duration of seven seg
I have a code that will cause the seven seg to count random numbers 0-9 once a button is pressed. I am have problems getting this to last for only for a certain amount of seconds though.
This is my code
"index VAR NIB
result VAR WORD
counter VAR WORD
time VAR WORD
duration VAR WORD
DO
RANDOM result
DEBUG ? IN0
IF (IN0 = 1) THEN
OUTH = %00000000
DIRH = %11111111
DO
RANDOM result
index = result//10
LOOKUP index , [ %11100111, %10000100, %11010011,
%11010110, %10110100, %01110110,
%01110111, %11000100, %11110111, %11110110 ], OUTH
DEBUG ? counter
LOOP
ENDIF
LOOP"
  • You need another loop to display the result once the button is released.
    In science there is no authority. There is only experiment.
    Life is unpredictable. Eat dessert first.
  • How does that help with making the action only last for 12 seconds for example?
    kwinn wrote: »
  • userjyjy wrote: »
    kwinn wrote: »
    You can count twelve "PAUSE 1000"s, for example. Think about it.
    Re-inventing the wheel is not a waste of time if, when you are done, you understand why it is round.
  • I think I see what you're saying. I'm going to try that tonight. Thanks!
    userjyjy wrote: »
    kwinn wrote: »
  • userjyjy wrote: »
    kwinn wrote: »
    One loop runs while the button is not pressed and displays the counter value.
    The second loop runs while the button is pressed and counts from 0 to 9. If you want the display blanked do that before you enter the second loop.
  • Hey I'm still not sure on how to implement that into my code.. how would i get it to count the 12 "1000 pauses" it just makes my numbers random slower.
    userjyjy wrote: »
    kwinn wrote: »
  • kwinn wrote: »
    userjyjy wrote: »
    kwinn wrote: »
    Like kwinn said...
  • I think I'm asking the wrong question. My apologies.. I would like the display to be random after the the button is pressed and released.So after the one cycle of the button the display shows random numbers for infinity. I need to change the infinity to a specific time.
    kwinn wrote: »
    userjyjy wrote: »
    kwinn wrote: »
    Like kwinn said...
  • This is the code for it running for infinity
    DO
    RANDOM result
    DEBUG ? IN0
    IF (IN0 = 1) THEN
    OUTH = %00000000
    DIRH = %11111111
    DO
    RANDOM result
    index = result//10
    DEBUG ? counter
    LOOP
    ENDIF
    LOOP
  • I'm thinking a loop until but I'm not sure how to represent that as in the time that has passed since the cycle of the button being pressed .
  • After working on it some more here is an updated code
    index VAR NIB
    result VAR WORD
    counter VAR WORD
    time VAR WORD
    duration VAR WORD
    result = 12000
    DO
    RANDOM result
    DEBUG ? IN0
    IF (IN0 = 1) THEN
    FOR counter = 0 TO 9
    FOR counter = 0 TO 300
    OUTH = %00000000
    DIRH = %11111111
    RANDOM result
    index = result//10
    DEBUG " ", DEC2 index, " ", BIN8 OUTH, CR
    NEXT
    NEXT
    ENDIF
    DEBUG ? counter
    LOOP
  • Hey guys I have a new code..Now I'm trying to figure out the increments every 2 seconds until 12 seconds
    DO
    RANDOM result
    DEBUG ? IN0
    IF (IN0 = 1) THEN
    FOR counter = 1 TO 1
    FOR counter = 1 TO 10
    OUTH = %00000000
    DIRH = %11111111
    RANDOM result
    index = result//10
    PAUSE 20
    NEXT
    FOR counter = 1 TO 5
    OUTH = %00000000
    DIRH = %11111111
    RANDOM result
    index = result//10
    PAUSE 40
    NEXT
    FOR counter = 1 TO 3
    OUTH = %00000000
    DIRH = %11111111
    RANDOM result
    index = result//10
    PAUSE 66
    NEXT
    FOR counter = 1 TO 2
    OUTH = %00000000
    DIRH = %11111111
    RANDOM result
    index = result//10
    PAUSE 100
    NEXT
    OUTH = %00000000
    DIRH = %11111111
    RANDOM result
    index = result//10
    PAUSE 200
    NEXT
    OUTH = %00000000
    DIRH = %11111111
    RANDOM result
    index = result//10
    PAUSE 400
    NEXT
    NEXT
    RANDOM result
    index = result//10
    ENDIF
    DEBUG ? counter
    LOOP
  • I think I may be misunderstanding what you are trying to do.
    userjyjy wrote: »
    By the above post and the code you have posted do you mean that when the button is pressed you want to generate a random number using the "random" command and then display it for a specific period of time (12 seconds) and then blank the display?
  • Yes! I would like to press the button and the display would randomly display numbers for 12 seconds. At the end of the 12 seconds a final number is displayed.
    I added pauses to each instruction to try to simulate a dice slowing down Every 2 seconds and then finally landing on a number at the end of the 12 seconds .
    quote="kwinn;c-1450429"]I think I may be misunderstanding what you are trying to do.
    userjyjy wrote: »
    By the above post and the code you have posted do you mean that when the button is pressed you want to generate a random number using the "random" command and then display it for a specific period of time (12 seconds) and then blank the display?[/quote]
  • The counter where I have 0 to 375 worked as far as randomly displaying numbers for 12 seconds. But I'm wanting to know the the time to be able to break it up so that I can slow the display down every two seconds leading up to the 12. I know how to slow it by using the pause. Just having trouble figuring out the time table for the 2 second intervals.
  • So you want to start out changing quickly and then slowing down until the final number is displayed.
    Loops inside loops:
    For I = 1 to 6          'loop changes the the pauses
      for J = 1 to 4        'arbitrarily four numbers displayed for each period
         get random
         display it
         loopup I, [125, 250, 500, 1000, 1500, 2000], Period     'choose how long to wait
         PAUSE Period
         Next
    Next
  • Would I add that inside the for counter loops that I already have ? Sorry for all of the questions. I'm not that good at coding ...
    Loops inside loops:
         get random
         display it
         PAUSE Period
         Next
    Next
  • Run it all by itself. You will need to define the variables I, J, and period. Replace the "get random" and "display it" with real code from your examples.
    See what it does. Study it in concert along with re-reading the relevant pages in the BASIC book. Change it to see how the results vary.
    You will almost certainly want to fiddle the constants 6 and 4, and likely the constants that end up in period.
    I see I wrote loopup when i meant LOOKUP.
    When you post more code, be sure and use the big "C" in the formatting bar so the indentations are preserved.
  • Ok thanks! I'll try it tonight. I'll update you on my progress. You're much appreciated !
  • userjyjy wrote: »
    No one is until they have done a lot of coding. It takes practice and study.
    Loops inside loops:
         get random
         display it
         lookup I, [125, 250, 500, 1000, 1500, 2000], Period     'choose how long to wait
         PAUSE Period
         Next
    Next
    This code Tom posted should get you close to the effect you want. Just keep in mind that pause is in milliseconds so the sum of all the numbers in the lookup should be close to the total time you want (so 12,000 for 12 seconds). The time it takes for the code to execute will add an insignificant bit of time to the total.
  • Thanks man! I appreciate you too. I'll update you guys tonight with my results.
    kwinn wrote: »
    userjyjy wrote: »
    Loops inside loops:
         get random
         display it
         PAUSE Period
         Next
    Next
  • Hey guys! I appreciate you alls help! I got it to work!
