P1 Spin Interpreter for P2
Cluso99Cluso99 Posts: 14,747
edited 2019-03-01 - 17:47:40 in Propeller 2
I started from scratch again in converting my faster P1 spin interpreter to run on P2.
What i am after is to run P1 compiled spin on the P2. There will be some things it cannot do such as videeo (waitvid) and some of the timer hardware differences, but overall most code should work.
So, let’s look at the makeup of hub code for the P1 object... (P1 spin on P2 will only use the bottom 64KB of HUB)
$0000(4) clockfreq - initially jump over spin code then updated to clockfreq
$0004(1) clockmode - not used
$0005(1) checksum - not used
$0006(...) spin code - same
* My P2 interpreter uses COG & LUT for extra speed
* PTRA & PTRB are used for pcurr and dcurr respectively
Currently how this works is P1 compiled spin bytecode is copied into the P2 source as bytes with the first 4 bytes replaced with a jump over the bytecode. The bottom 64KB will be reserved for P1 spin bytecode and interpreter.
Website: www.clusos.com
  • Cluso99 wrote: »
    How were you going to handle PASM? Were you going to translate that from P1 to P2 in your compiler? And which compiler were you going to use?
    Just out of curiousity, are you doing this for fun (totally understandable) and/or "because it's there", or do you have a specific use case in mind? If the latter, have you looked at fastspin? It can already compile most P1 Spin programs (the Spin part, that is; I don't try to translate PASM). If we combined that with a P1 PASM to P2 PASM translator would that do everything you want?
    Eric
  • 1. It’s fun and because i did it for P1 but it never got used
    2. Because i can run P1 spin code
    I am using pre-compiled P1 binaries. I’ve converted my P1 PASM (my Interpreter) to P2. So I am not using any new compilers for the P1 spin.
    However, maybe I should take a look at fastspin. Might be fun too :smile:
  • Cluso99 wrote: »
    Ah, so your pre-compiled P1 binaries do not have any PASM baked into their DAT sections? Then I guess you should be good to go, once the interpreter is up. Have fun!
    (And if you do want to try out fastspin on your Spin code, there are options to compile the binaries to run at different base addresses, so that one program can load another. IIRC one of your use-cases was a small operating system that loads programs from disk, so that might be a way to achieve that.)
  • Yes. I am interpreting P1 bytecode. So I’ll have a 64KB HUB RAM P1 spin interpreter running at P2 speeds.
    I can (and have) put debug code into the interpreter to output (using the ROM Monitor) to display variables etc at certain points in the interpreter.
    It’s amazing how much code space i saved when converting pasm from p1 to p2. Those ptra++ and —ptrb save quite a bit on their own :smiley:
    And yes, another reason is for my OS on SD :smile:
  • Cluso99Cluso99 Posts: 14,747
    edited 2019-03-03 - 14:24:24
    Today...
    I translated the DIRx/OUTx/INx registers and implemented PAR and CNT. The pin registers work for both ports A and B.
    I rewrote FILL/MOVE bytecodes using REP.
    I rewrote the maths routines to use skipf. Wow, what a boost this will be, and much less code too. Its not tested yet though.
    BTW we have an extra bytecode available since we don’t have WAITVID, and $3C was unused too.
    I looked at XBYTE but not for me just yet anyway.
    Might be worth taking a look at openspin with a view to changing the DIR/OUT/IN register addresses, and removing CTR/FRQ/PHS/VID registers and WAITVID to output compiled spin1 for P2. Probably a minor change to highlight errors. I wonder if P2ASM could co-exist with OpenSpin?
  • roglohrogloh Posts: 987
    edited 2019-03-04 - 01:03:17
    Sounds pretty good Cluso. I wonder if it makes sense to somehow hook the now unused WAITVID in your custom SPIN interpreter to become some custom type of breakpoint instruction (and its args could also optionally provide two parameters to a debugger, like a string to print, and/or a variable to log etc). I could see it could be handy to debug generic SPIN code without embedded P1 PASM on the P2, assuming some additional support is put in for debugging SPIN code.
  • rogloh wrote: »
    Actually I am debugging it with calls inserted into the spin interpreter to output serial messages using the ROM Monitor. Some of those messages pause for serial entry (just a cr) and I also call the monitor too, and return.
    I haven't played with the inbuilt debugger on the P2 yet.
    I keep finding new instruction toys in P2 :smiley:
    I used skip in the ROM SD so I have coded the maths ops in the interpreter to use these extensively.
  • oh yes @Cluso99, please, please
    write down some simple example how to use Monitor/Debugger.
  • thanks
  • Originally posted these code blocks over on the SKIPF, EXECF & XBYTE thread. That was a mistake so I am transferring here in the following posts.
    edited 2019-03-09 - 06:52:56
    I thought I'd post my skipf routines for my P2 SpinInterpreter of P1 here. :smiley:
    They are currently untested. If you see any holes/bugs please comment ;)
    Just realised there is an error in some skipf values. The top 1's need to be 0's once all required instructions are skipped
    Here are the VAR bytecodes
    '  %    $40..7F  Variable operation                                           %
    '                                .---v---v---v---v---v---v---v---.  These opcodes allow fast access by making long access
    '$40-7F Fast access VAR, LOC     | 0   1 | w | v   v   v | o   o |  to the first few long entries in the variable space
    '                                `---^---^---^---^---^---^---^---'  or stack a single byte opcode. The single byte opcodes
    '                                          |       |         |      are effectively expanded within the interpreter...
