The Virtually Infinite Propeller Modular Computer(VIPMC) Input Needed!
2
  • So, curious, the I/O pins on the P1 are logic gated together between cogs to determine the final output. Is there any real speed difference between the pins going through more or less gates? If so, which pins would be optimal to use between props?
    Windows 10 Home:
    Propeller Tool 1.3.2, BASIC Stamp Editor 2.5.4, Javelin Stamp IDE x.x.x, Arduino IDE, PST
    Hardware:
    BASIC Stamp Board of Education, Propeller Board of Education, Propeller Project Board, Propeller Mini
  • There has been said to be some difference, but I personally haven't run into any issues, even with 20 MHz SPI. Some couple nanoseconds (a single CPU cycle @ 80Mhz is 12.5 ns!)
    I think(!) that pins 0-15 are closest to cog 0 and pins 16-32 are closest to cog 7. Maybe the other way round. I'm sure there's a thread on here about it, but I can't find it right now.
  • Smaller opcodes for small constants versus referencing bigger values via "fake constants" in memory may be a thing there too. Code addressing lower pin numbers may be slightly faster.
    Perhaps this has more impact than the distance from cog to pin...
    ◁ propeller-wiki ▷ ◁ FastSpin ▷ ◁ Help Spin at RosettaCode.org ▷ ◁ No Source – No Go! ▷ ◁ DK-E ▷ ◁ :-D ▷ ◁ Stay OmmmmmmPtimistic! ▷ ◁ Why Asimov's Laws of Robotics Don't Work ▷ ◁ DNA is a four letter word. ▷ ◁ Stop slavery! Free all mitochondria! ▷
  • @yeti
    That could make a difference in Spin only. PASM timing is the same regardless of whether the source is immediate.
    However, pins 0-7 have the advantage of not needing to be shifted down to be WRBYTE'd...
  • Thank you! I will have another look at my pin assignments(finally just made a .txt file to keep track of them all) and set up the data lines.
    Windows 10 Home:
    Hardware:
  • AwesomeCronkAwesomeCronk Posts: 772
    edited 2019-06-25 - 22:36:23
    Well, I have made symbols for the XBee and ESP32 Feather. I have, however been unable to resolve the incapacity to program the Feather. I posted to the Adafruit Forums(twice since June 7th), to no avail. if anyone here can help solve this, I would greatly appreciate it.
    On the plus side, I have wired up the USB Prop! I will add the schematic once I fix my KiCAD Libraries. Screwed them up bad.
    EDIT: Fixed the libraries! Here is the PDF:
    Windows 10 Home:
    Hardware:
  • Two things: One, I have renamed the device. The VIPMC, Virtually Infinite Propeller Modular Computer. This is dues to the nature of the stack, in that you can add cards to it to the limit of either the props memory and your power supply.
    Two: I have been trying to get a QFP package sourced for EEPROMs. I’m just gonna use DIP sockets. That way I can program the EEPROMs on another board and mass produce programmed EEPROMs. This should also make firmware updates easier.
    Windows 10 Home:
    Hardware:
    edited 2019-08-24 - 15:15:50
    Feather programmability, SOLVED! (By purchasing a cable from Parallax.)
    I have sorta familiarized myself with the Arduino IDE and I have nailed server and webpage hosting with it.
    I am testing a Serial Initialization system using my PropBOE, Propeller Project Board, and PropMini. Pics later.
    Windows 10 Home:
    Hardware:
  • OK. I need your input as the community. Which of the following switches would be preferred on the VIPMC for a reset button?
    https://www.mouser.com/ProductDetail/NKK-Switches/GP0115ACCG30-R?qs=sGAEpiMZZMvxtGF7dlGNpjm6OJutkRKEA3AKEj%252B7mMI%3D
    https://www.parallax.com/product/400-00002
    Windows 10 Home:
    Hardware:
  • yetiyeti Posts: 584
    edited 2019-08-24 - 15:27:19
    I think GP0115ACCG30-R would only make sense if you have a case for the system and this button fits the design.
    Using the simpler button on the PCB and a jumper in parallel to easily add an off PCB reset button wherever you want is more flexible.
  • Good thinking!
    Windows 10 Home:
    Hardware:
  • I need to know where I can find female pin headers in 2.54mm spacing(0.1"). I need 2x1 and 16x1.
    Windows 10 Home:
    Hardware:
    Surface mount or Through-Hole?
    Along with 'Antimatter' and 'Dark Matter' we've recently discovered the existence of
    `Doesn't Matter`, which appears to have no effect on the universe whatsoever.
  • Peter JakackiPeter Jakacki Posts: 8,640
    edited 2019-08-24 - 23:08:32
    I prefer using male pin headers on main boards so that cables and modules are always female. Keep these connections along the edge of the PCB and if there are other pin headers then keep them in the same 0.1" grid. Avoid rats nest connectors that go all over the pcb.
    Standard pitch pin headers are ubiquitous but I have boxes of them that I bought in bulk from 4ucon.
    None of this should stop you from designing the PCB since you only have to allow for a connector. Once a PCB is being made you can decide whether to populate it or not with whatever fits. I prefer to use through-hole because they are easier to get and cheaper and also far less likely to rip off a pcb. Anyway, you can use a combo smd+th footprint so that you once again have the choice at assembly time.
