Should SETR/SETD/SETS be called MOVI/MOVD/MOVS ?
Cluso99
in Propeller 2
I have been coding for the P2 and I find in particular SETR seems wrong.
We have ALTR which means substitute the "R"esult address and ALTI which means substitute the "I"nstruction. Hence SETI or MOVI seems a better fit.
We have MOVBYTS, and so MOVI/MOVD/MOVS seems a better fit. There is also the benefit that the P1 uses MOVI/MOVD/MOVS.
And yes, we do have SET/GET/ROL triplets for BYTE and WORD. We don't have pairs/triplets for MOVI/MOVD/MOVS. May have been nice for I & D but not a great case for usage.
BTW this is only a compiler change, not a silicon change.
All of these modify selected bit(s) of a register.
Seems consistent to me.
And MOVBYTS be SETBYTS ???
No, I am not advocating this.
But the MOVI/MOVD/MOVS seem more like modifying instructions whereas the GET/SET/ROL seem more like bit/nibble/byte/word manipulations.
It's seems more likely to be used to configure the ALTI instructions R-field than modifying opcode fields in instructions.
That's right.
So I think the time for lengthy debates over the mnemonics is rapidly closing.
[Joking] Maybe we need two sets of mnemonics, like Intel vs Zilog [joking]
IIRC at the time there was no ALTR instruction. I don't understand??? The only "R-field" that I understand is within the pipeline, which is normally the "D-field" unless and ALTR preceded it.
SETR should at least be SETI as it changes the "I"nstruction bits, not the "R"esult address.
ALTR changes the "R"esult address within the pipeline.
Sorry, I wasn't very clear there.
It's not a pipeline thing, it modifies bits [27:19] in the D registers R field.
Aren't the RRRRRRRRR bits the IIIIIII_CZ bits of an instruction, and isn't the purpose of SETR (SETI) instruction to change the instruction on the fly ie self-modifying code ???
I am converting some P1 code that does quite a bit of instruction modification (spin Interpreter). Some of these problems include changing return jump addresses, switching between SHR and SHL, changing RDBYTE/WORD/LONG and changing RDxxxx to WRxxxx. The RD & WR and BYTE/WORD/LONG are a real PITA because of the lack of symmetry between these instructions but it's now too late to fix the encodings
The companion opcodes are GETxxx, so an alternative that avoids the SET (as in make the bit one) semantic conflict, would be PUTxxx.
GET & PUT more naturally pair, and that has to help non-english speakers.
Looking in the opcodes DOCs at the pair of set/clear, set appears 138 times and clear appears 49 times. Mostly usages apply to 'make a bit one'.
That's true, but both migration pathways are valid, and P2 ASM should assist anyone P1 porting, where that can be easily done.
Having it make sense in terms of P1 is really of limited value. They are very different devices as designed and intended. Longer term, assis5s to P2 ways and means make far more sense. There will not be new P1 designs. There are very likely to be multiple new P2 designs.
In many cases, new features really do make more sense. We did it this way to maximize the potential of the new design.
Those choices are long past cooked in. Muddying things up now makes very little sense.
Frankly, once SPIN 2 gets fleshed out, many things written in P1 PASM will do just fine written in P2 SPIN. This is a really big jump. Again as indended.
