Is this the right place to request an addition to blockly?
pwiecekpwiecek Posts: 21
I would like to have a control block that allows multiple lines of code to be disabled/enabled with one click. I'm currently using:
To disable the code, I simply disable the If. (You could achieve the same thing by changing the condition to "False" but that's not the way I choose to do it.)
  • 4 Comments sorted by Date Added Votes
  • You can request changes/improvements/bugs to Blockly here on the forums or on the GitHub, which we monitor more closely https://github.com/parallaxinc/BlocklyProp/issues.
    To clarify, what you're asking for is a shift-select with multiple disable, right? You'd like to disable chosen Terminal blocks but not all of them?
    At present, you'd need to disable individual Terminal blocks or the entire IF-DO loop.
  • Ken Gracey wrote: »
    That would fill the bill but I was specifically asking for something else. Here is my idea of what it would look like:
    Ken Gracey wrote: »
    At present, you'd need to disable <snip> the entire IF-DO loop.
    That is my current work around
  • So you are asking for basically a blank "statement" block - I think that's the official name for the type of input that holds groups of blocks...
    Like this:group_block.png
    While it's possible, I'm not sure how I feel about it. This one falls into a category of blocks that don't really have a code function, but do serve a purpose in helping you "visualize" or work with your blockly code. Another example is a "start" block - it doesn't do anything, but it marks the start of a program.
    Worth discussing - let's see where this thread goes...
    184 x 60 - 6K
    Matthew Matz
    STEM/Robotics Educator
    Parallax Inc.
  • As a visual programming language, these kinds of enhancements make sense - especially as users start to grow larger programs. It's similar to a comment block, I suppose, but with the ability to encapsulate a bunch of other code. I've also produced some really big BlocklyProp programs where I've relied on "collapse block" and "clean workspace" to get things organized.
    Others have thoughts on this?
