Welcome to the Parallax Discussion Forums, sign-up to participate.
{ Prop2 WS2812 demo using smartpins Version 0.2 ozpropdev Feb 15th 2019 } sys_clk = 25_000_000 us = sys_clk / 1_000_000 ws2812_load = 51 * us _200ns = us * 200 / 1000 num_leds = 64 clk = 14 ws2812 = 15 dat org hubset #0 wrpin #%1_00101_0,#clk 'transition mode wxpin ##_200ns,#clk dirh #clk wrpin ##%1111 << 24 | %1_11100_0,#ws2812 'sync tx mode wxpin #%1_00000 | 23,#ws2812 dirh #ws2812 'build ws812 waveform data into lut for each byte 'e.g. byte $8c becomes %001_001_011_011_001_001_001_011 mov index,#0 build mov count,#8 'number of bits mov pa,index mov pb,#0 .loop testb pa,#7 wc shl pb,#3 or pb,#1 '0 = %100 (1/3 t) if_c or pb,#%10 '1 = %110 (2/3 t) shl pa,#1 djnz count,#.loop shl pb,#32-24 rev pb 'prepare for msb shifted first wrlut pb,index incmod index,#255 wz if_nz jmp #build getct time addct1 time,delay 'Main loop 'send data to ws2812 devices update_ws2812 loc ptra,#@led_buffer 'iitialize pointer mov leds,#num_leds next_led rdlong rgb,ptra++ 'get grb data mov count,#3 '3 * 8 bits next_color getbyte pb,rgb,#2 'get color byte shl rgb,#8 rdlut pa,pb 'convert to waveform wypin pa,#ws2812 'load sync tx with 24 bit waveform wypin #48,#clk 'start 48 clock transitions busy testp #clk wc 'wait for smartpin completion if_nc jmp #busy rdpin 0,#clk 'clear smartpin djnz count,#next_color djnz leds,#next_led waitx ##ws2812_load 'data low for >50Us 'shift led pattern in led buffer pollct1 wc if_nc jmp #update_ws2812 addct1 time,delay loc ptra,#@led_buffer loc ptrb,#@led_buffer+4 rdlong pb,ptra rep #2,#63 rdlong pa,ptrb++ wrlong pa,ptra++ wrlong pb,ptra jmp #update_ws2812 time long 0 delay long sys_clk / 20 count long 0 index long 0 rgb long 0 leds long 0 lut long 0 orgh $400 led_buffer long $00_1f_00_00[4] 'green long $00_00_1f_00[4] 'red long $00_00_00_1f[4] 'blue long $00_00_1f_1f[4] 'magenta long $00_1f_00_1f[4] 'cyan long $00_1f_1f_00[4] 'yellow long $00_1f_1f_1f[4] 'yehite long 0[4] long $00_1f_00_00[8] 'green long $00_00_1f_00[8] 'red long $00_00_00_1f[8] 'blue long $00_00_1f_1f[8] 'magenta
Enjoy!
Smartpins make this so easy. A single cog can control a huge amount of leds.
BTW this is running in RCFAST mode with no problems.
