Live stream of bringing P2 Evaluation Board up
                    Follow https://www.youtube.com/user/ParallaxInc for a live stream pretty soon.
Chip is in Red Bluff, but Jeff and David will do their best to bring one of these up and running.
Schedule unknown, but pretty soon (after we get out of the Hour of Code meeting).
I think you mean bated breath
That's probably what I wanted but Abated works too :-)
abated: become less intense
(I love the pre-event banter!)
j
j
I think the stream is broken.
No stream today ! Some technical issues - lack of coverage quality.
Maybe some pics or a video clip will follow later......
Nail-biting stuff! Waiting for "snapper" Ken to finish helping some visitors....
Looks like the guys didn't even stop to solder on all the headers yet !!
Just remember to get that com port down below 10 so Pnut can find it
I just realized from the blurry photo that you were in TAQOZ. Don't forget you can check the Flash with .SF (print Serial Flash) which will report back the Flash IDs etc. You can also check the SD with MOUNT which should report back the details of a successful FAT32 mount. Then type DIR to see what's on there.
Other quick and useful stuff would be to check all the I/O, perhaps by outputting a different frequency on each like this: which will starting from P0 for 58 pins up to P57 will select a pin using the current index I and then using the index+1 as the kHz frequency on that pin. So P0=1kHz and P57=58kHz. Something you can confirm then with the scope but due to the fact that the ROM version assumed a CPU frequency of 80MHz then the actual timing will be almost a quarter of that. The revised ROM will adjust for CPU frequency though.
