Elev-8 Crashes
                    Hi everyone!
I have been experiencing a non-consistent problem with my Elev-8. I can often get in some 10-15 minute flights, gaining some altitude and distance. But, occasionally the copter will flip (roll) 180 degrees and head straight (upside) down. This has happened anywhere from 7 to 20 feet in altitude resulting in damage to motor mounts and props.
I really do not know where to start. I have been looking at the sensor data stream, but do not know if it is the flight controller or the transmitter or even the esc. I took screenshots of the sensor data to try to analyze, but really do not know where to start. Sometimes the Yaw Data is off the charts.
I have done the Accel and Gyro calibration many times.
Any advise would be greatly appreciated.
Which version of the ELEV8 you you have? The controller matters. Version 1 and 2 have the Hoverfly controller, while the Version 3 has the Parallax Flight Controller.
I have the V3 with the Parallax controller. I use 2.0.1 firmware and groundstation software. I also have the xBee setup to log data.
Maybe I’ll post the logs.
I would like to try to read the code to analyze just those sensors, then understand the math with the radio receiver.
I plan of removing the FC and ESCs to troubleshoot the basic systems.
Thanks!
Not sure that helps the OP as he has a Parallax Flight Controller.
I can send you a known working Flight Controller for testing. PM me your address.
Thanks Publison, life and the cold weather got in the way of doing any kind of troubleshooting. The hobbyist in me really wants to break down the FC to understand all the subsystems. I will probably revisit this in Feb/March.
We will be here to assist. Happy Holidays!
