P2 Voyager project (was New toy)
rogloh
Boards made, still waiting on rest of the BOM to arrive...including the P2D2!
Which pcb software did you use? The reason I ask is because it looks like it is hand taped in some places where tracks almost touch and in others there is "rather poor" routing. Look at the attachment for an example.
Thanks Ym2413a, there will definitely be plenty to test and then play with using my motherboard once it all works.
I would love to get a real P2D2 soon. When do you think you might have the new one coming? If it's still a long while away maybe an older board makes sense. I am going to work with Tubular and Ozpropdev for the first board bringup once I validate the power supply aspects and they already have P2D2s, but the hope is that I might eventually get a new board too at some future time. Other parts hopefully arriving next week and I'll probably make it up early new year as Xmas delays things somewhat. I can send you a board to play with too.
If I send off the artwork for the new board, even though it's that time of the year here, I think I should still get it in the next couple of weeks as I've done this before.
You can always claim the track routing is deliberate, to even up the timing
I found a minor issue with the VGA connector being very tight to install in place and I'll need to open up the holes a fraction with a PCB drill to help. Weird as I've used this particular footprint and component before in another project and it fit, could be just variation in supplied parts. Will increase hole size from 0.7mm to 0.8mm on next spin in any case. Stencil alignment looks okay too when I held it over the board.
Posted some pics of this board etc and within the instrument enclosure.
What dimensions do you need and I'll see if I have any.
Thanks Cluso but I was already able to drill out to 0.8mm from 0.7mm using a Dremel, press and a PCB drill bit. Connector fits snugly now. Good thing is that only one connection actually passes up to non-solder side and it was not affected by reducing its plated hole thickness by drilling. The rest of the connections already remain on the solder side so it wouldn't even matter for those if any of the inner plating was lost. Looks clean.
Will just start out with building and testing the power supply regulator circuits as a standalone test board I guess, then proceed from there...
Now ready to build the 5V buck regulator section on the first test board and take it from there.
This afternoon I was also able to solder up the main 5V step down regulator and input reverse FET protection stuff. Certainly not my best work as 0603 is getting somewhat small for me to see without proper magnification etc, but it should hopefully now be sufficient to test the circuit with any luck.
Going back to something you said earlier...
This morning, I will be making my first attempt at a surface mount component
I will be attempting to surface mount a 20 pin SSOP. A MCP23008 to be exact. I can only imagine the joy
Is that little 6 pin the small package (SOT-363?) ?
LOL... I can only imagine his joy with that one
Take your time. 0.65mm pitch is usually reasonably doable with some care, plenty of flux and desolder wick if you mess it up. I have one of those package types on my board too but in the 24 pin size for HDMI. At least its pins protrude out beyond the package unlike QFN/DFN or BGA etc. I only have one QFN device on my board, and it worries me. A couple of other 0.5mm parts are not going to be enjoyable either.
Yes unfortunately - and I DESPISE those! Took me forever to get it right on a prior board.
I can only imagine my joy if my first surface mount was a QFN
However, your same advice applies:
