USB Testing
11415161719
  • I finally got around to trying out the MouseKbdLite file...
    Not really working, but I do get these messages only when I connect a USB device:
    <Full-Speed device connected.>
    GetDescriptor(TYPE_DEVICE): 0x00000000, Retry limit exceeded, transaction canceled.
    Maybe I need pullup resistors?
    Prop Info and Apps: http://www.rayslogic.com/
  • RaymanRayman Posts: 9,460
    edited 2019-02-18 - 22:33:21
    Actually, I think I made a big mistake with this board...
    Seems that I have DP on an even pin...
    Tried this, but it doesn't work:
    DP           = 12'27                       ' DP is passive
    DM           = 13'26                       ' DM is "The Brain"
    Time to break out some jumpers...
  • Rayman wrote: »
    Yeah. DP must be the odd pin. No pullup/down resistors needed on silicon.
    garryj
  • Ok, I've reversed the wires and now it works with what I think is full speed wireless mouse.
    But, doesn't work with low speed mouse or keyboard.
    Gives that same message as with wires backwards:
    edited 2019-02-20 - 14:00:49
    Uh Oh, low speed works when compiled with PNut, but not with Fastspin.
    This sounds like a great challenge for ersmith!
  • Never mind, latest beta version of FastSpin (3.9.21-beta-83b9b75) works with low speed USB.
  • Trying USBMS and think I see a typo...
    Fastspin gives a warning on this line:
    dreq_clear_endpoint
                    cmp     cbw_flags, #BULK_DIR_IN
    warning on line 3400 that "cmp" is used without flags being set...
  • Just tried a few thumbdrives…
    The USB-SD-uSD thing is fun. It works with a black 2GB card, but not that white 32GB one.
    The 64GB Kangaroo doesn't work, probably because it's NTFS.
    1GB Lexar JumpDrive works.
    4GB RiData doesn't work, not sure why, seems like it should..
    Gives this:
    Vendor ID: Ut163
    Product ID: USB2FlashStorage
    Version level: 0.00
    Media is removable
    Device does not claim conformance to any SPC standard
    Highest LBA: 8060926
    Sector size: 512
    Checking media for a FAT file system...
    Unable to mount this device.
    3024 x 4032 - 2M
  • Rayman wrote: »
    dreq_clear_endpoint
    Yep. This routine is called when clearing a stalled endpoint, which is fairly rare. This one's been there a while. Thanks!
    garryj
  • Rayman wrote: »
    Hmm. It's bailing early in the FAT check, so the issue is likely something it doesn't like in the MBR or the volume BPB.
    At the "#" start-up prompt, issue a TGLDBG command to enable verbose output and it will output both of these sectors during device enumeration.
    garryj
  • Here it is. Note: this is a fairly old USB drive, wouldn't worry too much about it...
    GetDescriptor(TYPE_DEVICE): ACK
    SetAddress(): ACK
    GetDescriptor(TYPE_CONFIG): ACK
    SetConfiguration(): ACK
    RequestMaxLUN(): ACK
    INQUIRY(6):
    03EF4: 55 53 42 43  6B 85 59 63  24 00 00 00  80 00 06 12   'USBCk.Yc$.......'
    03F04: 00 00 00 24  00 00 00 01  00 00 00 00  00 00 00 55   '...$...........U'
    Data:
    04705: 00 80 02 02  1F 00 00 00  55 74 31 36  33 20 20 20   '........Ut163   '
    04715: 55 53 42 32  46 6C 61 73  68 53 74 6F  72 61 67 65   'USB2FlashStorage'
    04725: 30 2E 30 30  00 00 00 00  00 00 00 00  00 00 00 00   '0.00............'
    Status:
    03F13: 55 53 42 53  6B 85 59 63  00 00 00 00  00 53 74 61   'USBSk.Yc.....Sta'
    INQUIRY(6): ACK
    Vendor ID: Ut163
    Version level: 0.00
    Media is removable
    READ CAPACITY(10):
    03EF4: 55 53 42 43  C6 A8 A0 E7  08 00 00 00  80 00 0A 25   'USBC...........%'
    03F04: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 55   '...............U'
    Data:
    04804: 00 7A FF FE  00 00 02 00  00 00 00 00  00 00 00 00   '.z..............'
