy .py+1 add .x,#1 '9 in qvector .x,.y getqx .px+2 '2 out getqy .py+2 add .x,#1 '10 in qvector .x,.y getqx .px+3 '3 out getqy .py+3 add .x,#1 '11 in qvector .x,.y getqx .px+4 '4 out getqy .py+4 add .x,#1 '12 in qvector .x,.y getqx .px+5 '5 out getqy .py+5 add .x,#1 '13 in qvector .x,.y getqx .px+6 '6 out getqy .py+6 add .x,#1 '14 in qvector .x,.y getqx .px+7 '7 out getqy .py+7 add .x,#1 '15 in qvector .x,.y getqx .px+8 '8 out getqy .py+8 shr .py+0,#32-9 'get 9 MSBs of theta (stuff code between GETQx ops) add .py+0,.px+0 'add rho to twist it getqx .px+9 '9 out getqy .py+9 shr .py+1,#32-9 add .py+1,.px+1 getqx .px+10 '10 out getqy .py+10 shr .py+2,#32-9 add .py+2,.px+2 getqx .px+11 '11 out getqy .py+11 shr .py+3,#32-9 add .py+3,.px+3 getqx .px+12 '12 out getqy .py+12 shr .py+4,#32-9 add .py+4,.px+4 getqx .px+13 '13 out getqy .py+13 shr .py+5,#32-9 add .py+5,.px+5 getqx .px+14 '14 out getqy .py+14 shr .py+6,#32-9 add .py+6,.px+6 getqx .px+15 '15 out getqy .py+15 add .py+0,.z 'add z to slowly spin it rdlut .py+0,.py+0 'lookup rgbi8 color wfbyte .py+0 'write rgbi8 pixel to bitmap add .py+1,.z rdlut .py+1,.py+1 wfbyte .py+1 add .py+2,.z rdlut .py+2,.py+2 wfbyte .py+2 add .py+3,.z rdlut .py+3,.py+3 wfbyte .py+3 add .py+4,.z rdlut .py+4,.py+4 wfbyte .py+4 add .py+5,.z rdlut .py+5,.py+5 wfbyte .py+5 add .py+6,.z rdlut .py+6,.py+6 wfbyte .py+6 shr .py+7,#32-9 add .py+7,.px+7 add .py+7,.z rdlut .py+7,.py+7 wfbyte .py+7 shr .py+8,#32-9 add .py+8,.px+8 add .py+8,.z rdlut .py+8,.py+8 wfbyte .py+8 shr .py+9,#32-9 add .py+9,.px+9 add .py+9,.z rdlut .py+9,.py+9 wfbyte .py+9 shr .py+10,#32-9 add .py+10,.px+10 add .py+10,.z rdlut .py+10,.py+10 wfbyte .py+10 shr .py+11,#32-9 add .py+11,.px+11 add .py+11,.z rdlut .py+11,.py+11 wfbyte .py+11 shr .py+12,#32-9 add .py+12,.px+12 add .py+12,.z rdlut .py+12,.py+12 wfbyte .py+12 shr .py+13,#32-9 add .py+13,.px+13 add .py+13,.z rdlut .py+13,.py+13 wfbyte .py+13 shr .py+14,#32-9 add .py+14,.px+14 add .py+14,.z rdlut .py+14,.py+14 wfbyte .py+14 shr .py+15,#32-9 add .py+15,.px+15 add .py+15,.z rdlut .py+15,.py+15 wfbyte .py+15 incmod .x,#640/2-1 wc 'check if x at limit if_c neg .x,#640/2 if_c incmod .y,#480/2-1 wc 'step y if_c neg .y,#480/2 if_c sub .z,#1 'step z if_c drvnot #56 'toggle P56 for speed check jmp #.pixels ' Slow code (7.8 fps) .pixel qvector .x,.y 'convert (x,y) to polar (rho,theta) getqx .px getqy .py shr .py,#32-9 'get 9 MSBs of theta add .py,.px 'add rho to twist it add .py,.z 'add z to slowly spin it mov .px,.py 'convert 6 LSBs to 5-bit up/down ramp test .px,#$20 wc if_c xor .px,#$3F and .px,#$1F shr .py,#1 'apply 3 MSBs to RGB bits and .py,#$E0 or .px,.py wfbyte .px 'write rgbi8 pixel to bitmap incmod .x,#640/2-1 wc 'step x if_c neg .x,#640/2 if_c incmod .y,#480/2-1 wc 'step y if_c neg .y,#480/2 if_c sub .z,#1 'step z if_c drvnot #56 'toggle P56 for speed check jmp #.pixel ' Data .x long -640/2 .y long -480/2 .z long 0 .px res 16 .py res 16 end_of_pgmThe NTSC works fine, but I am not able to get any of your recent hdmi samples to run... two different cables two different Visio monitors.
