Can you use an Arduino Uno as a prop plug substitute
ti85
in Propeller 1
Can you use an Arduino Uno as a prop plug substitute? The Arduino uses an ATmega16u2 for USB communications. By using, a jumper wire to hold the ATmega328 in reset (GND) you can bypass the ATmega328 and get serial communication from the ATmega16u2 on pins 0 and 1. In addition, the DTR line is available at c5 (100n). Looking at the prop plug schematics it looks like you would just need to add a transistor and resister to invert the DTR line and create an RC
So after making those changes (holding atmega328 in reset and jumper wire from DTR with transistor to invert DTR), would the Arduino Uno work like a prop plug for programming the propeller chip? Would the propeller IDE recognize the atmega16U2 for serial communication?
How to handle DTR ia a different story. Do it like the PropPlug?
—▷ PropPlug schematics (page 5)
I prefer to use modules with FT232R or CP2102 for such tasks.
I had used it at 8MHz so it would run at 3.3V to try and keep things friendly
Moved jobs ... moved house (twice) ... must get back to making things.
