Appcon RF1276 Point to Point P2P Failure over time
Configuration of RF1276:
Parallax Arlo with RF1276 added:
Controller using Propeller:
Output: Arlo
Output: controller
Code for Arlo:
  mobile.c
  Demonstrates using full duplex serial communication to exchange information.
  https://www.appconwireless.com/showpro.php?id=94
  http://learn.parallax.com/tutorials/language/propeller-c/propeller-c-simple-protocols/full-duplex-serial
  https://github.com/parallaxinc/Simple-Libraries/blob/master/Learn/Examples/Protocols/XBee UART Command Mode Example.c
#include "simpletools.h"
#include "fdserial.h"
#include "compass3d.h"
void compass(void *par);
fdserial *robot;
fdserial *term;
unsigned int stack[44 + 128];
static volatile char dataIn[11];
int main()
  robot = fdserial_open(9, 8, 0, 9600);  // fdserial *fdserial_open(int rxpin, int txpin, int mode, int baudrate)
  pause(1000);
  term = fdserial_open(31, 30, 0, 115200);
  pause(1000);
  fdserial_rxFlush(robot);
  cogstart(compass, NULL, stack, sizeof(stack));
  int n = 0;
  char c;
  while(1)
    for (int i = 0; i < 11; i++)
      dataIn[i] = '\0';
    n = 0;
    c = fdserial_rxChar(robot);
    if(c != -1)
      while (n < 10)
        dataIn[n] = c;
        n++;
        if (c == -1 || c == '\n')
          break;
      dataIn[10] = '\0';
      dprint(term, "J%s\n", dataIn);
      pause(1000);
    else
//    dprint(term, "0XAF 0XAF 0X00 0X00 0XAF 0X80 0X20 0X02 00 00 CS 0X0D 0X0A");
  int x, y, z;                                // Declare x, y, & z axis variables
  i2c *bus = i2c_newbus(3, 2, 0);             // New I2C bus SCL=P3, SDA=P2
  compass_init(bus);                          // Initialize compass on bus.
  while(1)                                    // Repeat indefinitely
    compass_read(bus, &x, &y, &z);            // Compass vals -> variables
    float fy = (float) y;                     // Ints to floats
    float fx = (float) x;
    float heading = atan2(fy, fx) * 180.0/PI; // Calculate heading with floats
    if(heading < 0.0)                         // Convert -180...+180 to 0...360
      heading = (360.0 + heading);
//    fdserial_txFlush(robot);
    dprint(robot, "%.2f\n", heading);
    pause(1000);           // Display heading
    dprint(term, "%.2f\n", heading);
Code for Controller:
  controller.c
#include "adcDCpropab.h"
void joystick(void *par);
fdserial *robot;
fdserial *term;
int main()
  pause(1000);
  pause(1000);
  cogstart(joystick, robot, stack, sizeof(stack));
  int n = 0;
  char c;
  while(1)
      dataIn[i] = '\0';
    n = 0;
    if(c != -1)
      while (n < 10)
        dataIn[n] = c;
        n++;
          break;
      dataIn[10] = '\0';
      dprint(term, "C%s\n", dataIn);
      pause(1000);
//  pause(1000);                                      // Wait 1 s for Terminal app
  adc_init(21, 20, 19, 18);                         // CS=21, SCL=20, DO=19, DI=18
  float lrV, udV;                                   // Voltage variables
  while(1)                                          // Loop repeats indefinitely
    udV = adc_volts(2);                             // Check A/D 2
    lrV = adc_volts(3);                             // Check A/D 3
    //pause(1000);                                     // Wait 1/10 s
    dprint(robot, "%.2f %.2f\n", udV, lrV);       // Display voltage
    dprint(term, "%.2f %.2f\n", udV, lrV);       // Display voltage
//    dprint(robot, "%.2f\n", lrV);       // Display voltage
//    pause(1000);                                     // Wait 1/10 s
At first I had only one or two lines of output but by using dprint(robot, "%.2f %.2f\n", udV, lrV); and dprint(term, "%.2f %.2f\n", udV, lrV); as above the output continues for a short period but finally transmission stops at both ends.
Perhaps there is something more I need to do with the fdserial library?
Comments would be much appreciated.
Many thanks,
Kevin.
  • I have modified the RF1276 configuration:
    The default setting RF_BW 125Khz and RF_factor 2048 means the air data rate is 600bps. We recommend you set the RF_Factor 512, RF_BW 500Khz to try.
    RF_Factor: Lora spreading factor. Larger value means higher sensitivity but longer air transmission time
    RF_Factor 1 byte 7=128, 8=256, 9=512, 10=1024, 11=2048, 12=4096
    RF_BW: Lora bandwidth. Larger value means lower sensitivity. Recommended value: 125K.
    RF_BW 1 byte 6=62.5k, 7=125k, 8=250k, 9=500k
    I still do not know what settings are optimum? However the flow of data is much better.
    The syncing at power-up could be better. It comes right by itself but I probably need to eliminate data that is not complete. Also at times the data from one "channel" seems to appear in the other "channel". This can also correct itself over time. Where should fdserial_rxFlush and fdserial_txFlush be used?
    Kevin.
    395 x 329 - 49K
    If the first character is not a "C" or a "J" then the transaction is discarded.
    If the length of a joystick transaction is not >= 10 it is discarded.
    The compass transactions are not working correctly in terms of correct direction.
      mobile.c
    fdserial *robot;
    fdserial *term;
    static volatile char dataIn[13];
    int main()
      pause(1000);
      pause(1000);
    //  fdserial_rxFlush(robot);
      int n = 0;
      char c;
      while(1)
        for (int i = 0; i < 13; i++)
          dataIn[i] = '\0';
        n = 0;
        if(c != -1 && (c == 'J'))
          while (n < 12)
            dataIn[n] = c;
            n++;
            if (c == -1 || c == '\r')
              break;
          if (c == -1)
            break;
          if (c == '\r')
             dataIn[n] = '\0';
          dataIn[12] = '\0';
          if(strlen(dataIn) >= 10)
            dprint(term, "%s\n", dataIn);
            pause(1000);
    //      dprint(term, "%d\n", strlen(dataIn));
        else
        dprint(robot, "C%.2f\r", heading);
    //    dprint(term, "%.2f\n", heading);
    //    pause(1000);           // Display heading
      controller.c
    fdserial *robot;
    fdserial *term;
    int main()
      pause(1000);
      pause(1000);
      int n = 0;
      char c;
      while(1)
          dataIn[i] = '\0';
        n = 0;
        if(c != -1 && (c == 'C'))
          while (n < 12)
            dataIn[n] = c;
            n++;
              break;
          if (c == -1)
            break;
          dataIn[12] = '\0';
          pause(1000);
        else
        dprint(robot, "J%.2f %.2f\r", udV, lrV);       // Display voltage
    //    dprint(term, "%.2f %.2f\n", udV, lrV);       // Display voltage
    Any suggestions please?
    309 x 414 - 12K
