Fun with the P2 ROM :)
Cluso99Cluso99 Posts: 15,549
edited 2019-02-25 - 09:22:50 in Propeller 2
Here is a sample program to have some fun with the builtin ROM SD & Monitor routines...
The attached program is for the P2-EVAL board, and below is the output to PST.
Note: This uses the SD Boot code that was designed for RCFAST. As such, it only works with the clock between 15MHz and 35MHz.
Enjoy :)
Fun with P2 ROM v001
File sector(length) 000042C0(00001040)
Read sector 000042C0
04000: 5F 3A 64 FD  5F 70 64 FD  96 98 80 FF  1F 00 66 FD   '_:d._pd.......f.'
04010: EC FF 9F FD  54 68 65 20  71 75 69 63  6B 20 62 72   '....The quick br'
04020: 6F 77 6E 20  66 6F 78 20  77 61 73 20  68 65 72 65   'own fox was here'
04030: 21 20 20 20  54 68 65 20  71 75 69 63  6B 20 62 72   '!   The quick br'
04040: 6F 77 6E 20  66 6F 78 20  77 61 73 20  68 65 72 65   'own fox was here'
04050: 21 20 20 20  54 68 65 20  71 75 69 63  6B 20 62 72   '!   The quick br'
04060: 6F 77 6E 20  66 6F 78 20  77 61 73 20  68 65 72 65   'own fox was here'
04070: 21 20 20 20  54 68 65 20  71 75 69 63  6B 20 62 72   '!   The quick br'
04080: 6F 77 6E 20  66 6F 78 20  77 61 73 20  68 65 72 65   'own fox was here'
04090: 21 20 20 20  54 68 65 20  71 75 69 63  6B 20 62 72   '!   The quick br'
040A0: 6F 77 6E 20  66 6F 78 20  77 61 73 20  68 65 72 65   'own fox was here'
040B0: 21 20 20 20  54 68 65 20  71 75 69 63  6B 20 62 72   '!   The quick br'
040C0: 6F 77 6E 20  66 6F 78 20  77 61 73 20  68 65 72 65   'own fox was here'
040D0: 21 20 20 20  54 68 65 20  71 75 69 63  6B 20 62 72   '!   The quick br'
040E0: 6F 77 6E 20  66 6F 78 20  77 61 73 20  68 65 72 65   'own fox was here'
040F0: 21 20 20 20  54 68 65 20  71 75 69 63  6B 20 62 72   '!   The quick br'
04100: 6F 77 6E 20  66 6F 78 20  77 61 73 20  68 65 72 65   'own fox was here'
04110: 21 20 20 20  54 68 65 20  71 75 69 63  6B 20 62 72   '!   The quick br'
04120: 6F 77 6E 20  66 6F 78 20  77 61 73 20  68 65 72 65   'own fox was here'
04130: 21 20 20 20  54 68 65 20  71 75 69 63  6B 20 62 72   '!   The quick br'
04140: 6F 77 6E 20  66 6F 78 20  77 61 73 20  68 65 72 65   'own fox was here'
04150: 21 20 20 20  54 68 65 20  71 75 69 63  6B 20 62 72   '!   The quick br'
04160: 6F 77 6E 20  66 6F 78 20  77 61 73 20  68 65 72 65   'own fox was here'
04170: 21 20 20 20  54 68 65 20  71 75 69 63  6B 20 62 72   '!   The quick br'
04180: 6F 77 6E 20  66 6F 78 20  77 61 73 20  68 65 72 65   'own fox was here'
04190: 21 20 20 20  54 68 65 20  71 75 69 63  6B 20 62 72   '!   The quick br'
041A0: 6F 77 6E 20  66 6F 78 20  77 61 73 20  68 65 72 65   'own fox was here'
041B0: 21 20 20 20  54 68 65 20  71 75 69 63  6B 20 62 72   '!   The quick br'
041C0: 6F 77 6E 20  66 6F 78 20  77 61 73 20  68 65 72 65   'own fox was here'
041D0: 21 20 20 20  54 68 65 20  71 75 69 63  6B 20 62 72   '!   The quick br'
041E0: 6F 77 6E 20  66 6F 78 20  77 61 73 20  68 65 72 65   'own fox was here'
041F0: 21 20 20 20  54 68 65 20  71 75 69 63  6B 20 62 72   '!   The quick br'
Read sector 000042C1
04000: 6F 77 6E 20  66 6F 78 20  77 61 73 20  68 65 72 65   'own fox was here'
04010: 21 20 20 20  54 68 65 20  71 75 69 63  6B 20 62 72   '!   The quick br'
My Prop boards: P8XBlade2 , RamBlade , CpuBlade , TriBlade
P1 Prop OS (also see Sphinx, PropDos, PropCmd, Spinix)
Website: www.clusos.com
P1: Tools (Index) , Emulators (Index) , ZiCog (Z80)
P2: Tools & Code , Tricks & Traps