Signal not detected.
I have no 640x480 but 800x600 wirks jest fin.
Adjust the kaleidoscope constant for interesting effects. 22 is also good
'***************** '* HDMI Spiral * '***************** CON hdmi_base = 24 'must be a multiple of 8 freq = 250_000_000.0 'system clock frequency must be 250 MHz for HDMI fast = 1 '0 for small code (7.8 fps), 1 for fast code (36.6 fps) bitmap = $400 'HDMI bitmap (300 KB) kaleidoscope = 18 DAT org hubset ##%1_000001_0000011000_1111_10_00 'config PLL, 20MHz/2*25*1 = 250MHz waitx ##20_000_000 / 200 'allow crystal+PLL 5ms to stabilize hubset ##%1_000001_0000011000_1111_10_11 'switch to PLL setq ##($7FFFF - @end_of_pgm)/4 'clear hub RAM wrlong #0,##@end_of_pgm coginit #2,##@pgm_hdmi 'launch HDMI coginit #0,##@pgm_bmap 'launch bitmap cog '********************************* '* HDMI 640 x 480 x 8bpp luma8 * '********************************* DAT org pgm_hdmi setcmod #$100 'enable HDMI mode drvl #7<<6 + hdmi_base 'enable HDMI pins wrpin ##%001001<<8,#7<<6 + hdmi_base 'set 1k-ohm drive on HDMI pins setxfrq ##$0CCCCCCC+1 'set streamer freq to 1/10th clk (25 MHz) rdfast ##640*480/64,##bitmap 'set rdfast to wrap on bitmap ' Field loop field mov hsync0,sync_000 'vsync off mov hsync1,sync_001 callpa #10,#blank 'top blanks mov i,#480 'set visible lines line call #hsync 'do horizontal sync xcont m_rf,#0 'do visible line djnz i,#line 'another line? callpa #33,#blank 'bottom blanks mov hsync0,sync_222 'vsync on mov hsync1,sync_223 callpa #2,#blank 'vertical sync blanks jmp #field 'loop ' Subroutines blank call #hsync 'blank lines xcont m_vi,hsync0 _ret_ djnz pa,#blank hsync xcont m_bs,hsync0 'horizontal sync xzero m_sn,hsync1 _ret_ xcont m_bv,hsync0 ' Data sync_000 long %1101010100_1101010100_1101010100_10 ' sync_001 long %1101010100_1101010100_0010101011_10 ' hsync sync_222 long %0101010100_0101010100_0101010100_10 'vsync sync_223 long %0101010100_0101010100_1010101011_10 'vsync + hsync m_bs long $70810000 + hdmi_base<<17 + 16 'before sync m_sn long $70810000 + hdmi_base<<17 + 96 'sync m_bv long $70810000 + hdmi_base<<17 + 48 'before visible m_vi long $70810000 + hdmi_base<<17 + 640 'visible m_rf long $B0830000 + hdmi_base<<17 + 640 'visible rfbyte luma8 i res 1 hsync0 res 1 hsync1 res 1 '************************************** '* Make spirals in 640 x 480 bitmap * '************************************** org pgm_bmap wrfast ##640*480/64,##bitmap 'set wrfast to wrap on bitmap modc fast * %1111 wc 'fast or slow code? if_nc jmp #.pixel ' Fast code (36.6 fps) 4.7x the speed of slow code .lut mov .px,.z 'make lookup table for fast translation test .px,#$20 wc 'convert 6 LSBs to 5-bit up/down ramp if_c xor .px,#$3F and .px,#$1F mov .py,.z shr .py,#1 'apply 3 MSBs to RGB bits and .py,#$E0 or .px,.py wrlut .px,.z incmod .z,#$1FF wc if_nc jmp #.lut .pixels qvector .x,.y '0 in do overlapped QVECTOR ops for 16 pixels add .x,#1 '1 in qvector .x,.y add .x,#1 '2 in qvector .x,.y add .x,#1 '3 in qvector .x,.y add .x,#1 '4 in qvector .x,.y add .x,#1 '5 in qvector .x,.y add .x,#1 '6 in qvector .x,.y add .x,#1 '7 in qvector .x,.y getqx .px+0 '0 out getqy .py+0 add .x,#1 '8 in qvector .x,.y getqx .px+1 '1 out getqy .py+1 add .x,#1 '9 in qvector .x,.y getqx .px+2 '2 out getqy .py+2 add .x,#1 '10 in qvector .x,.y getqx .px+3 '3 out getqy .py+3 add .x,#1 '11 in qvector .x,.y getqx .px+4 '4 out getqy .py+4 add .x,#1 '12 in qvector .x,.y getqx .px+5 '5 out getqy .py+5 add .x,#1 '13 in qvector .x,.y getqx .px+6 '6 out getqy .py+6 add .x,#1 '14 in qvector .x,.y getqx .px+7 '7 out getqy .py+7 add .x,#1 '15 in qvector .x,.y getqx .px+8 '8 out getqy .py+8 shr .py+0,#32-kaleidoscope 'get 9 MSBs of theta (stuff code between GETQx ops) add .py+0,.px+0 'add rho to twist it getqx .px+9 '9 out getqy .py+9 shr .py+1,#32-kaleidoscope add .py+1,.px+1 getqx .px+10 '10 out getqy .py+10 shr .py+2,#32-kaleidoscope add .py+2,.px+2 getqx .px+11 '11 out getqy .py+11 shr .py+3,#32-kaleidoscope add .py+3,.px+3 getqx .px+12 '12 out getqy .py+12 shr .py+4,#32-kaleidoscope add .py+4,.px+4 getqx .px+13 '13 out getqy .py+13 shr .py+5,#32-kaleidoscope add .py+5,.px+5 getqx .px+14 '14 out getqy .py+14 shr .py+6,#32-kaleidoscope add .py+6,.px+6 getqx .px+15 '15 out getqy .py+15 add .py+0,.z 'add z to slowly spin it rdlut .py+0,.py+0 'lookup rgbi8 color wfbyte .py+0 'write rgbi8 pixel to bitmap add .py+1,.z rdlut .py+1,.py+1 wfbyte .py+1 add .py+2,.z rdlut .py+2,.py+2 wfbyte .py+2 add .py+3,.z rdlut .py+3,.py+3 wfbyte .py+3 add .py+4,.z rdlut .py+4,.py+4 wfbyte .py+4 add .py+5,.z rdlut .py+5,.py+5 wfbyte .py+5 add .py+6,.z rdlut .py+6,.py+6 wfbyte .py+6 shr .py+7,#32-kaleidoscope add .py+7,.px+7 add .py+7,.z rdlut .py+7,.py+7 wfbyte .py+7 shr .py+8,#32-kaleidoscope add .py+8,.px+8 add .py+8,.z rdlut .py+8,.py+8 wfbyte .py+8 shr .py+9,#32-kaleidoscope add .py+9,.px+9 add .py+9,.z rdlut .py+9,.py+9 wfbyte .py+9 shr .py+10,#32-kaleidoscope add .py+10,.px+10 add .py+10,.z rdlut .py+10,.py+10 wfbyte .py+10 shr .py+11,#32-kaleidoscope add .py+11,.px+11 add .py+11,.z rdlut .py+11,.py+11 wfbyte .py+11 shr .py+12,#32-kaleidoscope add .py+12,.px+12 add .py+12,.z rdlut .py+12,.py+12 wfbyte .py+12 shr .py+13,#32-kaleidoscope add .py+13,.px+13 add .py+13,.z rdlut .py+13,.py+13 wfbyte .py+13 shr .py+14,#32-kaleidoscope add .py+14,.px+14 add .py+14,.z rdlut .py+14,.py+14 wfbyte .py+14 shr .py+15,#32-kaleidoscope add .py+15,.px+15 add .py+15,.z rdlut .py+15,.py+15 wfbyte .py+15 incmod .x,#640/2-1 wc 'check if x at limit if_c neg .x,#640/2 if_c incmod .y,#480/2-1 wc 'step y if_c neg .y,#480/2 if_c sub .z,#1 'step z if_c drvnot #56 'toggle P56 for speed check jmp #.pixels ' Slow code (7.8 fps) .pixel qvector .x,.y 'convert (x,y) to polar (rho,theta) getqx .px getqy .py shr .py,#32-16 'get 9 MSBs of theta add .py,.px 'add rho to twist it add .py,.z 'add z to slowly spin it mov .px,.py 'convert 6 LSBs to 5-bit up/down ramp test .px,#$20 wc if_c xor .px,#$3F and .px,#$1F shr .py,#1 'apply 3 MSBs to RGB bits and .py,#$E0 or .px,.py wfbyte .px 'write rgbi8 pixel to bitmap incmod .x,#640/2-1 wc 'step x if_c neg .x,#640/2 if_c incmod .y,#480/2-1 wc 'step y if_c neg .y,#480/2 if_c sub .z,#1 'step z if_c drvnot #56 'toggle P56 for speed check jmp #.pixel ' Data .x long -640/2 .y long -480/2 .z long 0 .px res 16 .py res 16 end_of_pgmThis is a fun little demo Chip!