    '                                      0= VAR    Address    00= PUSH   Read  - push result in stack
    '                                      1= LOC  (adr = v*4)  01= POP    Write - pop value from stack
    '                                          |       |        10= USING  2nd opcode (assignment) executed, result in target
    '                                          |       |        11= PUSH # Push address of destination into stack
    '                                .---v---v---v---v---v---v---v---.  .---v---v---v---v---v---v---v---.
    '                                | 1 | 1   0 | 0 | 1   w | o   o |  | 0   0   0 | v   v   v | 0   0 |
    '        ADR
    '                                                           VAR   xxx    PUSH   $%00_0000_0000_1111_1100_1000
    '                                                            "     "     POP    $%00_0000_0000_1111_0011_1000
    '                                                            "     "     ASGN   $%00_0000_0000_1100_1111_1000  ??????????
    '                                                            "     "     PUSH#  $%00_0000_0000_0011_1111_1000
    '                                                           LOC   xxx    PUSH   $%00_0000_0000_1111_1100_0100
    '                                                            "     "     POP    $%00_0000_0000_1111_0011_0100
    '                                                            "     "     ASGN   $%00_0000_0000_1100_1111_0100  ??????????
    '                                                            "     "     PUSH#  $%00_0000_0000_0011_1111_0100
    'varop
    {adr}                   mov     adr,op                  '\ isolate adr          $%--_----_----_----_----_---0
                            and     adr,#%00011100          '/  adr=n*4             $%--_----_----_----_----_--0-
    {+base}                 add     adr,vbase               '  VAR: +base           $%--_----_----_----_----_-0--
                            add     adr,dbase               '  LOC: +base           $%--_----_----_----_----_0---
    {read var}              rdlong  x,adr                   '\ PUSH: read var       $%--_----_----_----_---0_----
    {push var}              wrlong  x,ptrb++                '/        & push        $%--_----_----_----_--0-_----
    {pop var}               rdlong  x,--ptrb                '\ POP:  pop var        $%--_----_----_----_-0--_----
    {write var}             wrlong  x,adr                   '/       & write        $%--_----_----_----_0---_----
                            nop                             '\ ASGN:                $%--_----_----_---0_----_----  ??????????
                            nop                             '/                      $%--_----_----_--0-_----_----  ??????????
                            and     x,maskword              '\ PUSH#: mask adr      $%--_----_----_-0--_----_----
    {push adr}              wrlong  adr,ptrb++              '/        & push        $%--_----_----_0---_----_----
                            jmp     #loop                   '
    and the table
      long $%00_0000_0000_1111_1100_1000 <<10 +varop     '$40  VAR  PUSH    addr=0*4= 00
      long $%00_0000_0000_1111_0011_1000 <<10 +varop     '$41  VAR  POP     addr=0*4= 00
      long $%00_0000_0000_1100_1111_1000 <<10 +varop     '$42  VAR  USING   addr=0*4= 00
      long $%00_0000_0000_0011_1111_1000 <<10 +varop     '$43  VAR  PUSH #  addr=0*4= 00
      long $%00_0000_0000_1111_1100_1000 <<10 +varop     '$44  VAR  PUSH    addr=1*4= 04
      long $%00_0000_0000_1111_0011_1000 <<10 +varop     '$45  VAR  POP     addr=1*4= 04
      long $%00_0000_0000_1100_1111_1000 <<10 +varop     '$46  VAR  USING   addr=1*4= 04
      long $%00_0000_0000_0011_1111_1000 <<10 +varop     '$47  VAR  PUSH #  addr=1*4= 04
      long $%00_0000_0000_1111_1100_1000 <<10 +varop     '$48  VAR  PUSH    addr=2*4= 08
      long $%00_0000_0000_1111_0011_1000 <<10 +varop     '$49  VAR  POP     addr=2*4= 08
      long $%00_0000_0000_1100_1111_1000 <<10 +varop     '$4A  VAR  USING   addr=2*4= 08
      long $%00_0000_0000_0011_1111_1000 <<10 +varop     '$4B  VAR  PUSH #  addr=2*4= 08
      long $%00_0000_0000_1111_1100_1000 <<10 +varop     '$4C  VAR  PUSH    addr=3*4= 0C
      long $%00_0000_0000_1111_0011_1000 <<10 +varop     '$4D  VAR  POP     addr=3*4= 0C
      long $%00_0000_0000_1100_1111_1000 <<10 +varop     '$4E  VAR  USING   addr=3*4= 0C
      long $%00_0000_0000_0011_1111_1000 <<10 +varop     '$4F  VAR  PUSH #  addr=3*4= 0C
      long $%00_0000_0000_1111_1100_1000 <<10 +varop     '$50  VAR  PUSH    addr=4*4= 10
      long $%00_0000_0000_1111_0011_1000 <<10 +varop     '$51  VAR  POP     addr=4*4= 10
      long $%00_0000_0000_1100_1111_1000 <<10 +varop     '$52  VAR  USING   addr=4*4= 10
      long $%00_0000_0000_0011_1111_1000 <<10 +varop     '$53  VAR  PUSH #  addr=4*4= 10
      long $%00_0000_0000_1111_1100_1000 <<10 +varop     '$54  VAR  PUSH    addr=5*4= 14
      long $%00_0000_0000_1111_0011_1000 <<10 +varop     '$55  VAR  POP     addr=5*4= 14
      long $%00_0000_0000_1100_1111_1000 <<10 +varop     '$56  VAR  USING   addr=5*4= 14