    Status:
    03F13: 55 53 42 53  C6 A8 A0 E7  00 00 00 00  00 53 74 61   'USBS.........Sta'
    READ CAPACITY(10): ACK
    Sector size: 512
    MBR0
    0
    1
    READ(10):
    03EF4: 55 53 42 43  E3 33 2F A3  00 02 00 00  80 00 0A 28   'USBC.3/........('
    03F04: 00 00 00 00  00 00 00 01  00 00 00 00  00 00 00 55   '...............U'
    Data:
    04BD4: FA 33 C0 8E  D0 BC 00 7C  8B F4 50 07  50 1F FB FC   '.3.....|..P.P...'
    04BE4: BF 00 06 B9  00 01 F2 A5  EA 1D 06 00  00 BE BE 07   '................'
    04BF4: B3 04 80 3C  80 74 0E 80  3C 00 75 1C  83 C6 10 FE   '...<.t..<.u.....'
    04C04: CB 75 EF CD  18 8B 14 8B  4C 02 8B EE  83 C6 10 FE   '.u......L.......'
    04C14: CB 74 1A 80  3C 00 74 F4  BE 8B 06 AC  3C 00 74 0B   '.t..<.t.....<.t.'
    04C24: 56 BB 07 00  B4 0E CD 10  5E EB F0 EB  FE BF 05 00   'V.......^.......'
    04C34: BB 00 7C B8  01 02 57 CD  13 5F 73 0C  33 C0 CD 13   '..|...W.._s.3...'
    04C44: 4F 75 ED BE  A3 06 EB D3  BE C2 06 BF  FE 7D 81 3D   'Ou...........}.='
    04C54: 55 AA 75 C7  8B F5 EA 00  7C 00 00 49  6E 76 61 6C   'U.u.....|..Inval'
    04C64: 69 64 20 70  61 72 74 69  74 69 6F 6E  20 74 61 62   'id partition tab'
    04C74: 6C 65 00 45  72 72 6F 72  20 6C 6F 61  64 69 6E 67   'le.Error loading'
    04C84: 20 6F 70 65  72 61 74 69  6E 67 20 73  79 73 74 65   ' operating syste'
    04C94: 6D 00 4D 69  73 73 69 6E  67 20 6F 70  65 72 61 74   'm.Missing operat'
    04CA4: 69 6E 67 20  73 79 73 74  65 6D 00 00  00 00 00 00   'ing system......'
    04CB4: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00   '................'
    04CC4: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00   '................'
    04CD4: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00   '................'
    04CE4: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00   '................'
    04CF4: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00   '................'
    04D04: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00   '................'
    04D14: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00   '................'
    04D24: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00   '................'
    04D34: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00   '................'
    04D44: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00   '................'
    04D54: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00   '................'
    04D64: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00   '................'
    04D74: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00   '................'
    04D84: 00 00 00 00  00 00 00 00  68 A8 A6 B3  00 00 80 01   '........h.......'
    04D94: 01 00 06 FE  7F F4 3F 00  00 00 C0 FF  7A 00 00 00   '......?.....z...'
    04DA4: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00   '................'
    04DB4: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00   '................'
    04DC4: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 55 AA   '..............U.'
    Status:
    03F13: 55 53 42 53  E3 33 2F A3  00 00 00 00  00 53 74 61   'USBS.3/......Sta'
    READ(10): ACK
    Partition BPB
    63
    1
    READ(10):
    03EF4: 55 53 42 43  CB 8A CE 18  00 02 00 00  80 00 0A 28   'USBC...........('
    03F04: 00 00 00 00  3F 00 00 01  00 00 00 00  00 00 00 55   '....?..........U'
    Data:
    04BD4: EB 3C 90 4D  53 44 4F 53  35 2E 30 00  02 80 04 00   '.<.MSDOS5.0.....'
    04BE4: 02 00 02 00  00 F8 F6 00  3F 00 FF 00  3F 00 00 00   '........?...?...'
    04BF4: C0 FF 7A 00  80 00 29 AB  89 A9 F4 4E  4F 20 4E 41   '..z...)....NO NA'
    04C04: 4D 45 20 20  20 20 46 41  54 31 36 20  20 20 33 C9   'ME    FAT16   3.'
    04C14: 8E D1 BC F0  7B 8E D9 B8  00 20 8E C0  FC BD 00 7C   '....{.... .....|'
    04C24: 38 4E 24 7D  24 8B C1 99  E8 3C 01 72  1C 83 EB 3A   '8N$}$....<.r...:'
    04C34: 66 A1 1C 7C  26 66 3B 07  26 8A 57 FC  75 06 80 CA   'f..|&f;.&.W.u...'
