Retronitus - Noise from the past!
12345679»
  • Well, after all, it is just a lil' beeper speaker. Kind of like some old computers have.
    Regarding the capacitor value, i'm not sure. Maybe 100uF ? With the pretentious audio-grade ones I used, that's the next step up. But 47uF certainly isn't terrible, as you can hear from my recordings.
  • JRetSapDoogJRetSapDoog Posts: 834
    edited 2018-10-31 - 03:11:38
    Maybe my filter is lame. With respect to the left channel in the schematic above, I only use surface mount decoupling caps (104's) for C4 and C5, and I use 180R instead of 750R for R20. Although I think there's a lot of variability on what values can be used, maybe my values and the cap type(s) are not ideal. Then again, it is mono and the speaker is small (though the beeps can be quite loud).
  • Here is the formula to calculate the 3db cutoff frequency
    f3db=1/(2*pi*r1*c1)
    For 19.4KHz the series R is 820 ohms and the capacitor to gnd is 10nF.
  • Maybe my filter is lame. With respect to the left channel in the schematic above, I only use surface mount decoupling caps (104's) for C4 and C5, and I use 180R instead of 750R for R20. Although I think there's a lot of variability on what values can be used, maybe my values and the cap type(s) are not ideal. Then again, it is mono and the speaker is small (though the beeps can be quite loud).
    Your sound circuit works fine for the beeps it was intended for. I was probably silly to try to use it for this music software.
    edited 2018-11-01 - 02:31:48
    Cluso99: Thanks for the formula. Guess that makes the 3dB cutoff for my current components (180R & 0.1uF) 8.84KHz. Sounds like there's room for improvement.
    David: Well, I had hoped that it would be able to play music, but I never got around to trying any.
  • David: Well, I had hoped that it would be able to play music, but I never got around to trying any.
    That's okay. It plays beeps quite well!
  • Wuerfel_21Wuerfel_21 Posts: 510
    edited 2019-01-13 - 20:22:34
    Hmm, I've been thinking about how to crunch the song data even smaller. Some people think about philosophy and the meaning of life while they're in the shower, I think about PASM....
    The actual note data is already extremely dense, but the pattern sequences are not only quite large, but also aren't very flexible.
    As far as I can tell, at the max tempo, the music routine is called 16 times per step - twice per channel, first to step through the patterns, second to load a new pattern from the sequence. If the max tempo was halved (still plenty fast at 64kHz), there would be four calls per step. There's the one for the pattern, but now we can interpret up to three sequence commands that can be 16 bit each. I haven't tested it yet, but I think replacing patternHandler with this would work:
    patternHandler
    B3            rdbyte    tempValue1, c1_stepPointer       wz
            if_nz jmp       #phaseAcc
                 'nop
    G1            rdword    tempValue1, c1_patternPointer
                  shr       tempValue1, #1                  wc  ' check bit 0
    B4      if_nc mov       c1_stepPointer, tempValue1          ' run pattern
            if_nc jmp       #patternNext
                  shr       tempValue1,#1                      wc  ' check bit 1
            if_c  jmp       #patternSetStuff                    ' if set, set instrument, octave, note
                  shr       tempValue1,#1                      wc  ' check bit 2
            if_c  jmp       #patternJump
                  mov       tempo, tempValue1
                  shl       tempo, #14                          ' set tempo
                  jmp       #patternNext
    patternJump
                  shr       tempValue1,#1                      wc ' use bit 3 as sign
                  jmp       #patternSum
    patternSetStuff
    F4            mov       c1_octave, tempValue1
    F5            shr       c1_octave, #10
    E6            mov       c1_note, tempValue1                 ' This takes care of "octave" and "note" init values
    E7            shr       c1_note, #6
    E8            and       c1_note, #15
                  and       tempValue1, #63                     ' Note = noteOn address
                  add       tempValue1, instrumenPointer              '
    C2            rdlong    c1_noteOn, tempValue1               ' TODO: Why are these longs?
    patternNext   mov       tempValue1, #2 wc
    patternSum
    G2            sumc      c1_patternPointer, tempValue1
                  jmp       #phaseAcc
    this code is only 3 longs longer than the original code. I will see if I can get it going with one of the existing tunes.