      long $%00_0000_0000_0011_1111_1000 <<10 +varop     '$57  VAR  PUSH #  addr=5*4= 14
      long $%00_0000_0000_1111_1100_1000 <<10 +varop     '$58  VAR  PUSH    addr=6*4= 18
      long $%00_0000_0000_1111_0011_1000 <<10 +varop     '$59  VAR  POP     addr=6*4= 18
      long $%00_0000_0000_1100_1111_1000 <<10 +varop     '$5A  VAR  USING   addr=6*4= 18
      long $%00_0000_0000_0011_1111_1000 <<10 +varop     '$5B  VAR  PUSH #  addr=6*4= 18
      long $%00_0000_0000_1111_1100_1000 <<10 +varop     '$5C  VAR  PUSH    addr=7*4= 1C
      long $%00_0000_0000_1111_0011_1000 <<10 +varop     '$5D  VAR  POP     addr=7*4= 1C
      long $%00_0000_0000_1100_1111_1000 <<10 +varop     '$5E  VAR  USING   addr=7*4= 1C
      long $%00_0000_0000_0011_1111_1000 <<10 +varop     '$5F  VAR  PUSH #  addr=7*4= 1C
      long $%00_0000_0000_1111_1100_0100 <<10 +varop     '$60  LOC  PUSH    addr=0*4= 00
      long $%00_0000_0000_1111_0011_0100 <<10 +varop     '$61  LOC  POP     addr=0*4= 00
      long $%00_0000_0000_1100_1111_0100 <<10 +varop     '$62  LOC  USING   addr=0*4= 00
      long $%00_0000_0000_0011_1111_0100 <<10 +varop     '$63  LOC  PUSH #  addr=0*4= 00
      long $%00_0000_0000_1111_1100_0100 <<10 +varop     '$64  LOC  PUSH    addr=1*4= 04
      long $%00_0000_0000_1111_0011_0100 <<10 +varop     '$65  LOC  POP     addr=1*4= 04
      long $%00_0000_0000_1100_1111_0100 <<10 +varop     '$66  LOC  USING   addr=1*4= 04
      long $%00_0000_0000_0011_1111_0100 <<10 +varop     '$67  LOC  PUSH #  addr=1*4= 04
      long $%00_0000_0000_1111_1100_0100 <<10 +varop     '$68  LOC  PUSH    addr=2*4= 08
      long $%00_0000_0000_1111_0011_0100 <<10 +varop     '$69  LOC  POP     addr=2*4= 08
      long $%00_0000_0000_1100_1111_0100 <<10 +varop     '$6A  LOC  USING   addr=2*4= 08
      long $%00_0000_0000_0011_1111_0100 <<10 +varop     '$6B  LOC  PUSH #  addr=2*4= 08
      long $%00_0000_0000_1111_1100_0100 <<10 +varop     '$6C  LOC  PUSH    addr=3*4= 0C
      long $%00_0000_0000_1111_0011_0100 <<10 +varop     '$6D  LOC  POP     addr=3*4= 0C
      long $%00_0000_0000_1100_1111_0100 <<10 +varop     '$6E  LOC  USING   addr=3*4= 0C
      long $%00_0000_0000_0011_1111_0100 <<10 +varop     '$6F  LOC  PUSH #  addr=3*4= 0C
      long $%00_0000_0000_1111_1100_0100 <<10 +varop     '$70  LOC  PUSH    addr=4*4= 10
      long $%00_0000_0000_1111_0011_0100 <<10 +varop     '$71  LOC  POP     addr=4*4= 10
      long $%00_0000_0000_1100_1111_0100 <<10 +varop     '$72  LOC  USING   addr=4*4= 10
      long $%00_0000_0000_0011_1111_0100 <<10 +varop     '$73  LOC  PUSH #  addr=4*4= 10
      long $%00_0000_0000_1111_1100_0100 <<10 +varop     '$74  LOC  PUSH    addr=5*4= 14
      long $%00_0000_0000_1111_0011_0100 <<10 +varop     '$75  LOC  POP     addr=5*4= 14
      long $%00_0000_0000_1100_1111_0100 <<10 +varop     '$76  LOC  USING   addr=5*4= 14
      long $%00_0000_0000_0011_1111_0100 <<10 +varop     '$77  LOC  PUSH #  addr=5*4= 14
      long $%00_0000_0000_1111_1100_0100 <<10 +varop     '$78  LOC  PUSH    addr=6*4= 18
      long $%00_0000_0000_1111_0011_0100 <<10 +varop     '$79  LOC  POP     addr=6*4= 18
      long $%00_0000_0000_1100_1111_0100 <<10 +varop     '$7A  LOC  USING   addr=6*4= 18
      long $%00_0000_0000_0011_1111_0100 <<10 +varop     '$7B  LOC  PUSH #  addr=6*4= 18
      long $%00_0000_0000_1111_1100_0100 <<10 +varop     '$7C  LOC  PUSH    addr=7*4= 1C
      long $%00_0000_0000_1111_0011_0100 <<10 +varop     '$7D  LOC  POP     addr=7*4= 1C
      long $%00_0000_0000_1100_1111_0100 <<10 +varop     '$7E  LOC  USING   addr=7*4= 1C
      long $%00_0000_0000_0011_1111_0100 <<10 +varop     '$7F  LOC  PUSH #  addr=7*4= 1C
  • Here are the MEM/OBJ/VAT/LOC bytecodes
    '  %    $80-DF  Memory operation                                              %
    '$80-DF Access MEM, OBJ,         | 1 | s   s | i | w   w | o   o |  (96 stack load / save opcodes)
    '           VAR and LOC          `---^---^---^---^---^---^---^---'
    '                                    00= Byte  |     |      00= PUSH   Read  - push result in stack
    '                                    01= Word  |     |      01= POP    Write - pop value from stack
    '                                    10= Long  |     |      10= USING  2nd opcode (assignment) executed, result in target
    '                                 (11= mathop) |     |      11= PUSH # Push address of destination into stack
    '                                              |  00= MEM  base popped from stack, if i=1 add offset
    '                                              |  01= OBJ  base is object base   , if i=1 add offset
    '                                              |  10= VAR  base is variable base , if i=1 add offset
    '                                              |  11= LOC  base is stack base    , if i=1 add offset
    '                                             0= no offset
    '                                             1=[]= add offset (indexed)
    '                               {+index}                'INDEX: pop/scale/+     $%--_----_----_----_--0-_-000