    --->CLICK THE LOGO for more links<---
    P2 +++++ TAQOZ INTRO & LINKS +++++ P2 SHORTFORM DATASHEET
    P1 +++++ Latest Tachyon includes EASYFILE +++++ Tachyon Forth News Blog
    Brisbane, Australia
    edited 2019-08-24 - 23:16:41
    I need them for stacking the CPU cards. And yes, THT like the ones on Stamp/Prop boards.
    Windows 10 Home:
    Hardware:
  • I suppose I could redesign the CPU stack design so that it uses four 3-pin headers, rather than six 2-pin headers.
    I need to be able to plug the CPU cards in one after the other, with each one facing the opposite way. I need 5 pins minimum with male pins facing downward, and female sockets facing upward. Here is my current plug, with 12 pins. 6 going up, 6 going down.
    575 x 472 - 43K
    Windows 10 Home:
    Hardware:
  • Here is a link to 4ucon for a 1x9@2.54 female socket with long pins that I use in some projects.
    4uconnector.com/online/object/4udrawing/15201.pdf
    Website: www.clusos.com
  • Also needed: a DIP version of this feller: https://www.parallax.com/product/602-10001
    Windows 10 Home:
    Hardware:
  • DIP EEPROM? There's the Microchip 24FC1026P, but that's 128K. I think there's also a 64K version (24FC512P I think?) but I recall it not being much cheaper.
    edited 2019-08-25 - 02:19:02
    Bigger EEPROM is better. You are correct on both mentions, and I think I will take the 24FC1026P. Thanks!
    Will this device work as a Propeller boot memory?
    Windows 10 Home:
    Hardware:
  • So, I was talking with Support via email. The VGA connector that I have in my bin is no longer being sold. Support said that Newark was the supplier, but was unable to recall the part number. Anyone here know it?
    Windows 10 Home:
    Hardware:
  • I find VGA connectors not only bulky but you need mechanical support for them as well once a cable is plugged in which is all good and fine for a desktop PC, but not bare PCBs.
    What I do instead is have a simple pin header, either a 8x2 way for common VGA+IDC plugs found on ebay or just the minimum 6 pins required. That way I can have my own cable plug into the pcb easily and directly into the monitor without all the bulk considering the Prop board is only a tiny PCB. This also allows you to use the standard VGA+IDC mounted to the chassis but connect via the 16-way IDC to the pcb, just like they do for video adapter cards on the PC. There are many variations of this but the point is to literally "think out of the box".
    Brisbane, Australia
  • jmgjmg Posts: 13,901
    VGA connectors have a choice of size of price, plenty of large ones out there...
    A popular compact VGA is something like
    https://www.digikey.com/product-detail/en/edac-inc/634-015-274-992/151-1125-ND/2059408
    or this, for lower-height
    https://www.digikey.com/product-detail/en/norcomp-inc/200-015-213L537/NOR1731-ND/6834321
    edited 2019-08-27 - 00:38:07
    I have never seen this to be an issue with the plug on PropBOE, which is the same plug I have.
    (Reply to Peter, didn't see jmg's post when I posted.)
    Windows 10 Home:
    Hardware:
    edited 2019-08-27 - 00:58:59
    Once a VGA cable is plugged in it ends up mechanically "over-powering" the tiny pcb and besides the VGA PCB connectors are bulky and footprints vary. What I have mentioned is my personal preference and from experience over decades of incorporating VGA onto pcbs themselves. Whether or not the chassis has a VGA connector itself is not a matter for the PCB to worry about. One Prop product I have has a male VGA connector on the pcb and is designed to mount inside an extended headshell so that it plugs directly into the monitor and it also has a USB socket for a PS/2 keypad. All I need to connect this to my system is a 4-wire connection for multi-drop RS485 and DC, so there is no need for a cable in this case (pun).
    BTW, I'm talking about commercial products, not educational ones. Consider this information as food for thought.
    Brisbane, Australia
  • Currently the motherboard is 13.8cm by 15(ish)cm. Not necessarily "tiny".
    If I must find a new VGA port, a vertical one may be ok. Looking at jmg's links.
    Windows 10 Home:
    Hardware:
  • BTW, I'm trying to get a head start on building the website for this feller. I'm trying to make a slideshow like the one at www.parallax.com. I want to be able to navigate between sheets using the buttons etc, and I also want it to advance automatically every 5 seconds. JavaScript is like my 30th language(not really) and thus not very well understood.
    Sorry if this is the wrong place to ask, but I figured that it was related via the product.
    Windows 10 Home:
    Hardware:
  • Nevermind, fixed it!
    Windows 10 Home:
    Hardware:
  • How much spacing between USB ports should be allowed?
    Windows 10 Home:
    Hardware:
  • Looking for a 3.7v regulator, 1A. This is an alternate method to powering the feather onboard. I choose this because I would like to avoid using a cut off usb plug sprouting from the board.
    Also, the feather has a charge circuit which will try to supply voltage to the regulator backwards when plugged into USB. My idea is to mimic a battery, but with stable supply.
    Windows 10 Home:
    Hardware:
