How to eliminate the need for @@@ in PropBASIC ?
Bean
Here is some code showing how PropBASIC uses the @ @ @ operator.
How can the use of @ @ @ be avoided ?
I am open to any ideas.
Bean
' hubVar1 HUB LONG ' mov __temp,#0 ' WRLONG hubVar1,0 wrlong __temp,__hubVar_adr ' __hubVar_adr LONG @ @ @ hubVar1 DAT hubVar1 LONG 0 '
Bean
static char *ops[] = { "++", "+=", "+", "--", "-=", "-", ">>=", ">>", ">-=", ">-", "><=", "><", ">|", ">=", ">", "<<=", "<<", "<-=", "<-", "<#=", "<#", "<>=", "<>", "<=", "<", "**=", "**", "*=", "*", "//=", "//", "/=", "/", "||", "|<", "|=", "|", " @ @ ", " @ ", "#>=", "#>", "^^", "^=", "^", "=>=", "=>", "=<=", "=<", "!", "~~", "~>=", "~>", "~", "?", "===", "==", 0}; /* INLINE SPIN PUB start | ptr ptr := @ops repeat while long[ptr] long[ptr] += @ @0 - 16 ptr += 4 */It produces the following Spin codeDAT ops long long @datstr + 16, @datstr + 19, @datstr + 22, @datstr + 24, @datstr + 27, @datstr + 30, @datstr + 32, @datstr + 36 long @datstr + 39, @datstr + 43, @datstr + 46, @datstr + 50, @datstr + 53, @datstr + 56, @datstr + 59, @datstr + 61 long @datstr + 65, @datstr + 68, @datstr + 72, @datstr + 75, @datstr + 79, @datstr + 82, @datstr + 86, @datstr + 89 long @datstr + 92, @datstr + 94, @datstr + 98, @datstr + 101, @datstr + 104, @datstr + 106, @datstr + 110, @datstr + 113 long @datstr + 116, @datstr + 118, @datstr + 121, @datstr + 124, @datstr + 127, @datstr + 129, @datstr + 132, @datstr + 134 long @datstr + 138, @datstr + 141, @datstr + 144, @datstr + 147, @datstr + 149, @datstr + 153, @datstr + 156, @datstr + 160 long @datstr + 163, @datstr + 165, @datstr + 168, @datstr + 172, @datstr + 175, @datstr + 177, @datstr + 179, @datstr + 183, 0 datstr byte "++", 0, "+=", 0, "+", 0, "--", 0, "-=", 0, "-", 0, ">>=", 0, ">>", 0 byte ">-=", 0, ">-", 0, "><=", 0, "><", 0, ">|", 0, ">=", 0, ">", 0, "<<=", 0 byte "<<", 0, "<-=", 0, "<-", 0, "<#=", 0, "<#", 0, "<>=", 0, "<>", 0, "<=", 0 byte "<", 0, "**=", 0, "**", 0, "*=", 0, "*", 0, "//=", 0, "//", 0, "/=", 0 byte "/", 0, "||", 0, "|<", 0, "|=", 0, "|", 0, " @ @ ", 0, " @ ", 0, "#>=", 0 byte "#>", 0, "^^", 0, "^=", 0, "^", 0, "=>=", 0, "=>", 0, "=<=", 0, "=<", 0 byte "!", 0, "~~", 0, "~>=", 0, "~>", 0, "~", 0, "?", 0, "===", 0, "==", 0 ' INLINE SPIN PUB start | ptr ptr := @ops repeat while long[ptr] long[ptr] += @ @0 - 16 ptr += 4The start method is not needed for the top object. It is only needed for the lower objects. The start method is generated using CSPIN's inline directive. I never implemented an automatic way of generating the start method.I think you are saying that it is, but only for the top object.
If that is true, I can try using the +16 and see if it works.
Thanks for the tip, I will try it.
Bean
Can you explain this line ?
Bean