    '                               {pop  adr}              'MEM:   pop adr         $%--_----_----_----_----_0---
    '                               {read adr}              'OBJ:   read adr+pbase  $%--_----_----_----_-0-0_----
    '                               {read adr}              'VAR:   read adr+vbase  $%--_----_----_----_0--0_----
    '                               {read adr}              'LOC:   read adr+dbase  $%--_----_----_---0_---0_----
    '                               {read  var byte}        'PUSH:  read byte       $%--_----_----_--0-_----_----
    '                               {write var byte}        'POP:   write byte      $%--_----_-0--_----_----_----
    '                               {read  var word}        'PUSH:  read word       $%--_----_----_-0--_----_----
    '                               {write var word}        'POP:   write word      $%--_----_0---_----_----_----
    '                               {read  var long}        'PUSH:  read long       $%--_----_----_0---_----_----
    '                               {write var long}        'POP:   write long      $%--_---0_----_----_----_----
    '                               {assign}                'ASGN:                  $%--_-00-_----_----_----_----  ??????????
    memop
    {pop index}             rdlong  x,--ptrb                '\ INDEX: pop           $%--_----_----_----_----_---0
     { & scale}             shl     x,#1                    '|   & scale            $%--_----_----_----_----_--0-
                            shl     x,#2                    '/                      $%--_----_----_----_----_-0--
    {pop adr}               rdlong  adr,--ptrb              'MEM: pop adr           $%--_----_----_----_----_0---
    {read adr}              call    #\read_adr              'OBJ/VAR/LOC: read adr  $%--_----_----_----_---0_----
    {+index}                add     adr,x                   'INDEX: +index          $%--_----_----_----_--0-_----
    {+base}                 add     adr,pbase               'OBJ: +pbase            $%--_----_----_----_-0--_----
                            add     adr,vbase               'VAR: +vbase            $%--_----_----_----_0---_----
                            add     adr,dbase               'LOC: +dbase            $%--_----_----_---0_----_----
    {read var}              rdbyte  x,adr                   '\ PUSH: read byte      $%--_----_----_--0-_----_----
                            rdword  x,adr                   '|       read word      $%--_----_----_-0--_----_----
                            rdlong  x,adr                   '|       read long      $%--_----_----_0---_----_----
    {push var}              wrlong  x,ptrb++                '/     & push result    $%--_----_---0_----_----_----
    {pop var}               rdlong  x,--ptrb                '\ POP: pop value       $%--_----_--0-_----_----_----
    {write var}             wrbyte  x,adr                   '|    & write byte      $%--_----_-0--_----_----_----
                            wrword  x,adr                   '|      write word      $%--_----_0---_----_----_----
                            wrlong  x,adr                   '/      write long      $%--_---0_----_----_----_----
    {assign}                nop                             '\ ASGN:                $%--_--0-_----_----_----_----  ??????????
                            nop                             '/                      $%--_-0--_----_----_----_----  ??????????
    {push address}          and     adr,maskword            '\ PUSH#: mask          $%--_0---_----_----_----_----
                            wrlong  adr,ptrb++              '/      & push adr      $%-0_----_----_----_----_----
                            jmp     #loop
  • and the MEM/OBJ/VAT/LOC table
      long $%11_1111_1110_1101_1111_0111 <<10 +memop     '$80  Byte      MEM  PUSH
      long $%11_1111_1001_1111_1111_0111 <<10 +memop     '$81  Byte      MEM  POP
      long $%11_1001_1111_1111_1111_0111 <<10 +memop     '$82  Byte      MEM  USING      ??????????
      long $%10_0111_1111_1111_1111_0111 <<10 +memop     '$83  Byte      MEM  PUSH #
      long $%11_1111_1110_1101_1010_1111 <<10 +memop     '$84  Byte      OBJ  PUSH
      long $%11_1111_1001_1111_1010_1111 <<10 +memop     '$85  Byte      OBJ  POP
      long $%11_1001_1111_1111_1010_1111 <<10 +memop     '$86  Byte      OBJ  USING      ??????????
      long $%10_0111_1111_1111_1010_1111 <<10 +memop     '$87  Byte      OBJ  PUSH #
      long $%11_1111_1110_1101_0110_1111 <<10 +memop     '$88  Byte      VAR  PUSH
      long $%11_1111_1001_1111_0110_1111 <<10 +memop     '$89  Byte      VAR  POP
      long $%11_1001_1111_1111_0110_1111 <<10 +memop     '$8A  Byte      VAR  USING      ??????????
      long $%10_0111_1111_1111_0110_1111 <<10 +memop     '$8B  Byte      VAR  PUSH #
      long $%11_1111_1110_1100_1110_1111 <<10 +memop     '$8C  Byte      LOC  PUSH
      long $%11_1111_1001_1110_1110_1111 <<10 +memop     '$8D  Byte      LOC  POP
      long $%11_1001_1111_1110_1110_1111 <<10 +memop     '$8E  Byte      LOC  USING      ??????????
