Posting code
 AGCB
AGCB
                    I'm wondering how to post code like in this thread in the SPIN icon.
https://forums.parallax.com/discussion/170737/pixel-driver-update
Aaron
Aaron
Another way is to post the code inline, by clicking the "C" icon above the text box, and then copy/pasting your code inside the generated tags.
Image attached.
Or you could attach multiple files if you feel that would be appropriate. Just click the Attach a file" link for each file. There might be a limit to how many individual files you can attach per post, so if you hit the limit then maybe make a second post. Or zip a bunch of files together
You could also use the "archive" in the Propeller Tool to create a zip file from a Spin program that uses multiple Spin files.
Aaron
Yes, that's it. Give it a try !
@Publison 's suggestion is a good time-saver too, if you are using Propeller Tool to edit your SPIN code.
