How many DoF on this chassis design???
Just stumbled across this while perusing youtube during my lunch. I love this chassis design and the level of articulation. I think this would make a great robot chassis platform. Even the back of it looks like a mean face ready for a robot battle....
Anyhow, I was trying to count the degrees of freedom for each "leg" but not quite sure.
  • Looks like each of the wheel let’s are 2 DOF, while the bucket arm is 4 DOF(5 DOF if you count the telescoping motion).
    Pretty cool! Makes you wander at the fuel consumption...
    That's not an explosion! That's an unscheduled rapid disassembly!
    Looking for a way to have a silicon chip made.
  • When I was way younger then now I worked in construction and operated heavy equipment. This is just amazing.
    But on the other hand it is sort of overkill. At 99% of my worksites I would never have needed to use those features.
    Cool to have but - hmm - rarely needed.
    Enjoy!
  • That is impressive amount of engineering there. The motors must be in the wheel hubs and are probably hydraulic motors.
    I was watching a modified tractor on a TV programme the other day, it was the old dunger hacked up for a single job. The job being mechanical de-weeding between crop rows. The wheels were extra skinny and all four had axel extensions added to match the row spacing. The grubber was customised too.
    "... peers into the actual workings of a quantum jump for the first time. The results
    reveal a surprising finding that contradicts Danish physicist Niels Bohr's established view
    —the jumps are neither abrupt nor as random as previously thought."
  • ercoerco Posts: 19,454
    WOW! Incredible, I want to see that in person. What a machine!
    "When you make a thing, a thing that is new, it is so complicated making it that it is bound to be ugly. But those that make it after you, they don’t have to worry about making it. And they can make it pretty, and so everybody can like it when others make it after you."
    - Pablo Picasso
    See also the "walking excavator" at the end of this top ten list. Very robotic!
    - Pablo Picasso
