Walmart $1.97 Motor Brackets
Just a bit of grinding and WM's steel corner brackets make dandy motor brackets for Stingray-style gearmotors. Stronger and cheaper than RS's simple aluminum ones: https://www.robotshop.com/en/dc-geared-motor-bracket-spg30-spg50.html
Please delete this post, Mods!
A good Nibbler tool would do nice in this situation as well fro your bracket instead of grinding...
I'm attaching a pic of the 3 "danger holes" to use short screws in. If you don't believe me, shove a straightened paper clip wire into those holes while the motor is running.