Here you go:
'**************** '* VGA Spiral * '**************** CON vga_base = 8 'must be a multiple of 8 intensity = 90 '0..128 fclk = 320_000_000.0 fpix = 25_000_000.0 fset = (fpix / fclk * 2.0) * float($4000_0000) fast = 1 '0 for small code (10 fps), 1 for fast code (47 fps) bitmap = $400 'rgbi8 bitmap (300 KB) DAT org hubset ##%1_000000_0000001111_1111_10_00 'config PLL, 20MHz/1*16*1 = 320MHz waitx ##20_000_000 / 100 'allow crystal+PLL 10ms to stabilize hubset ##%1_000000_0000001111_1111_10_11 'switch to PLL coginit #1,##@pgm_vga 'launch vga coginit #0,##@pgm_bmap 'launch bitmap cog '******************************** '* VGA 640 x 480 x 8bpp rgbi8 * '******************************** DAT org pgm_vga setxfrq ##round(fset) 'set transfer frequency to fpix setcy ##intensity << 24 'r set colorspace for rgb setci ##intensity << 16 'g setcq ##intensity << 08 'b setcmod #%01_0_000_0 'enable colorspace conversion wrpin dacmode_hsy,#0<<6 + vga_base + 0 'enable dac mode in pin 0 for hsync wrpin dacmode_rgb,#2<<6 + vga_base + 1 'enable dac modes in pins 1..3 for rgb drvl #3<<6 + vga_base 'enable dac outputs rdfast ##640*480/64,##bitmap 'set rdfast to wrap on bitmap ' Field loop field callpa #10,#blank 'top blanks mov i,#480 'set visible lines line call #hsync 'do horizontal sync xcont m_rf,#0 'do visible line djnz i,#line 'another line? callpa #33,#blank 'bottom blanks drvnot #vga_base+4 'vsync on callpa #2,#blank 'vsync blanks drvnot #vga_base+4 'vsync off jmp #field 'loop ' Subroutines blank call #hsync 'blank lines xcont m_vi,#0 _ret_ djnz pa,#blank hsync xcont m_bs,#0 'horizontal sync xzero m_sn,#1 _ret_ xcont m_bv,#0 ' Data dacmode_hsy long %0000_0000_000_1011000000001_01_00000_0 '123-ohm 3.3V, cog 1 dac channels dacmode_rgb long %0000_0000_000_1011100000001_01_00000_0 '75-ohm 2.0V, cog 1 dac channels m_bs long $7F010000 + 16 'before sync m_sn long $7F010000 + 96 'sync m_bv long $7F010000 + 48 'before visible m_vi long $7F010000 + 640 'visible m_rf long $BF030000 + 640 'visible rfbyte rgbi8 i res 1 '************************************** '* Make spirals in 640 x 480 bitmap * '************************************** org pgm_bmap wrfast ##640*480/64,##bitmap 'set wrfast to wrap on bitmap modc fast * %1111 wc 'fast or slow code? if_nc jmp #.pixel ' Fast code (47 fps) 4.7x the speed of slow code .lut mov .px,.z 'make lookup table for fast translation test .px,#$20 wc 'convert 6 LSBs to 5-bit up/down ramp if_c xor .px,#$3F and .px,#$1F mov .py,.z shr .py,#1 'apply 3 MSBs to RGB bits and .py,#$E0 or .px,.py wrlut .px,.z incmod .z,#$1FF wc if_nc jmp #.lut .pixels qvector .x,.y '0 in do overlapped QVECTOR ops for 16 