318MHz Oscillator? — Parallax Forums
318MHz Oscillator?
I'm not an RF guy, so I'm hoping one of my forum friends can help. I'm helping a young colleague with cloning his garage door opening. This system using 318MHz. We don't need a lot of power, just something that can be gated with a small microcontroller.
  • jmgjmg Posts: 15,148
    JonnyMac wrote: »
    If you want to build an oscillator, you could try something like a SAW resonator
    https://www.mouser.com/Search/Refine?Keyword=RO3118
    Or, a more complete cased solution might be what you are looking for ? (something like ?)
    https://www.electrodragon.com/product/remote-controller-315mhz/
  • ercoerco Posts: 20,254
    315 and 433 MHz TxRx pairs are among the cheapest things on Ebay: https://www.ebay.com/itm/263458011149
    Useful info at https://www.romanblack.com/RF/cheapRFmodules.htm
    Perhaps a propeller chip outputting a 106MHz square wave (318MHz is the first odd harmonic) would work. I know a 555 timer would interfere with AM reception due to all those odd harmonics so it might be worth trying.
    edited 2019-04-24 14:33
    You can pickup 318MHz SAW resonators such as the ro3118 from Mouser for around a dollar, just add a couple of transistors and let the pcb track be the antenna.
    Here's a circuit an image of the other side of a SAW resonator pcb I found on the interweb thingy.
    569 x 577 - 69K
  • BeanBean Posts: 8,129
    Jon,
    You might be able to generate a 106MHz squarewave and get enough energy on the third harmonic.
    Bean
  • @Peter: I found that, too, and am probably going that direction as I want to keep the parts count very low -- this is a learning project for my colleague. I wrote the code for an ATtiny85 while he watched and we verified the proper timing with a 'scope.