    EDIT: This is slightly shorter, at the cost of using more cycles when not having to load a command.
    Still haven't tested it.
    patternHandler
            'if_nz jmp      #phaseAcc
                 'nop
    G1      if_z  rdword    tempValue1, c1_patternPointer
             if_z shr       tempValue1, #1                  wc  ' check bit 0
    B4 if_nc_and_z mov      c1_stepPointer, tempValue1          ' run pattern
      if_nc_and_z jmp       #patternNext
            if_z  shr       tempValue1,#1                      wc  ' check bit 1
       if_c_and_z jmp       #patternSetStuff                    ' if set, set instrument, octave, note
            if_z  shr       tempValue1,#1                      wc  ' check bit 2
      if_c_or_nz  jmp       #patternJump
                  jmp       #patternNext
    patternJump
            if_z  shr       tempValue1,#1                      wc ' use bit 3 as sign
                  jmp       #patternSum
    patternSetStuff
    E7            shr       c1_note, #6
    E8            and       c1_note, #15
    patternSum
    G2      if_z  sumc      c1_patternPointer, tempValue1
                  jmp       #phaseAcc
  • There definitely are ways to improve Retronitus data format and make it more flexible etc. It will be interesting to see what you will come up with. P1 Retronitus is "abandoned" for now, so feel free to pick it apart, improve upon it or change it to suit your needs. I will look in here from time to time when I am not spending time in the P2 forum. In the future I will take what I have learned from Retronitus and make an improved version for the P2.
  • I noticed this while messing around: The square and triangle channels have twice the amplitude of the saw and noise channels. The square channels in particular divide their volume by 8 and then add or subtract that to/from the output, leading to a max. peak-to-peak volume of $1FFFFFFF (whereas to avoid overflow, it should be $0FFFFFFF)
    Is there any particular reason for this?
    edited 2019-11-30 - 19:46:41
    So here's another one of those things I've been sitting on for a while: Some Retronitus fork I call Retronitus DX.
    It's all a bit rough around the edges and unfinished and shit, but I'll link it here anyways, because why not.
    - blastershot.rb (get the pun?) can generate customized Retronitus DX cog images. It's super rough, there's no user interface at all, you'll need to manually invoke the gimme_retronitus function through IRB.
    - retrosnd.cpp/retrosnd.hpp are a C++ implementation of Retronitus DX. It's reasonably fast and should(tm) be bit-accurate.
    - retrosnd_env.hpp contains all the definitions one needs to slot the implementation into an environment of choice
    - build_dll.sh will build you a libretronitus.dll library. It should(tm) also work out on non-Windows OSes
    - rsndplay.rb can play a Retronitus DX song given on the command line. (This requires ffmpeg and ffplay to be installed and libretronitus.dll to have been built)
    - Alice.binary is a slightly improved version of that tune (obviously converted to the new data format, too). The source for this can be found here.
    It's been a while, but these are the changes I think I made compared to regular Retronitus:
    - Instrument instruction format changed: Now allows modifying previously internal-only registers (such as the phase accumulator). Jumps have been generalized as a regular register ADD (yes, there can also be absolute jumps now).
    - New 16 bit pattseq format - slightly more compact. I think it's the same as I proposed in this thread before.
    - Probably more, I don't remember.
    edited 2020-01-24 - 17:21:22
    Oh, I did some more work recently. First off, it all actually works now! Maybe. I hope.
    (Previously, I committed the wrong versions of some files... oof)
    (EDIT: I did it again! If you looked at the repo in the last 6 minutes, it wasn't updated yet....)
    Also, I did some more muckery:
    - TRG_x now jumps behind the normal instrument entry point. This makes most instruments that use TRG_x one instruction (= 8 bytes) shorter (obviously, this is a breaking change)
    - Tuned notes to 440Hz (hopefully? I can't tell the difference TBH. I just noticed while debugging another issue.)
    - Fixed some bugs in the C++ implementation
    - Source code for Alice.binary is now actually in the repository...
    I've also been working on some more stuff. I've attached some preview thing of an original composition of mine. Well, it's not particularly "original", is it? Not entirely happy with the percussion patches yet.
    (Of course, the forum won't let me upload MP3s. Classic. So I'll treat y'all with a ZIP file containing an MP3 file...)
