P2 Tricks, Traps & Differences between P1 (Reference Material Only)
2»
  • ozpropdev wrote: »
    P2 does have a NOP opcode.
    0000 0000000 000 000000000 000000000        NOP
    Yes, all zeros is a special "NOP" case and is trapped by the silicon, rather than being a ROR instruction. If it wasn't trapped it would be a
    _RET_ ROR 0,0
    which would cause a _RET_ operation following the ROR 0,0 which would have no effect. Wouldn't want that.
    But in P1, anything with the CCCC=0 would become a NOP, so it was often used to hold a smaller variable, or convert an instruction to a NOP.
    Website: www.clusos.com
  • It's not that we don't have a NOP instruction, it's that we don't have a NOP condition.
  • evanhevanh Posts: 6,643
    edited 2019-02-14 - 14:28:12
    It really comes down to COGINIT requiring both a load address of zero and execution to start at zero. ORG has to be aligned to this. If you don't, you make a mess.
    That's why Pasm variables in all Obex programs are at the end.
    PS: You guys are messing up this topic with chatter!
    "There's no huge amount of massive material
    hidden in the rings that we can't see,
    the rings are almost pure ice."
  • msrobotsmsrobots Posts: 2,443
    edited 2019-02-14 - 16:23:53
    I like to reuse the top area in the COG where I normally place my startup code as res variables needed later and to store parameter I got from whoever started my COG.
    On the P2 one can do this very efficient.
    DAT
    cog     long  0
    PUB start(param1, param2, param3, param4)
       stop
       cog := cogstart(@entry, @param1) + 1
    PUB stop
       if cog
         cogstop(cog-1)
    DAT
    entry
            ORG0
    par1    rdlong par1, ptra++
    par2    rdlong par2, ptra++
    par3    rdlong par3, ptra++
    par4    rdlong par4, ptra++
    and now my parameter uses the same cog register used by the instruction needed to load the parameter
    you can't do that shorter,
    Enjoy!
  • Nice one.
  • Cluso99Cluso99 Posts: 14,747
    edited 2019-02-15 - 04:35:26
    Untested, but fairly sure this would work too, and you have 2 instructions to initialise something else.
    DAT
                    org     0
    entry           nop                             ' or something else
                    setq    #4-1
                    rdlong  entry,ptra
    Postedit: fixed setq value
  • It should be "setq #3", since the argument of setq in setq+rdlong is how many extra operations it should do, not the total number.
  • TIMEOUT
    Using the counter for timeouts
    Here is how to setup your own timeout
                    getct   timeout                         '\ set timeout value
                    add     timeout,          ##delay1s     '/
    and code to test if the timeout has been exceeded
                    getct   timenow                         '\ timeout ?
                    cmpm    timeout,          timenow   wc  '| c if timenow > timeout
            if_c    jmp     #timed_out                      '/ y: timed out
    Note the use of the CMPM D,#/S {wc/wz/wcz} instruction!!!
    C = MSB of the result of D-S
  • ozpropdevozpropdev Posts: 2,458
    edited 2019-02-22 - 09:20:41
    Timeouts can also be checked using the pollct instructions
                    addct1     timeout,          ##delay1s     '/
                    pollct1 wc
            if_c    jmp     #timed_out
    Melbourne, Australia
  • Mark_TMark_T Posts: 1,958
    edited 2019-02-28 - 14:04:32
    One gotcha that regularly catches me out is that fastspin doesn't seem to detect duplicate labels as errors - is there a flag for more warnings?
    [ this is fixed in spin2gui release 1.3.9 and later ]
  • Mark_T wrote: »
    That was a bug; I accidentally commented some error detection code out while debugging. It'll be fixed in the next version.
  • I stumbled about another issue, not bad but confusing.
    I can compile a sub-object without errors, but compiling the main object throws then errors in the sub object.
    Maybe you eliminate unused functions to early?
    Enjoy!
  • Okay, no more Fastspin bugs/discussions in this topic please. Pnut is okay because it has been frozen for ages.
  • Tip: use block reads/writes even for 2 longs:
                setq    #2-1
                rdlong  a, PTRA
                add     PTRA, #8
    ' is significantly faster than
                rdlong  a, PTRA++
                rdlong  a+1, PTRA++
    The issue is you only get synchronous access to the hub with block reads/writes, so the latter version has to wait
    7 cycles as it misses the boat on the second read. Block reads and writes run at one long per clock cycle, ie
    two per instruction time.