    04C44: 02 88 56 02  80 C3 10 73  EB 33 C9 8A  46 10 98 F7   '..V....s.3..F...'
    04C54: 66 16 03 46  1C 13 56 1E  03 46 0E 13  D1 8B 76 11   'f..F..V..F....v.'
    04C64: 60 89 46 FC  89 56 FE B8  20 00 F7 E6  8B 5E 0B 03   '`.F..V.. ....^..'
    04C74: C3 48 F7 F3  01 46 FC 11  4E FE 61 BF  00 00 E8 E6   '.H...F..N.a.....'
    04C84: 00 72 39 26  38 2D 74 17  60 B1 0B BE  A1 7D F3 A6   '.r9&8-t.`....}..'
    04C94: 61 74 32 4E  74 09 83 C7  20 3B FB 72  E6 EB DC A0   'at2Nt... ;.r....'
    04CA4: FB 7D B4 7D  8B F0 AC 98  40 74 0C 48  74 13 B4 0E   '.}.}....@t.Ht...'
    04CB4: BB 07 00 CD  10 EB EF A0  FD 7D EB E6  A0 FC 7D EB   '.........}....}.'
    04CC4: E1 CD 16 CD  19 26 8B 55  1A 52 B0 01  BB 00 00 E8   '.....&.U.R......'
    04CD4: 3B 00 72 E8  5B 8A 56 24  BE 0B 7C 8B  FC C7 46 F0   ';.r.[.V$..|...F.'
    04CE4: 3D 7D C7 46  F4 29 7D 8C  D9 89 4E F2  89 4E F6 C6   '=}.F.)}...N..N..'
    04CF4: 06 96 7D CB  EA 03 00 00  20 0F B6 C8  66 8B 46 F8   '..}..... ...f.F.'
    04D04: 66 03 46 1C  66 8B D0 66  C1 EA 10 EB  5E 0F B6 C8   'f.F.f..f....^...'
    04D14: 4A 4A 8A 46  0D 32 E4 F7  E2 03 46 FC  13 56 FE EB   'JJ.F.2....F..V..'
    04D24: 4A 52 50 06  53 6A 01 6A  10 91 8B 46  18 96 92 33   'JRP.Sj.j...F...3'
    04D34: D2 F7 F6 91  F7 F6 42 87  CA F7 76 1A  8A F2 8A E8   '......B...v.....'
    04D44: C0 CC 02 0A  CC B8 01 02  80 7E 02 0E  75 04 B4 42   '.........~..u..B'
    04D54: 8B F4 8A 56  24 CD 13 61  61 72 0B 40  75 01 42 03   '...V$..aar.@u.B.'
    04D64: 5E 0B 49 75  06 F8 C3 41  BB 00 00 60  66 6A 00 EB   '^.Iu...A...`fj..'
    04D74: B0 42 4F 4F  54 4D 47 52  20 20 20 20  0D 0A 52 65   '.BOOTMGR    ..Re'
    04D84: 6D 6F 76 65  20 64 69 73  6B 73 20 6F  72 20 6F 74   'move disks or ot'
    04D94: 68 65 72 20  6D 65 64 69  61 2E FF 0D  0A 44 69 73   'her media....Dis'
    04DA4: 6B 20 65 72  72 6F 72 FF  0D 0A 50 72  65 73 73 20   'k error...Press '
    04DB4: 61 6E 79 20  6B 65 79 20  74 6F 20 72  65 73 74 61   'any key to resta'
    04DC4: 72 74 0D 0A  00 00 00 00  00 00 00 AC  CB D8 55 AA   'rt............U.'
    Status:
    03F13: 55 53 42 53  CB 8A CE 18  00 00 00 00  00 53 74 61   'USBS.........Sta'
    READ(10): ACK
    HWStack return address:
    00000016
  • Rayman wrote: »
    It's formatted as partition type $06 (FAT16) with a cluster size of 128KB and I currently have the cluster buffer set to a max of 32KB. I did that because FAT32 with 16KB cluster size gets you 64GB+. But since we're testing, I probably should be looking at the extremes, too.
    If you want to test it out, you can change the MAX_CLUSTER_SIZE constant to a max of 128KB and the "boms_cluster_buff" buffer size to MAX_CLUSTER_SIZE and it should enumerate.
    garryj
  • Huh, I thought 32KB was max cluster size. I remember Win95 limited to that. Largest FAT16 volume size was 2 GB.
