CM2302 power cosiderations
Rsadeika
in Propeller 1
In my new project I want to place the CM2302 module outside, and have it connected to the Activity Board using some four wire telephone cable, which will be located inside the house.
Now the questions is, since the cable will be at least forty feet in length, will the Activity board be able to supply the necessary power. I am not sure as to how much power it will cost to deliver the necessary voltage over forty feet of wire. The telephone cable has four wires that look like they maybe 16 or 18 gauge. Forty feet is my guesstimate at the moment, it could be a longer distance.
Since I am not an electrical engineer, I am not sure how I would go about calculating for the voltage value requirements. Any help would be appreciated.
Ray
Ray
Be sure to decouple the device, and use a stiff pull up (4k7 or lower) for a long run like this.
See fig 5.1.2 in the cm2302 user manual for suggested components for the sensor end of the cable.
Your will need to level shift to 5V as the CM2302 is not rated for cable runs over 10cm at 3V3, only 5V.
Probably my first test with the implementation, with the Activity Board, I will be using the 5V power supply, I am not sure which pull-up configuration that I should use, 4.7K or 10K. In fact this pull-up stuff is starting to get confusing, when do you use, and what do you use. Since I am using the new Activity Board, which has a better power source, I think it should be able to handle the forty or fifty feet of cable between the module and the Activity Board, using the 5V power source.
Ray
By all means, add a decoupling capacitor or balanced pair using a 0.1uF and perhaps a 10uF, the larger once provides the overall power to overcome "brownouts" while the 0.1uF handles the higher frequency switching transients better.
I was pleasantly surprised at accuracy of the module, not necessary to calibrate the module, the readings are very close.
I tested this with my FLiP module, now I will procced to add this too my Activity Board and do the telephone cable extension test. As it turns out, I am only using about twenty feet of cable, so I think that 3.3V should be plenty for this to work.
Ray