      long $%10_0111_1111_1110_1110_1111 <<10 +memop     '$8F  Byte      LOC  PUSH #
      long $%11_1111_1110_1101_1101_0000 <<10 +memop     '$90  Byte  []  MEM  PUSH
      long $%11_1111_1001_1111_1101_0000 <<10 +memop     '$91  Byte  []  MEM  POP
      long $%11_1001_1111_1111_1101_0000 <<10 +memop     '$92  Byte  []  MEM  USING      ??????????
      long $%10_0111_1111_1111_1101_0000 <<10 +memop     '$93  Byte  []  MEM  PUSH #
      long $%11_1111_1110_1101_1000_1000 <<10 +memop     '$94  Byte  []  OBJ  PUSH
      long $%11_1111_1001_1111_1000_1000 <<10 +memop     '$95  Byte  []  OBJ  POP
      long $%11_1001_1111_1111_1000_1000 <<10 +memop     '$96  Byte  []  OBJ  USING      ??????????
      long $%10_0111_1111_1111_1000_1000 <<10 +memop     '$97  Byte  []  OBJ  PUSH #
      long $%11_1111_1110_1101_0100_1000 <<10 +memop     '$98  Byte  []  VAR  PUSH
      long $%11_1111_1001_1111_0100_1000 <<10 +memop     '$99  Byte  []  VAR  POP
      long $%11_1001_1111_1111_0100_1000 <<10 +memop     '$9A  Byte  []  VAR  USING      ??????????
      long $%10_0111_1111_1111_0100_1000 <<10 +memop     '$9B  Byte  []  VAR  PUSH #
      long $%11_1111_1110_1100_1100_1000 <<10 +memop     '$9C  Byte  []  LOC  PUSH
      long $%11_1111_1001_1110_1100_1000 <<10 +memop     '$9D  Byte  []  LOC  POP
      long $%11_1001_1111_1110_1100_1000 <<10 +memop     '$9E  Byte  []  LOC  USING      ??????????
      long $%10_0111_1111_1110_1100_1000 <<10 +memop     '$9F  Byte  []  LOC  PUSH #
      long $%11_1111_1110_1011_1111_0111 <<10 +memop     '$A0  Word      MEM  PUSH
      long $%11_1111_0101_1111_1111_0111 <<10 +memop     '$A1  Word      MEM  POP
      long $%11_1001_1111_1111_1111_0111 <<10 +memop     '$A2  Word      MEM  USING      ??????????
      long $%10_0111_1111_1111_1111_0111 <<10 +memop     '$A3  Word      MEM  PUSH #
      long $%11_1111_1110_1011_1010_1111 <<10 +memop     '$A4  Word      OBJ  PUSH
      long $%11_1111_0101_1111_1010_1111 <<10 +memop     '$A5  Word      OBJ  POP
      long $%11_1001_1111_1111_1010_1111 <<10 +memop     '$A6  Word      OBJ  USING      ??????????
      long $%10_0111_1111_1111_1010_1111 <<10 +memop     '$A7  Word      OBJ  PUSH #
      long $%11_1111_1110_1011_0110_1111 <<10 +memop     '$A8  Word      VAR  PUSH
      long $%11_1111_0101_1111_0110_1111 <<10 +memop     '$A9  Word      VAR  POP
      long $%11_1001_1111_1111_0110_1111 <<10 +memop     '$AA  Word      VAR  USING      ??????????
      long $%10_0111_1111_1111_0110_1111 <<10 +memop     '$AB  Word      VAR  PUSH #
      long $%11_1111_1110_1010_1110_1111 <<10 +memop     '$AC  Word      LOC  PUSH
      long $%11_1111_0101_1110_1110_1111 <<10 +memop     '$AD  Word      LOC  POP
      long $%11_1001_1111_1110_1110_1111 <<10 +memop     '$AE  Word      LOC  USING      ??????????
      long $%10_0111_1111_1110_1110_1111 <<10 +memop     '$AF  Word      LOC  PUSH #
      long $%11_1111_1110_1111_1101_0000 <<10 +memop     '$B0  Word  []  MEM  PUSH
      long $%11_1111_1101_1111_1101_0000 <<10 +memop     '$B1  Word  []  MEM  POP
      long $%11_1001_1111_1111_1101_0000 <<10 +memop     '$B2  Word  []  MEM  USING      ??????????
      long $%10_0111_1111_1111_1101_0000 <<10 +memop     '$B3  Word  []  MEM  PUSH #
      long $%11_1111_1110_1111_1000_1000 <<10 +memop     '$B4  Word  []  OBJ  PUSH
      long $%11_1111_1101_1111_1000_1000 <<10 +memop     '$B5  Word  []  OBJ  POP
      long $%11_1001_1111_1111_1000_1000 <<10 +memop     '$B6  Word  []  OBJ  USING      ??????????
      long $%10_0111_1111_1111_1000_1000 <<10 +memop     '$B7  Word  []  OBJ  PUSH #
      long $%11_1111_1110_1111_0100_1000 <<10 +memop     '$B8  Word  []  VAR  PUSH
      long $%11_1111_1101_1111_0100_1000 <<10 +memop     '$B9  Word  []  VAR  POP
      long $%11_1001_1111_1111_0100_1000 <<10 +memop     '$BA  Word  []  VAR  USING      ??????????
