Just How Fast Can a P1 Go?
AwesomeCronk
Seems to typically run at 80Mhz, but I’ve heard of it run at up to 96Mhz. Is that the limit? How might this adversely affect the circuitry inside?
AFAIK P1's can and have run at 96 and 100MHz reliably. I believe some people have had them running at even higher speeds, but I do not recall what speed or who did so.
Parallax sells this faster crystal if you want to replace the usually 5 MHz found on most boards.
https://www.parallax.com/product/251-06250
5 MHz x 16 PLL = 80 MHz
6.25 MHz x 16 PLL = 100 MHz
You should be posting these Propeller related questions in the Propeller 1 forum.
Here you go.
https://forums.parallax.com/discussion/117476/maximum-clock-speed-for-the-propeller
http://forums.parallax.com/discussion/149239/maximum-reliable-clock-frequency
https://forums.parallax.com/discussion/143703/propeller-clock-speed
https://forums.parallax.com/discussion/102260/maximum-input-clock
https://forums.parallax.com/discussion/131706/114mhz-propeller-1-0-55/p1
https://forums.parallax.com/discussion/122680/7-3728mhz-crystal-wont-run-at-16x-but-would-a-faster-one-run-at-8x
https://forums.parallax.com/discussion/117864/the-clock-clock-multiplier-and-crystals
... Chip chimes in on this post about the PLL for those who are interested.
https://forums.parallax.com/discussion/113808/the-6-250mhz-crystals-are-in-run-your-propeller-at-100mhz/p1
For some unknown reason, DIPs run a little faster than QFPs.
I have never found a problem at 108MHz but I never continued as 104MHz was fine.
Maybe the pins being larger allows the power supply to be more reliable?
I'd expect it to have more to do with thermal resistance. The DIP is a much larger radiating surface, than a QFP.
P2 seems to benefit from the thermal pad and 4 layer PCBs - did anyone test the P1 QFN (now NRND) package on 4 layers for speed ?
That was on project boards (TQFP).
There are some crazy speeds to be attained by the p1!
