Looking for FPGA board
                    I'm looking for an FPGA board for P2 development but I'm having problems finding them for purchase (and fitting my budget).
The Prop123 is out of my budget (dang!) and the DE0-nano does not have CORDIC.
I need a board that can support at least:
-one Cog
-64K RAM & the 16K ROM
-8 Smart pins
-CORDIC
Everything else is a bonus :-)
I'm looking at Terasic's page and the DE10-nano (110k LEs) and the DE0-CV (49K LEs) look good and are affordable.
But are they supported !?! Is there an image for them?
Alternatively, the BeMicro CV might work (25k LEs) but I can't find it anywhere to buy.
Can it fit the CORDIC unit?
DE10-nano
http://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=1046
DE0-CV
http://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=165&No=921&PartNo=1
Jason
-one Cog
-8 Smart pins
-CORDIC
DE10-nano
DE0-CV
Jason
Boards listed are in this thread
https://forums.parallax.com/discussion/162298/prop2-fpga-files-updated-2-june-2018-final-version-32i/p1
Looks like DE2-115 is the smallest supported one that can fit cordic. (which is the toughest requirement, once you have cordic, everything else is ample..)
smart cogs pins RAM Freq CORDIC Filename +----------------------------------------------------------------------------------------- Prop123-A9 | 16 7 1024k 80MHz Yes Prop123_A9_Prop2_16cogs_v32i.rbf - not ready Prop123-A9 | 8 64 512k 80MHz Yes Prop123_A9_Prop2_8cogs_v32i.rbf ** - READY BeMicro-A9 | 16 7 1024k 80MHz Yes BeMicro_A9_Prop2_16cogs_v32i.jic * - not ready BeMicro-A9 | 8 64 512k 80MHz Yes BeMicro_A9_Prop2_8cogs_v32i.jic */** - READY Prop123-A7 | 4 38 512k 80MHz Yes Prop123_A7_Prop2_v32i.rbf - READY DE2-115 | 4 20 256k 80MHz Yes DE2_115_Prop2_v32i.pof * - READY BeMicro-A2 | 1 7 128k 80MHz No BeMicro_A2_Prop2_v32i.jic * - READY DE0-Nano | 1 8 32k 80MHz No DE0_Nano_Prop2_v32i.jic - READY DE0-Nano Bare | 1 8 32k 80MHz No DE0_Nano_Bare_Prop2_v32i.jic - READY * These images always map SD card pins {CSn,CLK,DO,DI} into P[61:58]. ** These images represent the logic and memory that will be built in silicon.DE2-115 seems to ue
EP4CE115F23I7N Cyclone® IV E Active 7155 LAB 114480 LE 3981312 RAMb
DE10-NANO
5CSEBA6U23I7N 47 - Immediate $246.42000 Cyclone® V SE Dual ARM® Cortex®-A9 MPCore™ with CoreSight™ 64KB
DMA, POR, WDT CAN, EBI/EMI, Ethernet, I²C, MMC/SD/SDIO, SPI, UART/USART, USB OTG 800MHz FPGA - 110K Logic Elements
P0496 Terasic Inc. DE10-NANO CYCLONE V SE SOC KIT 1,252 - Immediate $130.00000
Notice the DE10-Nano price is well under the chip price !
DE0-CV is more $ and only 49k LE, so the DE10-Nano looks viable, but right now there is no compiled image for that.
@cgracey Any chance of a DE10-Nano compile??
Jason
Interesting question, but nothing on the current list has spare room to meet the other requirements, and add a cordic.
20k LE's or about 8k ALM'S.
Ken
It's inexpensive and can accommodate a decent portion of the P2.
Jason
It's 'reasonable', but would only be known if Chip decides to add a build for the DE10-NANO 5CSEBA6U23I7N
PortA only with 32K Hub and 8 cogs.
ALM usage jumps from 18% to 22%
Based on Chip's comment that the Cordic uses ~8K ALM's that's about 20% of the available ALM's.
A P2 build will come down finding a good balance of cogs and smartpins.
