Anyone used SETPAT & WAITPAT ?
I expected this to fall straight thru with either MODCZ (not sure which way round the Z works for ==)
But neither fall thru'.
                waitx   ##_clockfreq
                mov     match,inb
                and     match,mask
'               modcz   _set,_clr         '  C & NZ     ' INB
                modcz   _set,_set         '  C &  Z     ' INB
                setpat  mask,match
                waitpat
match           long    $00000000
mask            long    $C0000000
Obviously I am missing something, but what???
Website: www.clusos.com
  • I think you need to specify wcz with the modcz, otherwise it's basically a nop.
  • jmgjmg Posts: 13,618
    edited 2019-03-01 - 04:37:21
    Dave Hein wrote: »
    Hmm, is the users intention not already clear and unambiguous ?
  • Thanks Dave :smiley:
    That will be it!
  • Interesting...
    A trigger event is required to fire the waitpat.
    I thought with the P1 that a waitpeq/waitpne would pass immediately if the condition was met.
                    mov     match,inb
                    and     match,mask
                    xor     match,mask                      ' invert the SI=P31 pin
    '               modcz   _clr,_set                   wcz ' NC & Z  (INA & D) == S
    '               modcz   _clr,_clr                   wcz ' NC & NZ (INA & D) != S
                    modcz   _set,_set                   wcz '  C & Z  (INB & D) == S
    '               modcz   _set,_clr                   wcz '  C & NZ (INB & D) != S
                    setpat  mask,match
                    waitpat                                 ' wait for activity on SI=P31
    Does it need that and in the second line ?
    Docs say
    Set pin pattern for PAT event. C selects INA/INB, Z selects =/!=, D provides mask value, S provides match value.
    ie the mask in D, should not need the match also masked elsewhere ?
  • jmg wrote: »
    Dave Hein wrote: »
    Not quite; the instruction doesn't really say which of c and z should be updated (c, z, or both).
    However, if neither is updated that's probably a bug. fastspin will issue a warning in this case. I don't think PNut warns about it, but perhaps that would be a useful addtion.
  • jmg wrote: »
    Docs say
    This is the test done for the event (C and Z are flag states and D and S are register values from when SETPAT executed):
    event = (((C ? INB : INA) & D) == S) ^ !Z
  • From what i saw, if the value doesn’t change, then no event will be created.
    ie if you are looking for a value, and that value exists prior to performing the waitpat, then waitpat never returns.
    I don’t think the P1 works this way. It just tests to see if the condition is met.
  • The event occurs when the pattern is detected. If the pattern is present from the beginning, there is no event.
  • Cluso99 wrote: »
    Totally. WAITPEQ and WAITPNE
    Re-inventing the wheel is not a waste of time if, when you are done, you understand why it is round.
  • Cluso99Cluso99 Posts: 15,085
    edited 2019-03-01 - 17:00:00
    So we have to do an additional check first now to see if the condition is met, and skip the waitpat if it’s already met?
  • tomcrawfordtomcrawford Posts: 1,060
    edited 2019-03-01 - 17:11:01
    Now that I think about it:
    Actually, for the 360 feedback servo, I have to measure a high period and the following low period. So on P1, I do a WAITPxx for a low, followed by a WAITPxx for a high to be certain I am measuring the whole high period (followed by another WATPxx for the end of the high period, etc). Basically, I am LOOKING for edges, so the P2 should work out better. Plus I think I can implement a timeout for the case where the servo died without feedback.
  • Now that I think about it:
    There is a state-measuring smart pin mode that alternately measures high and low times, without missing a clock.
    So that means it is edge activated, and is triggered on a change-to moment ?
    That would need to be made clear in the DOCs
    Sounds great for Duty capture to high precision, on a single smart pin. Which mode is that ?
