Programming Propeller Memory With Prop Powered Down - Page 2 — Parallax Forums
2»
  • TubularTubular Posts: 4,621
    edited 2019-03-19 07:37
    I wonder whether using the 24AA256 (wider voltage range) EEPROM at 1v8 level would be enough to program the EEPROM but not enough to boot the prop.
    I remember from the "Prop Limbo" thread the prop operation cutting out around 1.02V, but that was cutting out -- to boot and get the oscillators running took a higher voltage, like 1.7v from memory, and that might not happen if the ~0.6v body diode drop is factored in
    Another approach would be to put a series resistor on each of SDA and SCL, as well as a load resistor across VDD to VSS of the Prop, so anything parasitic at least has a load to overcome. what pete said
    An interesting requirement...
