Block read/write on next silicon
cgracey
I made some late changes to the PTRA/PTRB circuits to sensibly accommodate block reads and writes, but I accidentally oversimplified things.
On the next silicon, when doing a 'SETQ{2} + RDLONG/WRLONG/WMLONG PTRx' sequence to read or write a block of longs, no random index will be allowed.
Only 5 PTRx options will be recognized by the silicon:
In other words, the index becomes the (SETQ value + 1) << 2 for PTRx-modifying instances and $00000 for non-PTRx-modifying instances.
I realized this as I was going over the interpreter code, making sure it would easily be compatible with the next silicon. In several cases, I will need to use an extra instruction to modify PTRA now.
What used to be something like this:
Will now need to be coded like this:
The point of the change was to make things like block moves easy:
I should have keyed this block behavior from distal index values, perhaps, but it is this simplistic way now.
SETQ #100-1 'read 100 longs @PTRA into regs 0..99 RDLONG 0,PTRA SETQ #100-1 'read 100 longs @PTRA+400 into regs 0..99, PTRA += 400 RDLONG 0,++PTRA SETQ #100-1 'read 100 longs @PTRA-400 into regs 0..99, PTRA -= 400 RDLONG 0,--PTRA SETQ #100-1 'read 100 longs @PTRA into regs 0..99, PTRA += 400 RDLONG 0,PTRA++ SETQ #100-1 'read 100 longs @PTRA into regs 0..99, PTRA -= 400 RDLONG 0,PTRA--
setq #6-1 'push z/pbase/vbase/dbase/y/x (include x to init 'result' in hub) wrlong z,ptra++[5] 'ptra points to 'result' afterwards
setq #6-1 'push z/pbase/vbase/dbase/y/x (include x to init 'result' in hub) wrlong z,ptra++ sub ptra,#1<<2 'ptra points to 'result' afterwards
rep #4,#64 'move 64KB quickly from @ptra to @ptrb setq #$100-1 'read 1KB into registers $000..$0FF rdlong 0,ptra++ setq #$100-1 'write 1KB from registers $000..$0FF wrlong 0,ptrb++
My head is now full of bricks, lintels and other building components, but I think a problem at one time was ptrx not being modified at all after block moves. Pointing to the "next" location rather than the previous "end" location appears to be all right, although losing the index is unfortunate perhaps.
In the "used to be" code, were data written to ptra, ptra+4, ..., ptra+5*4, then ptra := ptra+5*4? If so, that was rather odd and not what the code suggested.
Using xxPTRA or PTRAxx will use the address (PTRA + SETQ * 4) as the first address ?
And the final result of PTRA will be +(SETQ+1)*4 ?
Example
So we have to initially set
PTRA = hubadr - (value of SETQ*4. ie $20*4)
For 'SETQ + RDLONG PTRA':
PTRA means use PTRA, PTRA stays the same
PTRA++ means use PTRA and post-update PTRA to PTRA+(SETQ +1)*4
PTRA-- means use PTRA and post-update PTRA to PTRA-(SETQ +1)*4
++PTRA means use PTRA+(SETQ +1)*4 and post-update PTRA to PTRA+(SETQ +1)*4
--PTRA means use PTRA-(SETQ +1)*4 and post-update PTRA to PTRA-(SETQ +1)*4
Just think of these sequences as giant pushes and pops, where {++/--}PTRx{++/--} is updated with the block size times 4 (for longs).
For {++/--}PTRx{++/--}, the assembler makes the 5-bit offset value either +1 or -1. The MSB of the offset value gets used to determine add or subtract.
It's not going to change. It's done. Hopefully, there are no bugs. I would have done it differently, had I been aware of the implications, but it's pretty straightforward: Don't use [index] with SETQ+RDLOAD, as it will adjust PTRx automatically. Of course, this behavior is different than the first-rev silicon.
Actually, you can write SETQ+RDLONG+PTRx code that will function on both chips, but be limited to a small adjustment range.
Thanks Chip.
So this line in your post should be ie this "@PTRA+400" was the confusing part.
I presume BYTE and WORD work similarly? (ie *2 and *1) - used of course without SETQ.
No. The ++PTRx means pre-add the index before using, while PTRx++ means post-add the index after using.
Getting my head around this...
Read/write block... Added "PTRA not updated". Got it
Block move... Added "ptra += $100*4 (ie next address)" Got it
Push[n] onto stack... Added "ptra += $100*4 (ie next address)" This is what I would expect the behaviour to be!
ie ptra would be incremented by the number of bytes/words/longs written/read.
In reality, this is equivalent to (for concept only - will not work due to pipeline!) To do it the way you intended, IMHO would be a bug, and many would get caught out.