pixels add .x,#1 '1 in qvector .x,.y add .x,#1 '2 in qvector .x,.y add .x,#1 '3 in qvector .x,.y add .x,#1 '4 in qvector .x,.y add .x,#1 '5 in qvector .x,.y add .x,#1 '6 in qvector .x,.y add .x,#1 '7 in qvector .x,.y getqx .px+0 '0 out getqy .py+0 add .x,#1 '8 in qvector .x,.y getqx .px+1 '1 out getqy .py+1 add .x,#1 '9 in qvector .x,.y getqx .px+2 '2 out getqy .py+2 add .x,#1 '10 in qvector .x,.y getqx .px+3 '3 out getqy .py+3 add .x,#1 '11 in qvector .x,.y getqx .px+4 '4 out getqy .py+4 add .x,#1 '12 in qvector .x,.y getqx .px+5 '5 out getqy .py+5 add .x,#1 '13 in qvector .x,.y getqx .px+6 '6 out getqy .py+6 add .x,#1 '14 in qvector .x,.y getqx .px+7 '7 out getqy .py+7 add .x,#1 '15 in qvector .x,.y getqx .px+8 '8 out getqy .py+8 shr .py+0,#32-9 'get 9 MSBs of theta (stuff code between GETQx ops) add .py+0,.px+0 'add rho to twist it getqx .px+9 '9 out getqy .py+9 shr .py+1,#32-9 add .py+1,.px+1 getqx .px+10 '10 out getqy .py+10 shr .py+2,#32-9 add .py+2,.px+2 getqx .px+11 '11 out getqy .py+11 shr .py+3,#32-9 add .py+3,.px+3 getqx .px+12 '12 out getqy .py+12 shr .py+4,#32-9 add .py+4,.px+4 getqx .px+13 '13 out getqy .py+13 shr .py+5,#32-9 add .py+5,.px+5 getqx .px+14 '14 out getqy .py+14 shr .py+6,#32-9 add .py+6,.px+6 getqx .px+15 '15 out getqy .py+15 add .py+0,.z 'add z to slowly spin it rdlut .py+0,.py+0 'lookup rgbi8 color wfbyte .py+0 'write rgbi8 pixel to bitmap add .py+1,.z rdlut .py+1,.py+1 wfbyte .py+1 add .py+2,.z rdlut .py+2,.py+2 wfbyte .py+2 add .py+3,.z rdlut .py+3,.py+3 wfbyte .py+3 add .py+4,.z rdlut .py+4,.py+4 wfbyte .py+4 add .py+5,.z rdlut .py+5,.py+5 wfbyte .py+5 add .py+6,.z rdlut .py+6,.py+6 wfbyte .py+6 shr .py+7,#32-9 add .py+7,.px+7 add .py+7,.z rdlut .py+7,.py+7 wfbyte .py+7 shr .py+8,#32-9 add .py+8,.px+8 add .py+8,.z rdlut .py+8,.py+8 wfbyte .py+8 shr .py+9,#32-9 add .py+9,.px+9 add .py+9,.z rdlut .py+9,.py+9 wfbyte .py+9 shr .py+10,#32-9 add .py+10,.px+10 add .py+10,.z rdlut .py+10,.py+10 wfbyte .py+10 shr .py+11,#32-9 add .py+11,.px+11 add .py+11,.z rdlut .py+11,.py+11 wfbyte .py+11 shr .py+12,#32-9 add .py+12,.px+12 add .py+12,.z rdlut .py+12,.py+12 wfbyte .py+12 shr .py+13,#32-9 add .py+13,.px+13 add .py+13,.z rdlut .py+13,.py+13 wfbyte .py+13 shr .py+14,#32-9 add .py+14,.px+14 add .py+14,.z rdlut .py+14,.py+14 wfbyte .py+14 shr .py+15,#32-9 add .py+15,.px+15 add .py+15,.z rdlut .py+15,.py+15 wfbyte .py+15 incmod .x,#640/2-1 wc 'check if x at limit if_c neg .x,#640/2 if_c incmod .y,#480/2-1 wc 'step y if_c neg .y,#480/2 if_c sub .z,#1 'step z if_c drvnot #56 'toggle P56 for speed check jmp #.pixels ' Slow code (10 fps) .pixel qvector .x,.y 'convert (x,y) to polar (rho,theta) getqx .px getqy .py shr .py,#32-9 'get 9 MSBs of theta add .py,.px 'add rho to twist it add .py,.z 'add z to slowly spin it mov .px,.py 'convert 6 LSBs to 5-bit up/down ramp test .px,#$20 wc if_c xor .px,#$3F and .px,#$1F shr .py,#1 'apply 3 MSBs to RGB bits and .py,#$E0 or .px,.py wfbyte .px 'write rgbi8 pixel to bitmap incmod .x,#640/2-1 wc 'step x if_c neg .x,#640/2 if_c incmod .y,#480/2-1 wc 'step y if_c neg .y,#480/2 if_c sub .z,#1 'step z if_c drvnot #56 'toggle P56 for speed check jmp #.pixel ' Data .x long -640/2 .y long -480/2 .z long 0 .px res 16 .py res 16It's using the streamer's RGBI8 mode, which is a byte per pixel. The top 3 bits select the color and the lower 5 bits select the intensity. No palette needed.
