I am following the learn.parallax.com tutorial on connecting a WX WiFi module to a bs2, minus the stamp. I want to use it standalone for now. I have run through connecting it to my home network, though it does not work. When I am on it's network, the index page functions quite well. I can navigate and change settings, files, etc. When I connect the module to my home network, the only page that works is the home or index page. Clicking on anything causes the page to freeze up.
My network is Windstream hosted if that helps.
It should at least say page not found and not just hang unless scripting is disabled.
I had a similar problem and the only solution was to switch to Chrome browser.
Try re-flashing the unit completely, using a proptool. (not the OTA method) Use the serial method.
Updated flashing instructions--> https://forums.parallax.com/discussion/comment/1453097/#Comment_1453097