      long $%10_0111_1111_1111_0100_1000 <<10 +memop     '$BB  Word  []  VAR  PUSH #
      long $%11_1111_1110_1110_1100_1000 <<10 +memop     '$BC  Word  []  LOC  PUSH
      long $%11_1111_1101_1110_1100_1000 <<10 +memop     '$BD  Word  []  LOC  POP
      long $%11_1001_1111_1110_1100_1000 <<10 +memop     '$BE  Word  []  LOC  USING      ??????????
      long $%10_0111_1111_1110_1100_1000 <<10 +memop     '$BF  Word  []  LOC  PUSH #
      long $%11_1111_1110_0111_1111_0111 <<10 +memop     '$C0  Long      MEM  PUSH
      long $%11_1110_1101_1111_1111_0111 <<10 +memop     '$C1  Long      MEM  POP
      long $%11_1001_1111_1111_1111_0111 <<10 +memop     '$C2  Long      MEM  USING      ??????????
      long $%10_0111_1111_1111_1111_0111 <<10 +memop     '$C3  Long      MEM  PUSH #
      long $%11_1111_1110_0111_1010_1111 <<10 +memop     '$C4  Long      OBJ  PUSH
      long $%11_1110_1101_1111_1010_1111 <<10 +memop     '$C5  Long      OBJ  POP
      long $%11_1001_1111_1111_1010_1111 <<10 +memop     '$C6  Long      OBJ  USING      ??????????
      long $%10_0111_1111_1111_1010_1111 <<10 +memop     '$C7  Long      OBJ  PUSH #
      long $%11_1111_1110_0111_0110_1111 <<10 +memop     '$C8  Long      VAR  PUSH    \ see also $40-7F bytecodes
      long $%11_1110_1101_1111_0110_1111 <<10 +memop     '$C9  Long      VAR  POP     |
      long $%11_1001_1111_1111_0110_1111 <<10 +memop     '$CA  Long      VAR  USING   |  ??????????
      long $%10_0111_1111_1111_0110_1111 <<10 +memop     '$CB  Long      VAR  PUSH #  |
      long $%11_1111_1110_0110_1110_1111 <<10 +memop     '$CC  Long      LOC  PUSH    |
      long $%11_1110_1101_1110_1110_1111 <<10 +memop     '$CD  Long      LOC  POP     |
      long $%11_1001_1111_1110_1110_1111 <<10 +memop     '$CE  Long      LOC  USING   |  ??????????
      long $%10_0111_1111_1110_1110_1111 <<10 +memop     '$CF  Long      LOC  PUSH #  /
      long $%11_1111_1110_0111_1101_0000 <<10 +memop     '$D0  Long  []  MEM  PUSH
      long $%11_1110_1101_1111_1101_0000 <<10 +memop     '$D1  Long  []  MEM  POP
      long $%11_1001_1111_1111_1101_0000 <<10 +memop     '$D2  Long  []  MEM  USING      ??????????
      long $%10_0111_1111_1111_1101_0000 <<10 +memop     '$D3  Long  []  MEM  PUSH #
      long $%11_1111_1110_0111_1000_1000 <<10 +memop     '$D4  Long  []  OBJ  PUSH
      long $%11_1110_1101_1111_1000_1000 <<10 +memop     '$D5  Long  []  OBJ  POP
      long $%11_1001_1111_1111_1000_1000 <<10 +memop     '$D6  Long  []  OBJ  USING      ??????????
      long $%10_0111_1111_1111_1000_1000 <<10 +memop     '$D7  Long  []  OBJ  PUSH #
      long $%11_1111_1110_0111_0100_1000 <<10 +memop     '$D8  Long  []  VAR  PUSH
      long $%11_1110_1101_1111_0100_1000 <<10 +memop     '$D9  Long  []  VAR  POP
      long $%11_1001_1111_1111_0100_1000 <<10 +memop     '$DA  Long  []  VAR  USING      ??????????
      long $%10_0111_1111_1111_0100_1000 <<10 +memop     '$DB  Long  []  VAR  PUSH #
      long $%11_1111_1110_0110_1100_1000 <<10 +memop     '$DC  Long  []  LOC  PUSH
      long $%11_1110_1101_1110_1100_1000 <<10 +memop     '$DD  Long  []  LOC  POP
      long $%11_1001_1111_1110_1100_1000 <<10 +memop     '$DE  Long  []  LOC  USING      ??????????
      long $%10_0111_1111_1110_1100_1000 <<10 +memop     '$DF  Long  []  LOC  PUSH #
  • Here are the MATHOP bytecodes
    Note the math_bin & math_un code is not currently in the code
    '  %    $E0..FF  Math operation                                               %
    '$E0-FF Math operation          | 1   1   1 | o   o   o   o   o |   (32 maths opcodes)
    ' Math Assignment (USING)       | p   1   s | o   o   o   o   o |   (32 maths opcodes) "op2"
    '  operation                    `---^---^---^---^---^---^---^---'
    '                                 |  (!s) 0 = swap binary args
    '                                 |       1 = no swap
    '                            (!p) 0 = push
    '                                 1 = no push
    math_bin                test    a,#%00100000    wz      '!s=swap binary args (for assignment operator)              '<<<<<<<<<<<<<<<<<<<<
            if_nz           rdlong  y,--ptrb                'if binary+!swap 1st into y
                            rdlong  x,--ptrb                'if binary+!swap 2nd into x, if binary+swap 1st into x
            if_nz           jmp     #math_EFx
    math_un                 rdlong  y,--ptrb                'if unary 1st into y (i.e.swap), if binary+swap 2nd into y  '<<<<<<<<<<<<<<<<<<<<
    math_EFx                shr     vtable,#9               'shift to 2nd vector
                            sets    vector,vtable           '2nd vector (9bits)                                         '<<<<<<<<<<<<<<<<<<<<
                            jmp     vector                  'indirect jump to: math_E0...FF
    math_E0
                                            '$F0=AND bool   ' %11_1111_1110_1111_1111_0000
                                            '$F2=OR  bool   ' %11_1111_1011_1111_1111_0000
    .math_F0                CMP     x,#0       wz           '                            *  'f=0,t=-1
                            MUXNZ   x,masklong              '                           *
                            CMP     y,#0       wz           '                          *    'f=0,t=-1
                            MUXNZ   y,masklong              '                         *
    .math_E0                ROR     x,y     '$E0=ROR        ' %11_1111_1111_1111_1110_1111
                            ROL     x,y     '$E1=ROL        ' %11_1111_1111_1111_1101_1111
                            SHR     x,y     '$E2=SHR        ' %11_1111_1111_1111_1011_1111
                            SHL     x,y     '$E3=SHL        ' %11_1111_1111_1111_0111_1111
                            FGES    x,y     '$E4=FGES       ' %11_1111_1111_1110_1111_1111
                            FLES    x,y     '$E5=FLES       ' %11_1111_1111_1101_1111_1111
                            NEG     x       '$E6=NEG     un ' %11_1111_1111_1011_1111_1111
                            NOT     x       '$E7=NOT     un ' %11_1111_1111_0111_1111_1111
                            AND     x,y     '$E8=AND        ' %11_1111_1110_1111_1111_1111
                            ABS     x       '$E9=ABS     un ' %11_1111_1101_1111_1111_1111
                            OR      x,y     '$EA=OR         ' %11_1111_1011_1111_1111_1111
                            XOR     x,y     '$EB=XOR        ' %11_1111_0111_1111_1111_1111
                            ADD     x,y     '$EC=ADD        ' %11_1110_1111_1111_1111_1111
                            SUB     x,y     '$ED=SUB        ' %11_1101_1111_1111_1111_1111
                            SAR     x,y     '$EE=SAR        ' %11_1011_1111_1111_1111_1111
                            REV     x       '$EF=REV     un ' %11_0111_1111_1111_1111_1111 *un
                            ENCOD   x       '$F1=ENCOD   un ' %10_1111_1111_1111_1111_1111
                            DECOD   x       '$F3=DECOD   un ' %01_1111_1111_1111_1111_1111
                            jmp     #pushr                  'push result
    math_F4
                    getct   c1
                    skipf   skipover                        ' skip over instruction(s)
    '               skip    skipover                        ' skip over instruction(s)
                            QMUL    x,y     '$F4=MPY        ' %00_0001_1111_1111_1111_1100
                            GETQX   x       '               '                           *
                            QMUL    x,y     '$F5=MPY_MSW    ' %00_0001_1111_1111_1111_0011
                            GETQY   x       '               '                         *
                            QDIV    x,y     '$F6=DIV        ' %00_0001_1111_1111_1100_1111
                            GETQX   x       '               '                      *
                            QDIV    x,y     '$F7=MOD        ' %00_0001_1111_1111_0011_1111
                            GETQY   x       '               '                    *
                            QSQRT   x,#0    '$F8=SQRT    un ' %00_0001_1111_1100_1111_1111 *un
                            GETQX   x       '                                 *
    '$F9..$FE=test signed LT/GT/NE/EQ/LE/GE '$F9..$FE       ' %00_0000_1000_0011_1111_1111  'LT/GT/NE/EQ/LE/GE
                            CMPS    x,y     wcz             '                *              'tests
            if_z            MOV     x,#%100                 '               *               'equal?
            if_nz           MOV     x,#%010                 '             *                 'above?
            if_c            MOV     x,#%001                 '            *                  'below?
                            ANDN    x,a     wz              '           *                   'set t/f
                            CMP     y,#0    wz '$FF=NOT bool' %00_0000_0111_1111_1111_1111  '!t/f      un
    pushtf                  MUXZ    x,masklong              '        *                      'Z=true(-1)/false(0)
    pushr                   wrlong  x,ptrb++                'push result
                            jmp     pa                      'indirect return        ret <= PA=pushret=~#loop                        '?????????
