How to Power Propeller Activity Board
Hello,
Is there a way to power the Activity Board other than using the 6-9 VDC power jack? I'd like to use a different lipo battery pack to power the Propeller and two motors. Is it possible to do this without splicing a male power jack (the one to fit the female jack on the board) onto the battery leads?
Thanks.
  • The schematics are here for Rev versions A, B and C.
    https://www.parallax.com/downloads/propeller-activity-board-wx-schematic
    Looks like the cleanest way will be to make up a short adapter cable like you describe.
  • Hello,
    Thanks.
    It is possible to solder wires to the power jack terminals on the WX board, but I agree with VonSzarvas, the cleanest way is with an adapter cable. It also makes it easier to remove and replace/repair/modify the board if required.
    In science there is no authority. There is only experiment.
    Life is unpredictable. Eat dessert first.
  • Thanks guys. I wasn't sure if there is a Vin pin, something like on the Arduino. That's fine, I'll just make a cable.
    David
