Using an a555 Monostable Timer as an alternative to a crystal for a prop clock
Thinking of using the a555 for a prop clock. Would an adjustable speed clock and the code
_clkmode = xtal1 + pll16x
_xinfreq = 6_250_000
conflict?
Windows 10 Home:
Propeller Tool 1.3.2, BASIC Stamp Editor 2.5.4, Javelin Stamp IDE x.x.x, Arduino IDE, PST
Hardware:
BASIC Stamp Board of Education, Propeller Board of Education, Propeller Project Board, Propeller Mini
Me, a programmer in English class, asking for grammar help: “What is the syntax for this statement?”
  • Oh, the humanity....
    Please just don't even go there and besides, a 555 is limited to 2MHz max and even then it will drift all over the place like flotsam and jetsam. I have a clock gen chip on my P2D2 that I can program to any frequency and it is very accurate.
    But why would you need an adjustable clock?
    --->CLICK THE LOGO for more links<---
    P2 +++++ TAQOZ INTRO & LINKS +++++ P2 SHORTFORM DATASHEET
    P1 +++++ Latest Tachyon includes EASYFILE +++++ Tachyon Forth News Blog
    Brisbane, Australia
  • Phil Pilgrim (PhiPi)Phil Pilgrim (PhiPi) Posts: 22,442
    edited 2019-05-19 - 02:06:06
    Yes/maybe. For this to work, the 555 would have to output a frequency between 4 and 10 MHz. But even then, it's really set up for a crystal, not an external oscillator. Also, your 555 would have to be 3.3V compatible. What are you trying to do with this?
  • jmgjmg Posts: 13,920
    Thinking of using the a555 for a prop clock. Would an adjustable speed clock and the code conflict?
    Why do you need an adjustable speed clock ?
    There are better choices than a 555, depending on exactly what it is you are trying to do ?
    What range do you need to adjust over, by what means ?
  • Also, you said "monostable." You meant "astable," right?
    Umm... sure, I really can’t find out much about the thing.
    As for the general information, I was simply curious. Thanks for the feedback.
    Windows 10 Home:
    Hardware:
  • Beau SchwabeBeau Schwabe Posts: 6,416
    edited 2019-05-19 - 15:28:53
    The only time I might consider running a processor like this would be using it somewhat like a giant ripple counter.
    Suppose I had a sensor that I could convert it's output to a stream of pulses, but only the deviation in frequency from the sensor changes were so small that I couldn't accurately capture it with a standard micro without devoting tons of overhead processing. By using the stream of pulses from the sensor to drive the clock of a micro, I could divide out (within that micro) as many times as I wanted so that the small deviations compounded in my favor to become larger deviations that could be measured with another micro running with a more precise time base.
    So unless your intent is to specifically use the clock input of a micro in some reciprocal timing scheme, I would advise against this method as the main time base of a micro.
    Definitely turn off the PLL, otherwise the PLL will be constantly "hunting" for a frequency to lock onto.
    Beau Schwabe --- Robotics applications- PCB design, embedded software, and mechanical
    Oklahoma Robotics -
    www.Kit-Start.com - bschwabe@Kit-Start.com ෴෴ www.BScircuitDesigns.com - icbeau@bscircuitdesigns.com ෴෴
  • JonnyMacJonnyMac Posts: 6,237
    edited 2019-05-19 - 20:29:10
    :lol:
    Wait.. what?! Millions of 555 timers are deployed every year -- there is a wealth of information about it. What a bit of researching (hint, hint) would tell you is that it can be configured in one of three modes: bistable, monostable, and astable; the mode is dependent on the connection of external components. What you're after is astable.
    Jon McPhalen
    Hollywood, CA
    It's Jon or JonnyMac -- please do not call me Jonny.
  • Hmm. I was thinking that an adjustable clock might be useful for complex propeller designs, to visually debug normally high speed code. Though further examination shows that a 6.25Mhz crystal to just go fast is likely wiser.
    Windows 10 Home:
    Hardware:
    There are few cases where very slow clocks would make sense, but it is possible to do so.
    See also this thread https://forums.parallax.com/discussion/170135/ultra-slow-clock-for-debugging#latest
    I could see use in teaching, to show students the `wiggles per opcode` but that would be for half a dozen lines of demo code, to get the concept across.