  • Here is a map of the special registers (P1 & P2 compared)
    ''  <------------- P1 ------------->  register  <--------------- P2 ---------------->
    ''  Boot Parameter              PAR   = $1F0 =  IJMP3  INT3  interrupt call   address
    ''  System Counter              CNT   = $1F1 =  IRET3  INT3  interrupt return address
    ''  Input  States     P31..P0   INA   = $1F2 =  IJMP2  INT2  interrupt call   address
    ''  Input  States     P63..P32  INB   = $1F3 =  IRET2  INT2  interrupt return address
    ''  Output States     P31..P0   OUTA  = $1F4 =  IJMP1  INT1  interrupt call   address
    ''  Output States     P63..P32  OUTB  = $1F5 =  IRET1  INT1  interrupt return address
    ''  Output Enables    P31..P0   DIRA  = $1F6 =  PA     CALLD/CALLPA/LOC
    ''  Output Enables    P63..P32  DIRB  = $1F7 =  PB     CALLD/CALLPB/LOC
    ''  Counter A Control           CTRA  = $1F8 =  PTRA   pointer A to hub RAM
    ''  Counter B Control           CTRB  = $1F9 =  PTRB   pointer B to hub RAM
    ''  Counter A Frequency         FRQA  = $1FA =  DIRA   P31..P0  Output Enables
    ''  Counter B Frequency         FRQB  = $1FB =  DIRB   P63..P32 Output Enables
    ''  Counter A Phase             PHSA  = $1FC =  OUTA   P31..P0  Output States
    ''  Counter B Phase             PHSB  = $1FD =  OUTB   P63..P32 Output States
    ''  Video Configuration         VCFG  = $1FE =  INA    P31..P0  Input  States  *
    ''  Video Scale                 VSCL  = $1FF =  INB    P63..P32 Input  States  **
  • Here is a pointer to a discussion of using smart pin mode 00100 (pulse out): (click here)
    Re-inventing the wheel is not a waste of time if, when you are done, you understand why it is round.
  • A trap I ran across: the "altr" setting for writing to the result register (and presumably similar settings like "altd" and "alts") is destroyed by the "aug" prefix. So for example:
       altr 0, #A
       add B, #1
    puts B+1 into A, but:
       altr 0, #A
       add B, ##1
    puts B+1 into B (!). I thought of breaking the "add B, ##1" apart into an explicit aug+add and putting the altr between them, but since the altr uses an immediate that probably will fail too.
    There are work-arounds, but it's something to watch out for.
    edited 2019-03-10 - 04:17:58
    A small defect with system clock setting got past the P2ES testing undetected. For clock config word, %0000_xxxE_DDDD_DDMM_MMMM_MMMM_PPPP_CCSS, if a PLL mode is configured with %PPPP = %1111 (_XDIVP = 1) there is a possibility of crashing if attempting to readjust the clock without knowing the exact config it is in.
    The solution for reliable operation into the future is to maintain a universal reserved hubRAM location containing a copy of the most recently issued config. That location is currently set as byte addresses $18 to $1b. Little-endian.
    Here is sample code for basic startup that includes the ability for a boot-loader to specify what config it has already set.
    CON
    	XTALFREQ	= 20_000_000                              'PLL stage 0: crystal frequency
    	XDIV		= 2                                       'PLL stage 1: crystal divider
    	XMUL		= 25                                      'PLL stage 2: crystal / div * mul
    	XDIVP		= 1                                       'PLL stage 3: crystal / div * mul / divp (1,2,4..30)
    	XOSC		= %10                             'OSC    ' %00=OFF, %01=OSC, %10=15pF, %11=30pF
    	XSEL		= %11                             'XI+PLL ' %00=rcfast(20+MHz), %01=rcslow(~20KHz), %10=XI(5ms), %11=XI+PLL(10ms)
    	XPPPP		= ((XDIVP>>1) + 15) & $F                  ' 1->15, 2->0, 4->1, 6->2...30->14
    	CLOCKFREQ	= XTALFREQ / XDIV * XMUL / XDIVP
    	SETFREQ		= 1<<24 + (XDIV-1)<<18 + (XMUL-1)<<8 + XPPPP<<4 + XOSC<<2
    	ENAFREQ		= SETFREQ + XSEL                          ' %0000_000e_dddddd_mmmmmmmmmm_pppp_cc_ss  ' enable oscillator
    DAT						'not Spin code
    ORGH  0						'loaded to hubram at address 0
    ORG						'longword addressing at 0
    		jmp     #_init
    		long	0,0,0
    '***  Boot-loader can fill all four of the following  ***
    spare1		long	0			'hubRAM addr $010 - compatible reserved for system variable
    clk_freq	long	CLOCKFREQ		'hubRAM addr $014 - sysclock frequency, integer frequency in hertz
    clk_mode	long	0			'hubRAM addr $018 - clock mode config word, used directly in HUBSET
    asyn_baud	long	BAUDRATE		'hubRAM addr $01c - comport baud rate, integer baud in hertz
    _init
    		hubset	clk_mode		'switch to RCFAST using known prior mode
    		mov	clk_mode, ##SETFREQ	'replace old with new
    		hubset	clk_mode		'setup for new mode, still RCFAST
    		waitx	##20_000_000/100	'~10ms for crystal/PLL to come up to speed
    		hubset	##ENAFREQ		'engage
    EDIT: Ditched all the underscores in the constants to avoid Pnut symbol naming conflict.
    EDIT2: Improved comments of system variables
  • Nice example, @evanh!
    But PNut throws the error "_CLKFREQ/_XINFREQ specified without _CLKMODE". So it looks like these three words may be reserved.
    garryj
  • clk_freq long _CLKFREQ 'hubRAM addr $014 - integer frequency in hertz
    should be _CLOCKFREQ
  • If using COGATN for synchronisation it's useful to know that the sender cog completes the COGATN instruction two sysclocks earlier than the WAITATN in the receiving cogs.
  • Here is a pointer to incmod: click here
  • I do not believe I am the only follower of this thread who had not seen (or perhaps forgot about) this description of all the P2 Instructions. click here