I just got my EVAL board four days ago. So I can finally move out of the peanut gallery and do some actual testing/coding/playing. Yay! But it will take some time for me to get up to speed (meaning a slow walk, in my case).
In playing with the VGA version, I noticed that the LED for P56 rapidly flickers, which it doesn't do when running the NTSC version. I haven't tried to figure out why (and likely couldn't if I did), but I assume that it's some kind of "artifact" from the code. I did comment out the launch of the bitmap cog (Cog 0) and I didn't see any activity on any of the LED's when I did that, so I assume that something in the code to drive the spiral is somehow affecting P56.
A funny thing happen when I commented out the coginit line for the bitmap cog and recompiled and ran it. The colorful spiral image appeared on the screen in all its beauty. And at first, I thought it was moving, but moving very slowly. So I thought, "What? How can that be? I killed the cog!" But the perception of movement was just my eyes playing tricks on me from having stared too much at the moving spiral.
Then I thought to myself, "But wait a second. Why is the spiral there at all, moving or not?" Well, I hadn't powered down between launches of the moving version and the static version. So, apparently, the hub RAM doesn't get cleared on a reset. I may have read that somewhere back during my peanut gallery days, but it caught me by surprise.
Anyway, I manually hit reset on the board and then re-ran the static version to see if the screen would be black. But it actually displayed a somewhat ghostly-looking version of the screen that shows up from a program that I stored in the flash memory. So, that program actually briefly loaded and put some data in the hub, which was then retained when I quickly relaunched the static spiral version. It makes sense, but it's interesting.
I then set the FLASH dip switch to off (such that my program in flash would not run on reset) to see what would happen. And rather than a black screen, I got a screen filled with random "static," kind of like white noise. So that's interesting, too.
I then re-enabled the bitmap cog (Cog 0) such that it would put up the spiral and fill the corresponding area in the hub. I then commented out the bitmap cog again and cut the power ever so briefly and reloaded the board. I was trying to see if the hub SRAM elements might retain any data, but they didn't (I got snow/static again). I believe that I recall reading that data in a DRAM (oddly enough with its refreshing needs) can persist for several seconds.
Moving on, I modified the original VGA version to allow me to pass in the video base_pin as a parameter (using setq before coginit). I then launched seven instances of the VGA program with separate base pins (0, 8, 16, 24, 32, 40 and 48), such that all eight cogs were running (with the bitmap cog occupying Cog 0). I wanted to see how hot the chip got to the touch. And it did get warm but not hot, much to my (pleasant) surprise, especially with the clock frequency set to 320 MHz for the VGA version (instead of 250 MHz for the NTSC one).
Unfortunately, I only made up a single VGA adapter board to plug into the headers, so I could only look at one cog's output at a time, but I moved the adapter around to confirm that all cogs were outputting on their respective headers (though I cut the power between each move of the adapter board just to be a bit safer when moving it around). Anyway, that pretty much confirms that all the cogs are running concurrently, with Cogs 1..7 all pulling data from the same bitmap cog (Cog 0).
I wouldn't be surprised if the bitmap cog is using the most power, as it uses the cordic. Then again, the vga cogs do have to access the memory slices at a pretty good clip. I haven't wrapped my head around RDFAST entirely yet, so I don't know if a video cog can "rest" a bit with the streamer handling video data transfers in the background. So, I'm not really sure how a video cog's power consumption compares to that of the the bitmap cog.
But I did monkey around with the fclk constant to try lower values than 320 MHz. It seemed to work for everything that I tried down to 243 MHz. The monitor sometimes had to shift the image a couple of times as it tried to lock on to the signals, but it took everything that I threw at it down to 243 MHz. Below that, my little 7" monitor protested "not support" (without the "ed"). But that's pretty impressive.
By the way, things seem to run equally fast at 320 MHz as at 243 MHz. It took about 10 seconds for an arm of the spiral to go all the way around (though I didn't get out a stopwatch). There seems to be another limiting factor involved other than the fclk setting. Perhaps it's due to waiting for the cordic to finish in the bitmap cog. Anyway, I'm not clear on why Chip used 320 MHz for the VGA version (It's not even an even multiple of 25 MHz). But it seems to work well, which is to say that my monitor didn't need to shift the screen to lock on to it.
For all I know (which is practically nothing at this point) perhaps some change could be made in the video cog code to accommodate running at a lower frequency (without any shifting occurring when locking on to the signal). But even if so, eventually such lowering of the clock frequency would cut in to the rate at which the bitmap cog is able to rotate the spiral.
I do know from running Chip's (?) program to display a bitmap (said program being modified by rayman to run on the Eval B version), that I could take the clock frequency all the way down to 23 MHz (Yes, 2 MHz below 25 MHz, not 250 MHz) and the image (bird or whatever) still displayed rock solid.
Incidentally, I know that I once stated my lack of comfort with using 25 MHz for VGA (640x480) instead of 25.175 MHz or something a bit closer to it than 25 MHz. But it seems to work fine on my little monitor (no complaints from it). And 25 MHz and multiples thereof (such as 200 and 250 MHz) are pretty convenient to work with when setting the clock speed.
Still on the To-Do list for my play with this VGA spiral program is to investigate why the base_pin supposedly must be a multiple of 8 instead of 4. I presume that some instruction(s) are so limited in this particular code design (probably for speed). But theoretically, the code could be written such that the base_pin would work on multiples of 4, or am I wrong? But I haven't thought about this much, partly because the VGA adapter board that I built the other day only works on multiples of 8. I guess that I should build one that works for VGA base_pins of 4, 12, 20, 28, 36, 44 and 52 (I likely would not try for pin 60).
Anyway, sorry for the long post, but maybe it's understandable considering that I've spent so much time in the peanut gallery. And many thanks to ersmith, rayman and ozpropdev, et. al., as I've used their compilers, GUI's and loaders to play with the P2. And thanks again, Chip, for providing the VGA version of your spiral program (not to mention the design of the P2 chip). Cheers! --Jim
pin56 toggle is diagnostics for monitoring the rendering frame rate.
Go @JRetSapDoog !!
Power consumption will be relatively small for the video out cogs. Even the hubram bandwidth is not very high. The renderer is the only one doing any hard work.
As for the flicker on P56, yes, I see the pair of "toggle P56 for speed check" lines in the code now. Thanks, Evan. I'm sorry that I did not look myself earlier (that would have taken less time than posting about it).