    "There's no huge amount of massive material
    hidden in the rings that we can't see,
    the rings are almost pure ice."
  • yes, that worked, thanks.
  • garryj: Do you have any guidance for using this in an application?
    I see I can "type" a file, so know I can get access to a file's contents.
    Say I want to open a bmp file and copy contents to RAM.
    Is there an easy way to do that?
  • evanh wrote: »
    Yep, that's still what MS recommends for "maximum compatibility" regarding FAT16.
    garryj
  • Rayman wrote: »
    The TYPE/CAT routine is single-minded, but does show the steps needed to read the directory and access the content of a file. Real fopen() type access is planned, but slow in coming...
    garryj
  • Thanks. I'm still thinking about how I'd use this...
    uSD kindof does the same thing.
    Thumb drives can be bigger in capacity though.
    Harder to break, apparently.
    Easier to handle...
    edited 2019-02-21 - 17:22:33
    How does the read speed compare with usd with spi interface ?
    Only needs 2 pins (instead of 4 for uSD). That can be a big advantage...
  • jmgjmg Posts: 13,462
    Rayman wrote: »
    Did you mean USB vs SPI ?
    USB needs 2 COGs I think, but yes, it can run on just 2 pins.
    Top USB speeds I've seen from PC's are 8~9 MBit/s (ie the 12 MHz minus overheads), which is slower than P2 can run SPI.
  • I bet USB could be made to run in 1 cog.
  • Rayman wrote: »
    Working on it...
    BTW, my head-math sucks -- the cluster size of your RiData drive is 64KB. For what it's worth, this is what MS has to say regarding FAT cluster sizes:
    BPB_SecPerClus (BPB offset 13, one byte):
    Number of sectors per allocation unit. This value must be a power
    of 2 that is greater than 0. The legal values are 1, 2, 4, 8, 16, 32, 64,
    and 128. Note however, that a value should never be used that
    results in a “bytes per cluster” value (BPB_BytsPerSec *
    BPB_SecPerClus) greater than 32K (32 * 1024). There is a
    misconception that values greater than this are OK. Values that
    cause a cluster size greater than 32K bytes do not work properly; do
    not try to define one. Some versions of some systems allow 64K
    bytes per cluster value. Many application setup programs will not
    work correctly on such a FAT volume.
    garryj
  • samuellsamuell Posts: 279
    edited 2019-05-15 - 22:56:13
    Hi all,
    I'm unable to fully test USB, since PNut doesn't run a terminal by itself after the program has been compiled and loaded. My main problem is that Tera Term resets the board and clears the program after PNut, and thus I'm unable to interact with it. I've tried loading the program with spin2gui as an alternative, but it yields compilation errors.
    I'm using the zip file located in this post:
    https://forums.parallax.com/discussion/comment/1462546/#Comment_1462546
    Can anyone instruct me on how to run it? Any help would be appreciated. Thanks in advance!
    Kind regards, Samuel Lourenço
  • I use PST which can be running in another window(suspended when it loses the focus).
    Website: www.clusos.com
  • samuell wrote: »
    What version of spin2gui are you using? I'm able to compile that program just fine with versions 3.9.24 and 3.9.26. There is a warning on line 3400 about a cmp being used without flags, but I think that warning is legitimate (and it is just a warning).
    edited 2019-05-16 - 00:07:53
    ersmith wrote: »
    samuell wrote: »
    Hi ersmith,
    I'm using version 1.3.2, which seems to be much older. I'll upgrade and try the newer version ASAP.
    Update: Compilation issue solved with version 3.9.26. Thanks! Now I have to sort out which baudrate is used.
    edited 2019-05-16 - 13:37:40
    Hi,
    Here is what I got with a SanDisk Ultra pen:
    Vendor ID: SanDisk
    Product ID: Ultra
    Version level: 1.00
    Media is removable
    SCSI version is ANSI X3.131:1994 (SCSI-2) or higher
    Highest LBA: 60062499
    Sector size: 512
    Partition type: 0x0C
    Cluster size: 16384
    Volume base sector: 32
    Reserved sector count: 38
    FSInfo base sector (in reserved): 33
    FAT region base sector: 70
    Sector count of one FAT: 14657
    FAT region sector count: 29314
    RootDir base sector: 29384
    RootDir cluster#: 2
    Dir/file/data base sector: 29384
    Count of data region clusters: 1876034
    Count of free clusters: 1872940
    FSInfo next free cluster: 52516
    Count of data region sectors: 60033116
    Count of volume sectors: 60062468
    FAT32 volume mounted.
