I See Two USB Ports on the P2 Eval
What are they for?
Windows 10 Home:
Propeller Tool 1.3.2, BASIC Stamp Editor 2.5.4, Javelin Stamp IDE x.x.x, Arduino IDE, PST
Hardware:
BASIC Stamp Board of Education, Propeller Board of Education, Propeller Project Board, Propeller Mini
Me, a programmer in English class, asking for grammar help: “What is the syntax for this statement?”
  • One is for a USB data connection and 500ma power to the board, the other one is for power only with a greater 2A current capacity. See https://docs.google.com/document/d/1gIKAfx5slcwjrAvHnbn5VNReY2SbQxtYkgO8cIzjyyY/edit#heading=h.6frgvwkw4djo
    The difference between theory and practice is that, in theory, there is no difference between theory and practice, but in practice, there is.
  • One provides power, and optionally can have it's data pins connected to the P2 for software USB.
    The other is the normal USB serial connection (via FTDI chip) to pins 62/63 for programming/etc.
  • Roy Eltham wrote: »
    Does that mean that the board can't be powered off of the USB serial connection? Does it require a separate USB power connector to the other USB port?
  • David Betz wrote: »
    Roy Eltham wrote: »
    No, both USB connectors can power the board.
    pmrobert wrote: »
    In science there is no authority. There is only experiment.
    Life is unpredictable. Eat dessert first.
  • kwinn wrote: »
    David Betz wrote: »
    Roy Eltham wrote: »
    That's good. Don't want a rats nest of cables on my desk!
  • II ordered this one from amazon to do the brute force power.
    https://www.amazon.com/gp/product/B074KHX8CP/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    Infernal Machine
  • Roy ElthamRoy Eltham Posts: 2,655
    edited 2018-12-02 - 21:44:47
    The problem is that most computer USB board can't deliver very much power (unless you have those new fangled power delivery USB 3.1 ports), so you'll probably want to power the board from a good usb charger/power source if you plan to do anything more than the most basic stuff.
    Especially if you are going to hang daughter boards off of it with more chips needing power.
    Publison, it's interesting how the main title of that amazon link says 3A, but the description text below says 2.5A.
    I'm sure my experiments will mostly involve blinking LEDs and printing stuff to the serial port. :smile:
  • jmgjmg Posts: 13,922
    edited 2018-12-02 - 22:14:04
    David Betz wrote: »
    Roy Eltham wrote: »
    I think that depends how ambitious you are... FWIR 100mA is default and 500mA is easily configured on most USB interfaces.
    However, P2 can draw above what those can deliver.
    Generic cables may struggle even with 500mA.
    Publison wrote: »
    Good idea.
    Roy Eltham wrote: »
    I wonder if Parallax used highest current spec'd USB connectors ?
    When you get to 2/3.5/3A not everyone agrees on who can carry what current :)
    Digkiey specs variously 1A / 1.5A / 1.8A /
    1.8A looks like the industry default, (for cheapest/highest volume stocks) which should be OK for P2
    Wurth Electronics Inc. 629105150521 specs 1A/3A, but comes at a relatively high price. It does spec 30 mΩ max & has nice solid looking body-pins.
    A good cable, with proper copper conductors, is likely to have most influence. Fatter copper on the PCB on GND/PWR can only help too...
  • VonSzarvasVonSzarvas Posts: 1,621
    edited 2018-12-02 - 22:44:24
    Yes, they are 1.8A rated. (The USB sockets)
    By Jove, I think you are right! I can't zoom the see the actual printing.
    Infernal Machine
