Prop Plug LED(s) meaning?
There is a red LED and a blue LED.
I've searched the site and the Prop Plug documentation at https://parallax.com/product/32201
Red LED = ?
Blue LED = ?
tia!
Red LED = ?
Blue LED = ?
tia!
Configurable CBUS I/O Pin. Function of this pin is configured in the
device internal EEPROM. Factory default configuration is RXLED#. See
CBUS Signal Options, Table 3.9.
23 CBUS0 I/O
23 CBUS0 I/O
device internal EEPROM. Factory default configuration is TXLED#.
https://www.ftdichip.com/Support/Documents/DataSheets/ICs/DS_FT232R.pdf
Thank you for that.
(eta)
I'm looking for clues to Propeller IDE failure to download (to a Spinerette, running in Ubuntu).
Both flash.
It's probably dialout error, but I've not yet run through the steps to track it down.
I'm running propellerIDE from the terminal to see the reports from propeller-manager.
Just wanted to add the meaning of the LEDs to what I'm presently seeing..
(again eta) ... and I wanted to note it in my own user-manual-journal.
Just something I do..
Now I got it.
thanks for your help!