    And here is the same test using a SanDisk Cruzer Slice:
    Vendor ID: SanDisk
    Product ID: Cruzer Slice
    Version level: 8.02
    Media is removable
    No data...
    Bulk-IN endpoint STALL...
    SCSI command error: Failed
    ASC: 0x3A, ASCQ: 0x00
    Unit requires attention: medium not present
    And a last one with an unidentified, generic pen:
    Vendor ID: DW
    Product ID: PND1GCBM11013B
    Version level: 4.00
    Media is removable
    Highest LBA: 2045438
    Sector size: 512
    Partition type: 0x0B
    Cluster size: 4096
    Reserved sector count: 36
    FAT region base sector: 68
    Sector count of one FAT: 1994
    FAT region sector count: 3988
    RootDir base sector: 4056
    RootDir cluster#: 2
    Dir/file/data base sector: 4056
    Count of data region clusters: 255172
    Count of free clusters: 252482
    FSInfo next free cluster: 46608
    Count of data region sectors: 2041383
    Count of volume sectors: 2045407
    The mass storage driver seems to work fine for the most part, although only detects a connection on the upper port of the serial host add-on board. I don't know if it is to be expected.
    As for the Cruzer Slice, the pen is formatted and contains no FAT errors. It mounts well on Windows and Linux, so I was not expecting that. The issue is very consistent.
    edited 2019-05-16 - 15:01:36
    Hi,
    Tested the mouse and keyboard driver too, as posted here:
    https://forums.parallax.com/discussion/comment/1462633/#Comment_1462633
    It works great! First I used a wireless mouse to test it, then a wireless keyboard/mouse combo. Here is the output:
    ( Entering terminal mode.  Press Ctrl-] to exit. )
    [2J[HUSB low/full speed minimal host & HID boot protocol keyboard/mouse driver v0.18.
    Debug output to terminal is off.
    Woo-hoo, found a boot mouse!
    Mouse ready...
    Count: 0000000295, Buttons: 00000000, X: +000, Y: -001
    <Device disconnected>.
    <Low-Speed device connected.>
    Woo-hoo, found a boot keyboard!
    Keyboard ready...
    Mouse ready...
    Count: 0000000902, Buttons: 00000000, X: +000, Y: +000defABCDEF
    However, as in the MSC driver, only the upper port works on the add-on board.
  • I'm at a loss as to why the lower port is not working, as that is the one I usually test with:
    ' P2-ES USB Host (Master) x 2 Accessory Board I/O group base pin:
            USB_BASEPIN = 16 ' + offsets for ES-64006 Serial Host board
    '#define USB_PORTB
    #ifndef USB_PORTB ' PortA is the default.
    ' USB "portA" connector pin assignments (lower port):
            HOST_ACTIVE_LED = USB_BASEPIN + 4
    ' USB protection enable/disable
            USB_PROTECT_ON = USB_BASEPIN + 5
    ' Smart pin pair used for the USB transceiver:
            DM = USB_BASEPIN + 6   ' DM is "The Brain"
            DP = USB_BASEPIN + 7   ' DP is passive
    ' Long repository pin#:
            USB_EVENT_REPO = USB_BASEPIN + 8
    ' LED to blink at host/driver fatal error:
            HOST_ERROR_LED = LED56
    #else
    ' USB "portB" connector pin assignments (upper port):
            HOST_ACTIVE_LED = USB_BASEPIN + 0
            USB_PROTECT_ON = USB_BASEPIN + 1
            DM = USB_BASEPIN + 2    ' DM is "The Brain"
            DP = USB_BASEPIN + 3    ' DP is passive
            USB_EVENT_REPO = USB_BASEPIN + 9
            HOST_ERROR_LED = LED57
    #endif
    There are refreshes (hopefully soon) of the "lite" USB keyboard/mouse demo coming: a pure p2asm version and a Spin2 version, which can support more than one USB port.
    garryj
  • samuell wrote: »
    Hi Samuel,
    Just to double check that both power enable pins are getting set; the upper and lower usb sockets each have an ENable pin.
    basepin+1 and basepin+5
    garryj's post/code above includes those, but maybe some older code didn't assert both?
