HELP!! SPIN coding problem with LEDs lighting on down count.
AImanAIman Posts: 522
edited 2019-02-04 - 22:02:44 in Propeller 1
I feel embarrassed to say this, but for the life of me I can't figure out what it is thats screwed up in this code. All its supposed to do is make a series of 8 LED lights turn on one at a time and go back and forth.
Var
Byte Pin ' I/O pin.
PUB Toggle {Made to toggle 8 LEDs on and off in sequence from low to high and then high to low}
Pin := 16 ' Set value to first pin
dira[Pin]~~
Repeat
Repeat until !outa[Pin]++ == 23 ' Go up one pin at a time to pin 23
waitcnt(clkfreq/4 + cnt) ' Wait for delay cycles
Repeat until !outa[Pin]-- == 16 ' Go down one pin at a time to pin 16
  • Of course the space indentations didn't show up in the post ...
  • use the C to make a code block, then the indentions show up.
    You are doing it slightly wrong, here a better version
    Var
    Byte Pin ' I/O pin.
    Repeat
      Repeat
        dira[pin] := 1
        outa[pin] := 1
      until Pin++ == 23 ' Go up one pin at a time to pin 23
      Repeat
        dira[pin] := 0
        outa[pin] := 0
      until Pin-- == 16 ' Go down one pin at a time to pin 16
    Enjoy!
  • AImanAIman Posts: 522
    edited 2019-02-04 - 14:37:46
    Thanks Mike.
    Just one question - if I alter the code slightly to shut off the led once they are turned on but putting !outa[Pin] after waitcnt, why doesn't it work going from 23 to 16? So it would read as
    !outa[pin]
    If I do !dira[Pin] it will light up on the way back to 16 but not shut off the others.
  • JonnyMacJonnyMac Posts: 6,156
    edited 2019-02-04 - 19:35:58
    Here's another approach that may be a bit easier to digest. Look for opportunities to put redundant code into methods, and when you keep using the same methods over and over group them into a library.
    pub main | pin
      repeat { forever }
        repeat pin from 16 to 23
          high(pin)
          waitcnt(cnt + (clkfreq >> 2))
          low(pin)
    pub high(pin)
      outa[pin] := 1
      dira[pin] := 1
    pub low(pin)
      outa[pin] := 0
      dira[pin] := 1
    For my normal work I have a library called jm_io.spin which handles essential pin IO functions.
    Jon McPhalen
    Hollywood, CA
    It's Jon or JonnyMac -- please do not call me Jonny.
  • Just for future reference, AIman, you'll probably get more extensive help if your title includes some information about your issue. "Help!!" is much too vague to elicit the best this forum has to offer.
  • Code still isn't working. I will attach a video of a few seconds so you can see the original code.
    The LEDs will light up for 1/4 second and then shut off for 1/4 second. The LEDs move from pin 16 to 17 to 18 etc. However, on the way down from 23 the LEDs will not light up - or not light properly. There should be one light on at a time and the light should move back and forth across string of lights.
    For ease of coding I am using the Propeller Demo Board Rev G since it already has LEDs on it.
    This code works halfway, but it is bulky and crude. At this point I will take bulky and crude if it will run like its supposed to.
    Var
     Byte Pin                {I/O pin to toggle on/off. Good from 0 - 255}
    PUB Toggle
      Pin := 16                {Set value of pin to starting point}
      Repeat
        repeat while pin < 24   ' Repeat the following
          dira[Pin]~~           ' Set I/O pin to output direction
          !outa[Pin]            ' Toggle I/O Pin
          dira[pin]~
          Pin += 1              ' Go to next pin. Short form of Pin := Pin + 1
        repeat until pin < 16
          dira[pin]~
          Pin -= 1              ' Go to next pin. Short form of Pin := Pin - 1
  • So the video I was going to attach apparently isn't allowed. This will require a bit of thought to work around.
  • jmgjmg Posts: 13,108
    AIman wrote: »
    In fault finding, you should note exactly what does happen, and compare that with what you expect to happen.
    'not light properly' is too vague to be useful.
    Do the leds (all/some/partial?) fail on down-slope only, and work ok on every up slope time window ?
  • The video I was hoping to upload would have shown and clarified most questions but in absence of that -
    The LEDs are one to each pin on pins 16 - 23. Pin 16 goes high turning on that LED and after 1/4 second the pin goes low shutting off the LED. This repeats up to pin 23.
    BUT
    When the pins go from 23 - 16 it doesn't work and only a very faint LED light is visible as the pins count down from 23 to 16.
    AIman wrote: »
    .. and then what happens.. ? Does the next up ramp work ok ?
    "doesn't work and only a very faint LED light is visible" is still vague. Does that mean the timing is as-expected, but each single on LEDs is faint, or all leds light, but faint, or something else ?
    The small details matter a lot, and help you figure out possible causes.
  • Here's the solution. You need to delay before you toggle the pin when going from P23 to p16.
          waitcnt(clkfreq/4 + cnt)  ' Wait for delay cycles  - need to delay before turning off the led
          ' waitcnt(clkfreq/4 + cnt)  '   This line needs to be before the !outa[pin]
          dira[pin]~
  • The next ramp up works fine, but for whatever reason going down doesn't. The LEDs are very dim, almost not noticeable, but have proper timing.
    In other words, it works with timing as it should, but the LEDs won't fully light up when subtracting a pin. I will try to post pictures since the video clip can't post.
  • twm47099 - Thanks!!!
    edited 2019-02-05 - 15:12:41
    Because you're not manipulating the IO pins correctly.
    I don't mean to be blunt, but you're writing code in a bit of an obtuse manner. In my opinion, it's always best to write code that is obvious.
    It seems that you now want to create a Larson Scanner (Cylons, Kit car) -- I didn't understand that from your initial post. As I live and work in Hollywood, I've written lots of Larson scanner code. Here's one way that I think is easy to follow.
    pub main | pin
      repeat { forever }
        repeat pin from 16 to 22
          high(pin)
          waitcnt(cnt + (clkfreq >> 3))                             ' delay 1/8 second
          low(pin)
        repeat pin from 23 to 17
          high(pin)
          low(pin)
    pub high(pin)
      outa[pin] := 1
      dira[pin] := 1
    pub low(pin)
      outa[pin] := 0
      dira[pin] := 1
    There are many roads that lead to Rome, and many ways to solve the same programming problem. Here's one that's close to your style -- if a bit more obvious:
    pub main | pin
      outa[23..16] := %00000000                                     ' set LEDs to outputs
      dira[23..16] := %11111111
      pin := 16
      repeat { forever }
        repeat
          outa[pin] := 1
          outa[pin] := 0
        while (++pin < 23)
        repeat
          outa[pin] := 1
          outa[pin] := 0
        while (--pin > 16)
    Jon McPhalen
    Hollywood, CA