As for the rotation rate of the spiral, on first thought, it makes sense that it would be faster at 320 MHz than 243 MHz. That's what I expected, but it just seemed like the rates were the same from a cursory look when I ran things yesterday. Too bad that I couldn't run two versions side-by-side to watch (I'd need another P2 board for that).
Anyway, I figured that I had just misjudged the rates. So I went back again today to have another look. This time, I compared running at 375 MHz with running at 250 MHz, the former being 50% faster than the latter. But I still wasn't sure if my eye would be able to reliably detect any difference from successive runs. For this, I only changed the fclk constant in the code, nothing else.
I recorded both runs on video for one minute using a countdown timer. For both of them, the whitish spiral arms "hit" the top of the screen about 11.2 times over the course of a minute. I was expecting the run at 250 MHz to be about a third less (say between 7 and 8 hits). But it wasn't (or at least it didn't seem to be). So, I'm still open to the idea that there might be some other limiting factor, even though that runs counter to expectations.
I apologize in advance if there was something wrong with my test/measurements described above. Perhaps someone else can do a check (or if a code warrior, analyze the code for any possible limiting factor, but I'd see if there's really a difference in the rate first). As for me, I'll likely go on to some other things as I break in (but hopefully not break) this new board.
By the way, as an alternative to running 7 video cogs, I tried the opposite: I launched 7 instances of the bitmap manipulation (spiral animation) code. I assumed that they would kind of clobber each other and produce strange output (after the video cog displayed the bitmap data). But the spiral ran fine (and at the same speed).
As to why they didn't step on each other, maybe the 7 instances were all in lockstep. Or not. They are all use the same pipelined CORDIC, I realize. Well, in all likelihood, it's a case of "last man standing wins," with the final cog clobbering any earlier hub writes (likely with the same or very similar data). Or maybe I botched the code to launch them or they weren't really contending for the same memory for some reason.
Anyway, I was mostly trying to see if I could get the P2 chip to run warmer. But I couldn't tell if it ran any warmer (using my fingertip) than the 7-cog video version.
Actually, I still need to open up the P2 docs to see if there's any reason why the video cog is not running flat out (like I assume that the bitmap cog is), despite the streamer having more than enough time to supply the data (from the bitmap cog). If there's an automatic mechanism to make or allow it to "rest" (and thus take less power), I'm not aware of it yet, and I don't see any wait instructions in this particular VGA video generation code, either.
Anyway, as far as heat generation and dissipation goes, so far, so good. But the EVAL is a four-layer board, with two-ounce (or maybe it's four-ounce?) copper on the bottom layer. I recall that someone (evanh?) got all eight cores/cogs running flat out and was able to consume upwards of 2 amps at 320 MHz (for Vdd). So, I guess I should try that code if I really want to heat things up. But based on the results so far, it doesn't sound like I'll be roasting any marshmallows over the chip any time soon.
Update: Okay, I just ran the speed check described above (375 MHz vs. 250 MHz) again just using a countdown timer (there was no real need to make a video). Again, the whitish spiral arms "hit" the border at the top of the screen a tad over 11 times per minute either way, so it still seems like there's some other limiting factor for the max speed of the bitmap cog. But what? It doesn't seem to make sense. I see references in the code to 10 and 47 frames per second, but I assume those are measured results, not imposed/calculated results. Assuming that Chip is not limiting things, you'd think the faster the clock, the faster the animation. Hmm, could some logic handling the spiral rotation code be directly tied to the 20 MHz crystal speed instead of the 320 MHz (or whatever) clock speed? Hope not. Or is the code imposing an FPS limit (such as 47 frames per second)? Again, sorry if I've made some mistake in measuring the rotation speeds.
At 250 MHz sys-clock:
P56 is pulsing at 18.495 Hz (39.99 36.99 frames per second). Rotation is moving at about 34.5 arms per minute, or about 14 seconds for one rotation.
If you ran six cogs for rendering and had each one handle 80 lines, based on its COGID, then you'd see a 6x speed increase, making a frame rate of 6 x 42fps =252fps. That's way faster than the VGA could keep up with.
