Running PASM from c
Bobby1066Bobby1066 Posts: 7
edited November 1 in Propeller 1 Vote Up0Vote Down
Hi I'm very new to this so the help i want may seem very stupid but I keep getting the following compiler error.
I have #include <propeller.h>
Tried all sorts just don't have the knowledge to work out what is wrong.
Start 1Hz PASM (Pulse1Hz.Spin) PUB Pulse_Every_Sec
int startPulse1Hz(unsigned int * par){
extern unsigned int *binary_Pulse1Hz_dat_start;
return cognew(&binary_Pulse1Hz_dat_start,0);
int main() // Main function
Error returned is
C:\Users\Bobby\AppData\Local\Temp\cceNPXg3.o: In function `_startPulse1Hz':
(.text+0x1): undefined reference to `_binary_Pulse1Hz_dat_start'
collect2: ld returned 1 exit status
Done. Build Failed!
I've never used a forum before so hope what I've done is the correct way to go about it.
Thanks in advance.
Bob
  • 9 Comments sorted by Date Added Votes
  • I believe you can not call spin code from C code.
    You can however include PASM code in your C code and call that.
    void doAsm(void *par)
      int rxbits;
      int wcnt;
      int rxdata;
      int Data;
      int rxmask;
      int baud;
          __asm__ volatile (
          "     waitpne 0, %[_mask]        \n\t"
          "     mov %[_rxbits], #9         \n\t"
          "     mov %[_wcnt], %[_baud]     \n\t"
          "     shr %[_wcnt], #1           \n\t"
          "     add %[_wcnt], cnt          \n\t"
          "bit: add %[_wcnt], %[_baud]     \n\t"
          "     waitcnt %[_wcnt], %[_baud] \n\t"
          "     test %[_mask], ina  wc     \n\t"
          "     rcl %[_rxdata], #1         \n\t"
          "     djnz %[_rxbits], #bit      \n\t"
          "     mov %[_data], %[_rxdata]   \n\t"
            :[_rxbits] "+r" (rxbits),
             [_wcnt] "+r" (wcnt),
             [_rxdata] "+r" (rxdata),
             [_data] "+r" (Data)
            :[_mask] "r" (rxmask),
             [_baud] "r" (baud)
  • Bobby1066Bobby1066 Posts: 7
    edited November 1 Vote Up0Vote Down
    I have brought a book on propeller programming by Sridhar Anandakrishnan. Which gives examples but I can't get them to work.
    Have found other references on this forum but no clear examples or explanations.
    Hopefully there are others who may help me.
    Thank you
    Bob
  • Bobby1066 wrote: »
    Done. Build Failed!
    If I remember correctly, the symbol name generated for the PASM code has two underscores prepended to the name, so you need to declare it with a single underscore (the second is automatically added by the C compiler as the standard naming convention).
    extern unsigned int *_binary_Pulse1Hz_dat_start; // underscore added
    return cognew(&_binary_Pulse1Hz_dat_start,0);
    If still not working, please post the complete source code you are actually using, otherwise it is very complicated to help you.
    Best regards,
    Marco.
    VT-100 Terminal and Graphics Card for the RC2014 Z80 Computer
    Have tried that and exactly same error?
    Here is my C and the PASM I'm trying to run.
    Thanks Bob
    #include <simpletools.h>
    #include <stdbool.h>
    #include <stdio.h>
    #include <cog.h>
    Start 1Hz PASM (Pulse1Hz.Spin) PUB PULSE
    const int PosDetMask =        0b100000000000000000000000000000; // Positive edge detection mode
    const int NegDetMask =        0b110000000000000000000000000000; // Negative edge detection mode
    const int IpBitMaskPendulum = 0b000000000000100000000000000000; // Mask for INA Register Pin Location
    long   Pendulum = 17;                          // Select Input pin
    Design note write code to generate "IpBitMaskPendulum"
    unsigned long  hightime = 0;
    unsigned long  Tick = 0;
    unsigned long  Tock = 0;
    bool  TickFlag = true;
    bool  CountStabalised = true;
    bool  DataReady = false;
    startPulse1Hz(0);
      set_direction(Pendulum,0);                     // enable pin for input
      waitcnt(CLKFREQ/10 + CNT);
      printf("Clock Frequency %d \n\n",CLKFREQ);
      CTRA = PosDetMask + Pendulum;                  // POSDET Set control mode and Pin
      FRQA = 1;
      CTRB = NegDetMask + Pendulum;                  // NEGDET  "     "      "   "    "
      FRQB = 1;
      waitpeq(IpBitMaskPendulum, IpBitMaskPendulum); //sync to input
      waitpeq(0,  IpBitMaskPendulum);
      PHSA = 0;                                      // ready for POSDET phase
      waitpne( IpBitMaskPendulum,  IpBitMaskPendulum);
      printf("Ready for positive detect %d\n");
      while(1)  {
        PHSB = 0;                               // pin is high, POSDET phsa advancing, phsb not
        waitpeq(0 ,  IpBitMaskPendulum);        // pin goes low, phsa stops, phsb starts
        hightime = PHSA;                        // pin is low, NEGDET phsb advancing, phsa not
        PHSA = 0;
        waitpeq( IpBitMaskPendulum,  IpBitMaskPendulum);          // pin goes high, phsb stops, phsa starts
        if(TickFlag)  {
            Tick = PHSB + hightime; //
            TickFlag = false;
            printf("Tick %d  " , Tick);
        else  {
          Tock = PHSB + hightime;
          TickFlag = true;
          printf(":: Tock %d" , Tock);
          printf(" :: Beat Error %d \n" ,Tick - Tock);
          if (CountStabalised > 2) {
            DataReady = true; // New Data ready for reading
          else  {
              CountStabalised++;
          }// if Count stabilised
        }// if Tickflag
     } // while
    print("Done \n");
    Then PASM in spin file Pulse1Hz.spin
    '**          Used to output a test signal at 1 Hz on Pin P16
    PUB PULSE
    cognew(@PULSE_1Hz, 0)                     ' Start a Cog with our assembly routine, no stack
                                              ' is required since PASM requires we explicitly
                                              ' assign and use memory locations within the Cog/Hub
    DAT
    PULSE_1Hz   org     0
        or      dira, Pin       'Set Pin to output
                 mov     Time1, cnt      'Calculate delay time
                 add     Time1, #9       'Set minimum delay here
    :loop        waitcnt Time1, Delay1   'Wait
                 xor     outa, Pin       'Toggle Output
                 waitcnt Time1, Delay2   'Wait
                 jmp     #:loop          'Loop endlessly
    Pin     long  |< 16                   'Pin number
    Delay1  long  1_000_000              'Output Pulse High Time  1_000_000
    Delay2  long  79_000_000             'Output Pulse Low Time   79_000_000
    Time1   res 1                        'System Counter Workspace
    fit    496                              'Display PASM size on Compile
    Thanks for having a look for me. forgot am using SimpleIDE to compile and download
    Bob
    PS any hints or tip you have about my code would be gratefully received. Always looking to learn.
    Well, the code you posted works without errors for me (and without the underscore thing, I was wrong with that, sorry).
    I have just added the two sources to a new SimpleIDE project and compiled.
    The spin file name is exactly as you typed in the post ? Because the symbol name is derived from the file name and it is case sensitive.
    Best regards,
    Marco.
  • Thanks for that Marco.
    Really scratching my head now.
    Cant have any typos if it runs for you.
  • Thanks everybody got it worked out.
    Had to have PASM as another Tab in SimpleIDE
    Brill.
