New and improved "High Performance" fidget spinner powered by Flip
Beavis3215
I had a technical error before with the interface between the Hall sensors and the FLIP giving me false hits, less performance and poor tachometer readings. I improved the spinner with a better bearing, smaller closer sensor targets, and less weight. I also changed the angle of the electromagnet. The result is a precision instrument that nothing less than violent!