    and the table
    '        binary normal assign description
      long  %11_1111_1111_1111_1110_1111 <<10 +math_E0   '$E0 ROR       1st -> 2nd  b       ->     ->=  rotate right
      long  %11_1111_1111_1111_1101_1111 <<10 +math_E0   '$E1 ROL       1st <- 2nd  b       <-     <-=  rotate left
      long  %11_1111_1111_1111_1011_1111 <<10 +math_E0   '$E2 SHR       1st >> 2nd  b       >>     >>=  shift right
      long  %11_1111_1111_1111_0111_1111 <<10 +math_E0   '$E3 SHL       1st << 2nd  b       <<     <<=  shift left
      long  %11_1111_1111_1110_1111_1111 <<10 +math_E0   '$E4 FGES      1st #> 2nd  b       #>     #>=  limit minimum (signed)
      long  %11_1111_1111_1101_1111_1111 <<10 +math_E0   '$E5 FLES      1st <# 2nd  b       <#     <#=  limit maximum (signed)
      long  %11_1111_1111_1011_1111_1111 <<10 +math_E0   '$E6 NEG       - 1st       unary   -      -    negate
      long  %11_1111_1111_0111_1111_1111 <<10 +math_E0   '$E7 NOT       ! 1st       unary   !      !    bitwise not
      long  %11_1111_1110_1111_1111_1111 <<10 +math_E0   '$E8 AND       1st & 2nd   b       &      &=   bitwise and
      long  %11_1111_1101_1111_1111_1111 <<10 +math_E0   '$E9 ABS       ABS( 1st )  unary   ||     ||   absolute
      long  %11_1111_1011_1111_1111_1111 <<10 +math_E0   '$EA OR        1st | 2nd   b       |      |=   bitwise or
      long  %11_1111_0111_1111_1111_1111 <<10 +math_E0   '$EB XOR       1st ^ 2nd   b       ^      ^=   bitwise xor
      long  %11_1110_1111_1111_1111_1111 <<10 +math_E0   '$EC ADD       1st + 2nd   b       +      +=   add
      long  %11_1101_1111_1111_1111_1111 <<10 +math_E0   '$ED SUB       1st - 2nd   b       -      -=   subtract
      long  %11_1011_1111_1111_1111_1111 <<10 +math_E0   '$EE SAR       1st ~> 2nd  b       ~>     ~>=  shift arithmetic right
      long  %11_0111_1111_1111_1111_1111 <<10 +math_E0   '$EF REV       1st >< 2nd  b       ><     ><=  reverse bits (neg y first)
      long  %11_1111_1110_1111_1111_0000 <<10 +math_E0   '$F0 AND bool  1st AND 2nd b       AND         boolean and
      long  %10_1111_1111_1111_1111_1111 <<10 +math_E0   '$F1 ENCOD     >| 1st      unary   >|     >|   encode (0-32)
      long  %11_1111_1011_1111_1111_0000 <<10 +math_E0   '$F2 OR  bool  1st OR 2nd  b       OR          boolean or
      long  %01_1111_1111_1111_1111_1111 <<10 +math_E0   '$F3 DECOD     |< 1st      unary   |<     |<   decode
      long  %00_0001_1111_1111_1111_1100 <<10 +math_F4   '$F4 MPY       1st * 2nd   b       *      *=   multiply, return lower half (signed)
      long  %00_0001_1111_1111_1111_0011 <<10 +math_F4   '$F5 MPY_MSW   1st ** 2nd  b       **     **=  multiply, return upper half (signed)
      long  %00_0001_1111_1111_1100_1111 <<10 +math_F4   '$F6 DIV       1st / 2nd   b       /      /=   divide, return quotient (signed)
      long  %00_0001_1111_1111_0011_1111 <<10 +math_F4   '$F7 MOD       1st // 2nd  b       //     //=  divide, return remainder (signed)
      long  %00_0001_1111_1100_1111_1111 <<10 +math_F4   '$F8 SQRT      ^^ 1st      unary   ^^     ^^   square root
      long  %00_0000_1000_0011_1111_1111 <<10 +math_F4   '$F9 LT        1st < 2nd   b       <           test below (signed)
      long  %00_0000_1000_0011_1111_1111 <<10 +math_F4   '$FA GT        1st > 2nd   b       >           test above (signed)
      long  %00_0000_1000_0011_1111_1111 <<10 +math_F4   '$FB NE        1st <> 2nd  b       <>          test not equal
      long  %00_0000_1000_0011_1111_1111 <<10 +math_F4   '$FC EQ        1st == 2nd  b       ==          test equal
      long  %00_0000_1000_0011_1111_1111 <<10 +math_F4   '$FD LE        1st =< 2nd  b       =<          test below or equal (signed)
      long  %00_0000_1000_0011_1111_1111 <<10 +math_F4   '$FE GE        1st => 2nd  b       =>          test above or equal (signed)
      long  %00_0000_0111_1111_1111_1111 <<10 +math_F4   '$FF NOT bool  NOT 1st     unary   NOT    NOT  boolean not
  • msrobotsmsrobots Posts: 2,443
    edited 2019-03-09 - 08:33:06
    @Cluso99,
    I think this is very cool what you are doing there, sure we still have the problem with PASM1/PASM2 but you are opening up a lot of OBEX P1 stuff for the P2.
    I really like fastspin, but it compiles to large binaries, and - yes - I am sure that 512kb will be small soon, needing RAM for HDMI or whatever.
    Having a SPIN1 byte code interpreter on the P2 would be nice. @Chip has to come up with Spin2 yet (and hopefully follow @ersmith and his SPIN2 additions)
    You said that you will implement port B, as far as I follow the forum, what about the memory size?
    I guess 64kb will work with the current byte codes, but - hmm - basically spin bytecodes are relocatable so do you plan/think about/have a Idea for using more then 64kb?
    just curious,
    edited 2019-03-09 - 09:28:06
    The spin interpreter for P1 is limited to 16 address bits (words) so my interpreter will also be limited to the bottom 64KB but remember that's 2x what we have in the P1 provided you don't need the P1 ROM stuff.
    And yes, Ports A & B are supported :)
    edited 2019-03-22 - 14:31:17
    Been having fun rewriting the interpreter to use xbyte/execf/skipf almost completely.
    Saving a huge amount of clocks as the decode table removes most requirements for testing bytecode bits. This also saves instructions. Same goes for conditional instruction execution.
    Also used some of the new instructions like SIGNX, ZEROX, and others.
    I’ve been optimising for speed at some instruction code expense.
    Been testing out some of the basics. Mathops all seem working fine. Basic repeats working. Register translation working. Waitcnt working. Some of the assignments are working, some not. Maths assignments not done yet - should just be a matter of calling the mathop routine.
    It’s interesting to debug. I am displaying the registers, stack, and upcoming bytecode at each bytecode execution.
    Yet to do COGINIT tho.
