How to Determine Elapsed Time of a Loop — Parallax Forums
Hello,
Is there a way to determine the elapsed time of a loop in Propeller C?
Thank you.
    edited 2018-10-28 21:52
    Usually you save a copy of CNT just before the loop starts, then subtract that from CNT just after the loop ends. The difference is the number of elapsed system clocks. You need to #include <propeller.h> in your program. For example:
    int tryTiming(void) {
      int startTime;
      int i, j, k;
      startTime = CNT;  // remember starting time
      for (i=1;i<=100;i++)
        for (j=1;j<=100;j++) k = i * 12345 / j;  // multiply and divide
      return CNT - startTime;  // return time difference in system clocks
    We have 10,000 multiplies and divides plus assorted other operations. The system counter rolls over after 2^32 clock cycles so you need to keep the total loop time under roughly 53 seconds (2^32 / 80000000) using the normal 80MHz system clock. In this case, the values are signed, so the maximum loop time is 26 seconds.
  • Thanks for your reply, Mike. Using your code, I've done the following:
    #include propeller.h
    float startTime;
    float delta;
    // Do Prediction Step, note: filter is not using accel measurements at this point, only gyro, so it drifts
        startTime = CNT; // Remember starting time
        int N = 3;
        for(int i = 0; i < N; i++){
        // State derivatives
        float f[2] = {
          {gy+gx*sin(phi)*tan(theta)+gz*cos(phi)*tan(theta)},
          {gx*cos(phi)-gz*sin(phi)}
        // Calculate xhat
        // xhat = xhat + (Ts/N)*f
        xhat[0]=xhat[0]+(delta/N)*f[0];
        xhat[1]=xhat[1]+(delta/N)*f[1];
        phi=xhat[0];
        theta=xhat[1];
        print("%f  delta = %f\n",theta*180/PI, delta);
        delta = (CNT-startTime)/80000000;
    Have I implemented this correctly by dividing by 80,000,000 to get the elapsed time in seconds?
    David
  • Currently delta is uninitialised, could give you errors when you get to:
    // Calculate xhat
  • Yes, you divide by 80000000 to get seconds assuming the standard system clock of 80MHz.
  • 78rpm,
    Thanks. I have now initialized delta to an estimated value. Before it was assuming delta is zero.
    Mike,
    Thanks so much for your help. I have not changed anything with the clock so I'm assuming it is still set to 80 MHz.
    David
  • Unless you change the crystal on the board from 5MHz to something else, the system clock will normally be set to 80MHz (there’s a multiplier of x16 set by a constant (_clkmode) compiled as part of your program with a value of “pll16x”). The crystal frequency is specified by another constant (_xinfreq).
  • If you have a scope then a common way is to insert test pulses into your code so that when it enters a routine it may take a pin high and when it leaves it goes low again. That way you can see how often, how regular, and how long it is running for.
