Propeller PCB Layout Template and First Attempt - Page 4 — Parallax Forums
124»
  • Good news. I use the rotary encoder object in OBEX and it works well but yes it wants pins in order. No idea about C.
  • Duh. It turns out my LED circuit works correctly after all. The problem I had earlier was due to using a ring of RGBW LEDs for testing. The driver only handles RGB LEDs at present. When I replaced that with a ring of RGB LEDs everything started working correctly. So I guess everything on the board works. The only problem was a reversed connection on the rotary encoder and the inability of my rotary encoder driver to handle the case where pin B was not pin A+1.
    edited 2018-07-03 15:59
    That's good news David!
  • Publison wrote: »
    Now I need to move on to a completely manual layout where the signals and power are routed more sensibly. I'm in the process of learning KiCad for that.
